PDA
View Full Version : R60/R61 Stock Problems/Issues
Pages : 1 2 [3] 4 5
  1. Glove Box Light Replacement
  2. Can anyone tell me if i have Intelligent battery System from VIN?
  3. A/C Issues; Need clarity
  4. CV axle shaft removal
  5. Stuttering while accelerating
  6. 2012 Mini Countryman R60 Tail Light
  7. How to access Fog Lights to replace bulb
  8. Water rushing sound/water inside the frame or door?
  9. Mini connected
  10. Friction wheel replacement
  11. Weird acceleration studder/shifting...?
  12. N18 engine noise after shut-off
  13. Driver seat shifting when braking/accelerating
  14. Timing chain tensioner
  15. AC, Blower motor problems
  16. 2014 Mini Countryman Bike Rack Repair
  17. CM 2011 auto trans oil change
  18. "Music collection" can't have 2 albums with same name? 2017 CMS All4
  19. Replacing rotors and pads
  20. Bleeding brakes. No fluid from calipers!
  21. Fuse for lighter/power?
  22. Engine ventilation heating, activation: line disconnecting
  23. Broken fog light cover
  24. '17 CMS All4 - Parking Brake Question...
  25. Rear squeaking noise
  26. 2017 Countryman - First tow to dealer
  27. Creaky Center Arm Rest Help!
  28. Miltek Downpipe intstall now I have an o2 sensor light
  29. Stalls right after start.
  30. Cold Start Noise - Not timing chain IMO
  31. R60S Sputter Under Full Throttle @ 3000-5000RPM
  32. Preventative maintenance - upper timing chain rail and tensioner
  33. Unable to send text via speech
  34. Rear of car "lifts up" when reversing on a hill?
  35. The Acceleration Stutter - Pulling my hair out.
  36. knock sensor - codes P13B8 & 2D8E
  37. Name that part - CV Axle housing bolt? Something...
  38. Limp mode at 2500 rpm
  39. Squeak (not brakes)
  40. Miss firing 1 and 4 and over heating off and on
  41. Footwell module, no pwr windows, no blinkers
  42. Hot drive to california
  43. Seat Height problems
  44. Clutch | Can I Launch This Car?
  45. rear end noise off throttle
  46. Interior ambient lighting problem.
  47. Warped door panels?
  48. Hard accel stutter
  49. Parking light replacements
  50. F60 SZL (Steering Angle Sensor?) Clip Bulletin
  51. Ck Engine light on throwing code P0012
  52. 2011 S All4 - HPFP dying, or?
  53. F60 FM Antenna Issues
  54. Turbo replacement aftermarket recommendations
  55. Second clutch issue
  56. MFSW Retrofit
  57. Rock hit my windshield
  58. 2011 Countryman S All4 jerking on downshifts
  59. Code
  60. Clutch slipping and no smell?
  61. Clutch slipping and no smell?
  62. 2011 Countryman S Valvetronic fault codes
  63. Rear cargo light fuse and passenger airbag light
  64. Car won't start - just cranks?
  65. AC not working after Pressure washing
  66. Inside door handle won't open door - Help!
  67. 2011 mini countryman all4 codes
  68. Ignition coil issues
  69. Help! What does this mean??
  70. My battery keeps dying every week or so, what do I do?
  71. Coolant Leak
  72. Water Pump
  73. 2012 Countryman All4 Bucking
  74. 2012 Mini Cooper S Countryman All4 "Bucking issue"
  75. Sprint Booster Issue
  76. n18 noises
  77. Part Identification Help
  78. Removing headlights - nut spinning
  79. Valve Cover Issues - 2011
  80. Where is AC compressor located?
  81. Normal or not?
  82. 2013 Countryman S All4 Acceleration Issue
  83. Oil Burn Question
  84. Flooded fusebox?
  85. Strange "jerk" when quick-accel from stop...
  86. Half engine light
  87. Humming noise at 45-50 mph
  88. How do you swap out the trunk badge on MCS?
  89. Ac compressor
  90. DME Question
  91. 2011 Countryman--Where do I start???
  92. Disturbing noise
  93. Bumper dings: Easy fix without removing bumper?
  94. Idle rpm goes to 3500 on start
  95. Punctured gas tank
  96. Brake pedal vibration at startup
  97. Multiple '16 Coutnryman Audio/Infotainment issues
  98. Engine Malfunction! Reduced Power combination?! Help?
  99. Battery Drain Warning
  100. 2012 R60 Heater Blower Half Works
  101. Abs turning noise? Need help
  102. 11 Countryman keeps blowing Fuse #2
  103. Trunk won't open - can it be manually released?
  104. Turn Signal Three Blinks Issue
  105. How to change oil pressure sensor switch?
  106. What fuse is what fuse???
  107. 2014 Countryman S Xenon Bulb Removal and Replacement
  108. ATTN DIY Spark Plug changers
  109. Rear alignment off
  110. Stiff shifting in gears 3-6
  111. did i get taken for a ride by mechanic?
  112. Crack in R/R lower control arm/knuckle assembly
  113. How many failed HPFPs? Enough to investigate?
  114. Help! JB+ Check Engine Light
  115. What Fluid for Transfer Case
  116. I did something stupid= Oil light/Half Engine CEL
  117. Engine light on (cut engine power)
  118. How do I program a key for my 2012 Countryman.
  119. Controller Joystick malfunction
  120. Acceleration hesitation on R60 Non-S
  121. Half engine light on!
  122. 2014 R60 HK radio dead
  123. Rear under tray - gas tank
  124. Cam sensors
  125. Spark Plug Gap
  126. Half engine light with full power
  127. All 3 cigarette lighters out, fuses ok
  128. R60 - What does this bolt do?
  129. Poly LCA Bushing
  130. R60. Too many malfunctions!
  131. No start, no codes, no ideas. HELP!
  132. Xenon failure ?
  133. Turbo failure at 70K
  134. Suspension Busings
  135. Auto gearbox problem?
  136. '15 CM S All4 Windshield
  137. Brake lights remain on when headlights are on?
  138. Rear Camber Problems
  139. Few codes and rpms unstable
  140. P00BD code ?
  141. P0015 Code
  142. Removoning CM scuttles
  143. Exhaust Smell in Cabin Countryman S
  144. LCA and Sway Bar Bushings
  145. LED Headlight Question
  146. Thermostat housing issue
  147. HELP!!! 2009 Clubman, 50k miles- need a new engine, water pump???
  148. R60 Rough idle Manic Tune
  149. misfires and P2402
  150. Replacement Coils
  151. Wet floor
  152. Cylinder Head Cover Replacement
  153. 2012 Countryman oil in discharge pipe
  154. Seatbelt and Airbag light staying on. Any advice?
  155. 2016 Rear seat belt fail: Can you please test on yours?
  156. Hard ride on New 2016? Easy fix...
  157. Tapping, Rattling noise right rear passenger
  158. Brake cooling channel coming apart?
  159. countyman rear driveshaft removal from gearbox
  160. Leak from coolant temp sensor on elbow 2012 countryman S
  161. Successful battery replacement in a 2011 Countryman
  162. Plastic Brake Sensor Attachment Point - Broken
  163. AC Recirculation + Tire Warning
  164. Doors wont lock
  165. HP fuel pump replaced- Lost power.
  166. P053A code
  167. "The oil leak"
  168. Grinding on cold start
  169. Lighting Malfunction Warning
  170. Front side windows and triangular trim piece installation
  171. Driver side headlight and wipers not working
  172. Where can I get good deal JCW mouldings and skirts??
  173. Gas gauge issue after ECU reset
  174. Passenger seat sensor (airbag)
  175. Extended waranty for 2012 Countryman S?
  176. Programming Homelink HELP!
  177. Wind Noise w/ Thule Edge Aeroblades 7601
  178. Intermittent radio issue
  179. Intermittent misfire codes, no CEL
  180. Rear door locking issue
  181. 4x4!, DSC, engine malfunction lights = car won't run...
  182. Stripes are peeling and fading! Replacements?
  183. Usb and Aux will only recognize 30 pin Y cable
  184. Voltage drop AFTER start up
  185. Engine malfunction light yellow/fault warning flashing
  186. Electrical gremlins!
  187. Countryman: what kind of issues to expect in the first few years?
  188. Leatherette is cracking
  189. Xenon headlight fogging
  190. New intercooler, but higher temps
  191. Key not unlocking car but will turn on car with all engine lights on
  192. P306c and P306f codes
  193. 2015 Cooling Fan Running High all the time
  194. Clear codes
  195. Single Click Noise after stopping then accelerating.
  196. New 2015 CM 600 miles - More than normal Fault Codes
  197. So many codes!
  198. Countryman Rear Caliper Dust Boot Torn
  199. Rear shaft CV difficulty
  200. What's the EPDW valve?
  201. CLUTCH died
  202. SPC Lower Control Arm Loosening - Scary!!
  203. iPhone 6 Plus and connecting
  204. Cracking windshields..........
  205. Electrical Problem, windows, headlights, interior lighting
  206. Driver's Seat Lumbar Popping Feeling
  207. Loosing antifreeze?
  208. 2015 countryman S ALL 4 engine Rattle/ticking
  209. Oil Leak
  210. TPMS Receiver Location
  211. P2402
  212. Mini Connected Pairing Issue
  213. Super-annoying rattle from back seat area
  214. iPhone6 and Video not working
  215. Need a new turbo...
  216. Ignition Help 2011 Countryman
  217. Aftermarket stereo- Ant cable
  218. Passanger Seat Occupancy Sensor
  219. Lock issue
  220. 2014 JCW Countryman has bad timing chain tensioner
  221. Clearing CELs with OBD2 apps
  222. Blower not working - 2013 Countryman
  223. Bad ECU?
  224. Increased Battery Discharge warning
  225. 2012 All4 clutch, alternator and HPFP have all already died
  226. Occasional smoke at startup
  227. Start/Stop Button Intermittent Problem R60
  228. Too much boost problem
  229. Engine Fault Message
  230. Starting problem
  231. iOS 8 sucks
  232. Dynamic Stability Control System
  233. Water dripping from rear view mirror
  234. Super Knock Cylinder 3
  235. Vibration from 3-3500 rpm
  236. Rotational thumping type noise and feel under acceleration
  237. Door Locks
  238. BMW 2C57 2C91 Codes
  239. 2011 Countryman - Potential Issues
  240. Oh where oh where has my radiator fluid gone?????
  241. DTC Fault Code 3786??
  242. Wierd electrical with new 2014 Countryman?
  243. Brake caliper piston won't go in
  244. Grille Lights
  245. Trans replaced at 8k miles
  246. New turbo
  247. Countryman Boot Stuck
  248. Contryman front brake retainer screw torque
  249. 2012 All4 Transfer Case Seals
  250. Auto Transmission Failure at 63k miles
