PDA
View Full Version : R60/R61 Stock Problems/Issues
Pages : 1 2 3 [4] 5
  1. 2012 All4 Transfer Case Seals
  2. Auto Transmission Failure at 63k miles
  3. Carbon buildup
  4. Mini Connected Bluetooth freaking out
  5. Passenger Door Ajar Warning When Door Closed
  6. Mirror scrape
  7. Please help!! (videos), Possible Timing chain & Water pump issue
  8. 2011-12 Countryman ALL4 solenoid recall
  9. 4X4! warming light on the speedometer
  10. Passenger Door
  11. P306c cel
  12. Readiness Codes
  13. CM Fuel Filter
  14. Help HK work with MP3 player
  15. Location of AC drain
  16. Countryman rattle.
  17. Missing Splash Shield?
  18. Best way to charge Countryman battery?
  19. Engine/ injectors
  20. Cold start + rattle
  21. Vibration and noise from steering wheel or front tires
  22. The Polar Vortex, a rattle, and my check engine light
  23. Countryman Door issue
  24. Rear Hatch and Wiper
  25. Bad Spark Plugs?
  26. 2011 Countryman S no power at 4,000rpm HELP
  27. 2013 tachometer digital display modification?
  28. Brake Job Cost / Parts + Labor - Non Dealer
  29. CMS All 4 Trunk Wont Unlatch in Freezing Cold
  30. Check engine light caused by cold weather?
  31. Countryman abs, all4, and tpms issues
  32. anyone know how to adjust the xenon headlight?
  33. Airbag light on
  34. 2014 Paceman Cold Start issue?
  35. Engine Stopped and Will not Restart, Towed to Dealer!
  36. Mini countrryman
  37. Engine rattle only at certain RPM's
  38. Fan Issues
  39. Anybody have issues with tire pressure sensor?
  40. MINI Connected new iPhone question.. More of an iPhone 5 data question...
  41. Film on winshield
  42. Engine Hissing Sound
  43. Invisible oil leak with no light indication?
  44. Sport Seat Discomfort...Help
  45. Flutter when off throttle
  46. transfer case on all4 s
  47. Anyone know how to replace this piece?
  48. Air Filter Help
  49. Ignition Coils
  50. Does The Countryman's AC Just Suck?
  51. Blank Driving Excitement Mini Connected
  52. HELP!Mini Countryman ISSUES IN CANADA!
  53. help/anyone else had these issues?
  54. Leaking Coolant & Rough Idle
  55. New CMS strange leather smell
  56. Software Used to Reset Adaptations?
  57. Missing part problem
  58. Pulsating Ticking Sound
  59. Recall list for 2012 Countryman?
  60. Mystery Bulb Out?
  61. Engine clatter, poss. 'death rattle'?
  62. My baby is hurt - Feedback please?
  63. Turbo Replacement - Dealer Issues
  64. Rough Idle with automatic transmission
  65. sounds like a valve is loose, tapping from top of engine
  66. Engine Power warning light after T-stat housing replacement
  67. Help!! Error Code: P2D9B &P2D50
  68. Electrical Issue. Need Help.
  69. 1101S Subwoofer Issue
  70. Folding mirrors - 2012 ClubmanS
  71. Rear glass
  72. Mini countryman all4s2011 current fuel consumption delay display problem
  73. Unusual Rhytmic Whining From Rear of S ALL4
  74. Lighting code issue
  75. Code P0301 Rough idle when cold
  76. Broken ground wire - Please Help!
  77. Auto transmission downshift issue?
  78. Rear Seat Back Release
  79. Not so cool A/C
  80. Motor problems
  81. Intense oil leak/spill and loud rattling
  82. Help - New Countryman 2013 Oil Light Warning
  83. Steering wheel volume control button issues
  84. CMS Ski/Snowboard Attachment Whistling
  85. Alarm problems
  86. Key not recognized
  87. Bi-Xenon Headlight Cutoff switch/adjustment
  88. Loose Hood Latches
  89. New ignition coils
  90. Idle issues
  91. Rattling Noise - Trunk Compartment
  92. Oil leak?
  93. Side Mirror Issues: Potential DIY Fix
  94. Countryman steering problem
  95. malfunction, malfunction, malfunction
  96. MINI Connected - iPhone backlight has to stay on?
  97. Known Issues With 11-12 CMS
  98. High Battery Drain Warning
  99. What kind of brake fluid does the r60 take? Dot4?
  100. Yellow Check Engine Light Stays On
  101. OMG! Routine service for $1222!!!!
  102. 2012 MC Countryman -Leak, overheating & no heater
  103. Annoying squeaking sound during cold start
  104. dashboard rattle
  105. Key Fob Slot Stuck
  106. Dead Battery, Key FOB Stuck, Frozen Break Pedal --Road Side Assistance
  107. Of Mice and Countrymen
  108. Manual tailgate latch?
  109. Minicountryman 2012
  110. Front passenger door won't open when cold
  111. ear splittig noise with rear windows down - highway speeds
  112. I'm on my 3rd high pressure fuel pump
  113. Door rattle - solved it with rubber lube
  114. Oil warning coming on sporadically
  115. Alignment Issues
  116. Coolant Sensor Oil Leaking into wiring main harness affecting main computer. (RECALL)
  117. Leaking Valve Cover
  118. Stuff stuck in hatch lock
  119. headlight shortage
  120. Countryman All4 Towed on 2 wheels!
  121. Master technician in so cal looking for service work
  122. Is my car a Lemon? - 2012 Countryman ALL4 in NY
  123. Have I made a $31,000 mistake ?
  124. Left MAF unplugged by accident -CEL
  125. Dealership forgot to put in engine coolant!
  126. Poor Fuel Mileage CMS4
  127. Rear Transaxle Issue ALL4
  128. Joystick Problem
  129. "something died inside" smell - cabin air
  130. 2012 Countryman S - Vibr-O-Matic Rear View Option
  131. Broken lumbar support
  132. iPhone Phone book Transfer
  133. bloody bus hit my car :S advice needed!
  134. SUPER loud fan coming on when hot out - is this normal?
  135. Odd Warning Light Not in Manual
  136. How to change the left rear light ?
  137. Code: CC-ID 345--what is it?
  138. Found a Fluid leak!!
  139. Bonnet/hood release cable broken?
  140. Tire rub issue
  141. Oddball Problem With Audio Presets
  142. starting problems
  143. PSA/BMW 1.6T issues – How to diagnose
  144. 2012 CMS All4 (6M) pulling to right when accelerating on hwy
  145. check engine light
  146. Navigation issue
  147. Driver's Side window problem
  148. High pitched squeal from rear passenger side
  149. black liquid leaking from exhaust
  150. Trunk Won't Open
  151. mini countryman door rattling noise *solved*
  152. A/C getting warmer and warmer
  153. No A/C, no fan...
  154. What the ...
  155. Service Light???
  156. Is it me or something else
  157. Engine malfunction and fan running long after car is off...
  158. Question on lemon law Days out of service
  159. countryman whooping sound
  160. Brake/Suspension malfunction
  161. Valvetronic - Is this a common issue with our CM's?
  162. "Passenger Airbag is Off" Warning Light
  163. Grinding noise when drive at low speed after car sitting for hours
  164. tip rattling: remove the rail cup holders/rear boot flap
  165. vehicle lost it's original power - check your air filter
  166. Overly Sensitive Seatbelt Sensor??
  167. automatic kickdown problem
  168. Automatic gearbox problems shifting into 4th gear
  169. Creaky Window Seals
  170. Valvetronic issue
  171. Engine warning light -- Error code P0087. What does it mean?
  172. 2011 MINI Countryman S Service Bulletins/recalls
  173. gas mileage
  174. How to turn up the lights inside CM?
  175. Bench seat pull handle
  176. speakers not working
  177. Coolant leaking from reservoir cap?
  178. Bonnet/Hood alignment off when closed
  179. 2005 conv.works kit S MOtor and cables shot?
  180. Rear hatch release
  181. Car stutters when I take my foot off the gas pedal
  182. hit a bump/pothole and the DSC & hill assist throw up warnings
  183. Can't adjust side view mirrors
  184. re-mapping question
  185. Weird smell from the engine compartment
  186. Fuse icon decoding
  187. flatload floor retrofit kit!
  188. Low fuel?! Ignore the speed limit and find gas! (fuel reserve icon issue)
  189. Clock Reset
  190. Manual Transmission RPM "Nanny"
  191. Noise after shutting off engine
  192. 2004 Auto window up
  193. The Dreaded Fuel Question
  194. Passenger Seat belt sensor?
  195. vanity mirror cover
  196. HELP. My countryman S all 4 sport is too stiff how can i undo the sport suspension
  197. rock, windshield = $430
  198. Faint hiss?
  199. Side marker question
  200. Countryman All4 overheating!! Help!
  201. Leaking breather hose & how to remove?
  202. "Twang" or rattle when braking?
  203. Rear seat belts?
  204. Mini Connected Question!
  205. Cooper Countryman All4 S issues anyone?
  206. Phone holder on the rail exploded!
  207. Reprogramming done. I noticed a change..
  208. Key fob stuck in ignition - car dead as a door nail - HELP!
  209. Engine wants to stall during hard braking
  210. Accessory Rail phone holder
  211. Critters living in my Countryman
  212. Water Dripping Into Countryman
  213. Thermostat Sensor (root cause of no/hard start, fan running excessively, overheating)
  214. Cooling Fan Running On
  215. Hope this helps others with hissing aux sound
  216. Rear Washer Dribble
  217. How/Why does high pressure fuel fail ?
  218. Brake lost contact on bumps!
  219. Personalizing features on the CMS All4
  220. Comfort access heads-up.
  221. Dead Battery
  222. 2011 CM S issues..
  223. Washer fluid Leak
  224. Noise under hood after car is turned off.
  225. Alignment issue
  226. Cold day, No start
  227. Sirius Lockup
  228. Thermostat replaced for the 2nd time
  229. Interior light question
  230. iOS notifications in Connected..what am I doing wrong?
  231. Power Steering Malfunction 2007 S
  232. Loosing favorite stations
  233. iPhone Y cable replacement
  234. Trip Odometer Disappeared
  235. Less than 1 month and door handle broken.
  236. Gas door not flush with body
  237. rear door won't open from inside
  238. Red coolant temp light
  239. About rear wiper in Reverse?
  240. Clutch problem? (video)
  241. Sunroof just exploded while driving!
  242. iOS 5 problem
  243. 2012 countryman connected pandora issue.
  244. Pandora W/ mini Connected
  245. Connected: missing contacts and voice dial fails
  246. I hate the ride with pirellit centurato runflats!
  247. Clicking noise when shifting
  248. Engine light- fuel rail sensor/injectors
  249. Heating/Cooling Vent Problem
  250. countryman antenna
