- High Pressure Fuel Pumped changed..now jerks when accelerating
- Turbo failed at high altitude
- Tire pressure indicator issue
- Stupid Handbrake
- Radio changing channel randomly
- Fuel Gauge Arrow
- Headliner Color
- Fuel System Issues!
- light thumping...
- Battery replacement
- Driver's Window Lost Its Viagra
- Uneasy driving over bumps???
- Peeling rubber coating on steering wheel
- Soft brake pedal
- unable to turn off radio
- dusty door sills
- Heads up on automatic shift lever failing...
- Bonnet Washer Jet Tubing
- Never Buy a Countryman
- Battery Died
- Jammed Key Fob while in ignition
- engine vibration
- Rolling Noise from dash
- Brake pedal click/clack when in Park
- Rear Window Issue
- High pitched buzz/rattle in the front passenger door
- Peeling Trim Update from MA
- 2011 S, 3K miles, several issues
- rattling noise when downshifting?
- 2004 Mini S cranks but will not start
- Misfiring issues
- Oil Film on Oil Vapor Return Line
- Junction Block Failure
- Low tire pressure (all 4 at once)
- No sound from speakers?!
- iPod connecting issue
- Turn signals not clicking in rhythm?
- Help!! Noise from engine bay when car is off killing battery
- Steering problems?
- Chrome Trim Peeling after 7-days
- Tailing Arm Issue
- Window Adjustment
- Squeaky Clutch Pedal
- Stumble when accelerating?
- CM rear view mirror vibration
- Codes found with scangauge..
- 1st time post: Countryman front axle problem
- Engine malfunction, reduced power message?
- nobody can hear me well when using Bluetooth telephone.
- General Creak / Rattle / Buzz Solution Log
- Wheel-Tire ballance problem Cooper S FWD
- Yellow engine power warning light
- Lift gate NOT locking
- fan still on when turn off car
- CREAKS and Buzzes
- CM iPhone 3gs Snap In Adapter
- Need New Radiator. And Need Some Advice
- Navigation Maps and Speech
- Video from iPod Nano
- Toasted HK Amp
- Re:help with Ipod
- A/C capability
- So I threw a CEL today.
- Anyone having door/window rattles
- Connected display screen not working
- 08 Clubman Front Bumper: Repair or Replace?
- "P" indicator remaining illuminated. huh?
- Countryman Shifter
- Countryman Hazard Lights Switch
- Ghost in the Machine
- Sunroof Rattle
- Countryman wheel arches
- Engine Noise
- iPod Classic not recognized!
- Hello from Illinois.Help if you can!
- Brand new MINI Countryman S All4 Clutch burnt in snow?
- Engine Emissions Warning Light at 600 miles
- Driver's side front window problem
- Faint Brake Grinding and Paddle Shifters not working properly?
- Window Issue
- Extended Motorer Protection Program?
- problems with Countryman year 1 - 2011
- electrical problems
