SPC Lower Control Arm Loosening - Scary!!
Old Jun 22, 2015 | 07:12 PM
monkiboy's Avatar
monkiboy
Hey Guys,
I just got home and checked the rear wheels and noticed that one wheel the camber is CRAZY off. I'm so glad I went to check because I feel like if I drive the car any more it the wheel would just come loose where it comes to the lower control arm.
I just installed a set of SPC lower control arms a week ago and this happened. Is it a problem with the arms themselves or is it because the nuts were not tightened enough?
It actually really worries me, now that I think about it the adjustable arms aren't really designed so well. What are all your thoughts? Anybody experienced this before?
Attached Thumbnails SPC Lower Control Arm Loosening - Scary!!-img_20150622_215424.jpg   SPC Lower Control Arm Loosening - Scary!!-img_20150622_215438.jpg
Old Jun 23, 2015 | 06:15 AM
Have not seen that before, did you follow the instructions?
http://www.spcalignment.com/instruct...10-INS_WEB.pdf
Looks like you did not tighten them down all the way. Can you spin the inner rod by hand. I don't see anything broken ?
Also you can post in this section for the Countryman, https://www.northamericanmotoring.co...yman-talk-355/
you are in Gen 3 right now.
Old Jun 24, 2015 | 08:01 AM
kyoo's Avatar
kyoo
yikes
Old Jun 29, 2015 | 08:12 PM
Shoof's Avatar
Shoof
Did you just install them yourself without having the car aligned at the same time? Because that's where you went wrong if you did that. Get your car aligned, and this will be corrected...I'll bet you didn't properly tighten it and your rear alignment is waaaaay off!
Old Jul 10, 2015 | 05:39 AM
Any update ?
Old Jul 10, 2015 | 05:45 AM
Ryephile's Avatar
Ryephile
Very likely you forgot to tighten them.
This is why after you torque safety-critical bolts you mark their position with a paint marker. It's a verification you torqued it correctly plus you can easily see if the fastener has loosened.
On a related note; is your ride height or alignment requirements so different that the OEM eccentric cam can't adjust it enough?
Old May 25, 2019 | 08:51 AM
Thumper996's Avatar
Thumper996
I have found that the factory rear camber adjustments will get you close to spec but not exactly. I have installed these arms on several R60s and have never had this problem.
ebowling
90
Aug 4, 2019 09:15 AM
BRracing
Dec 22, 2015 09:25 AM
Manny_cooper
Nov 4, 2015 09:42 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
