Engine warning light -- Error code P0087. What does it mean?
Old May 9, 2012 | 08:31 PM
sirbikes's Avatar
sirbikes
The other day the yellow engine warning light came on. My friend has a ODBC code reader and hooked it up. It gave code P0087 Fuel rail / System Pressure - Too Low. What does this mean? Is it related to the dreaded thermostat issue? My dealer is 2+ hrs away so I can't get there unless I do some planning first. Should I just keep driving it? It seems to drive just fine.
Old May 9, 2012 | 10:44 PM
Mojito's Avatar
Mojito
not sure by the code, but there are these 2 TSB's related to the fuel system
Make : MINI Model : COOPER S COUNTRYMAN Year : 2011
Manufacturer : BMW OF NORTH AMERICA, LLC
Service Bulletin Number : SIM-16-01-09 Date of Bulletin : FEB 01, 2012
NHTSA Item Number : 10043722
Component : FUEL SYSTEM, OTHER:DELIVERY:FUEL PUMP
Summary :
MINI: INFORMATION PROVIDED REGARDING PROCEDURE OF REPLACING FUEL LEVEL SENSOR DUE TO FAILURE ON THE RIGHT AND/OR LEFT SIDE. *PE
Service Bulletin Number : SIM-12-03-11 Date of Bulletin : JAN 01, 2012
NHTSA Item Number : 10043873
Component : FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
Summary :
MINI: SERVICE ENGINE SOON IS ILLUMINATED DUE TO TANK VENTILATION VALVE (TEV) BEING JAMMED OPEN AND FUEL CAP, WITH EVAPORATIVE SYSTEM LEAKAGE, WAS INCORRECTLY INSTALLED. *PE
Mojito's Avatar
Mojito
make sure the gas cap is tight
Old May 10, 2012 | 08:27 PM
pyrrhusmj's Avatar
pyrrhusmj
+1 very common code.
Old May 11, 2012 | 03:58 AM
sirbikes's Avatar
sirbikes
I retightened the gas cap and the light went away for now....thanks. It wasn't a good day for my CM and me - the same day the engine light came on a rock flew out of a dump truck ahead and cracked my windshield.
Old May 11, 2012 | 11:42 AM
padre40's Avatar
padre40
After 1 week w/ the car, wifey saw engine warning light on this past Wed. after gassing up car. Our salesman told her to tighten the gas cap, but warning light still on. Brought it in yesterday and was told faulty fuel pump - factory defect. Fixed in an hour.
Old May 16, 2012 | 07:35 PM
sirbikes's Avatar
sirbikes
My light keeps coming on and off. Today it did not come on, but yesterday it was on (with reduced engine power). I have not taken it in yet because of the two hr drive. It's probably a faulty fuel pump like yours.
Ironically, I am now getting better gas mileage: 29mpg on my most recent fill-up. I've never gotten 29 before. 28 a few times, but my overall average is 26.7.
Old May 16, 2012 | 07:56 PM
1bigpea's Avatar
1bigpea
Make the plans and take it in. What you're experiencing won't fix itself.
Old May 21, 2012 | 07:45 PM
sirbikes's Avatar
sirbikes
Update ... I took it in, turned out to be a faulty high pressure fuel pump ... replaced.
BTW, they said they don't use the P codes, they use other ones specific to Mini.
Old Apr 23, 2013 | 09:46 AM
CanuckRunner's Avatar
CanuckRunner
I just experienced the same thing recently. I just bought a used 2011 Mini Cooper S, I've had it for about 4 weeks now, and love it!
Last week, I ran it super-low on fuel - I was on the last little red light, then the yellow check engine light came on, along with the loss of turbo. Went to the station to fill up, light went away.
Since then, the light has been going on/off randomly, but typically after about 1 hour or driving. I'm 3 hours from the nearest Mini dealership, so I took it to my local mechanic to check the code: P0087: Fuel rail / System Pressure - Too Low. He reset the light today, and all is good (for now).
Should I still schedule an appointment with Mini, or just wait to see if it happens again? Kinda bummed that I'm already having issues with the car, after just a few weeks of owning it. Could it simply be related to the fact that I was so low on fuel that day, which would've triggered a pressure issue?
If it *does* need fixing, is that covered under warranty?
Thank you!!
Old Oct 21, 2013 | 07:18 AM
FirefighterJw's Avatar
FirefighterJw
Mine came on 3 days ago. The low pressure fuel rail. Had a 90 day warranty on it and was goin to call today. 2 hr drive to my dealer. Found out I exceeded the mileage for the 90 day. But after reading this I will call. You guys are awesome ! I'll keep you all updated on my status.
Old Oct 21, 2013 | 07:21 AM
FirefighterJw
Thank you!!
I was at a full tank of gas on mine , when my light came on. Doesn't hurt to have them check it. Just my thought
Old Oct 21, 2013 | 07:22 AM
CanuckRunner
I forgot to post my own update to this: I did end up taking mine into the dealership since the light did come on/off a few more times (along with the loss in Turbo). Turns out it was also a defective high pressure fuel pump, which they replaced, and it was covered under my warranty. So it cost me nothing.
That was done back in June, and I haven't had a single problem since! :-)
Old Oct 21, 2013 | 07:39 PM
FirefighterJw
Summary :
Summary :
Where did you find these ?
Old Oct 25, 2013 | 08:31 AM
FirefighterJw
So, took my car in. For a few issues. It ended up obv being the high fuel pump. My car has 70k on it. Dealer said no recall on them and i don't have a warranty . BUT the one opener before me replaced it a year and half ago. 2year warranty on replaced items. So that covers my pump. The fixed some seals in the transmission when I bought it. Well it was still leaking. Again covered under 2 year replaced parts. I'm a happy person ! I got lucky. Hope everyone else does too.
Old Aug 27, 2014 | 07:13 PM
MiniCrisis's Avatar
MiniCrisis
p0087
I had my PCV changed out at the dealer because I had a little fender bender and it was pulling vacuum on the entire block because I couldn't pull the fill cap off while running. its been about 3 months I started getting a little engine light on the tach. Took to advance and they told me that it was a Low fuel rail pressure but it was intermitting. I was thinking fuel pump, filter sensor big bucks, so while I was searching for the gage connection to get and actual pressure I stumbled across a loose ground wire that is located at the rear of the valve cover #8 nut . I tighten it and so far no light no power lost
Old Aug 31, 2015 | 12:18 PM
gmcnaugh's Avatar
gmcnaugh
Hi, hopefully you are still watching this post. Could you give a bit more detail on the ground wire you found loose please. I am having loss of power above 4K RPM and think from reading another post it might be the HPFP but am keen to check this wire before I go down that route.
Thanks.
Old Oct 10, 2015 | 08:02 PM
Suji's Avatar
Suji
I just got this code on my car today I stopped at Autozone when the engine light came on I have a 2012 Coupe does anybody know if this is the high pressure fuel pump issue that MINI extended the warranty for 10 years or 120K miles?
Also I am planing to take a road trip should I get this fix now or can I wait until I come back from my trip?
Old Jan 16, 2020 | 09:10 PM
C Vergara's Avatar
C Vergara
Have you figured out what the problem was?
Old Jan 17, 2020 | 06:26 PM
eric.stewart's Avatar
eric.stewart
Veteran: Canadian Forces
You replied to a very old thread (and I guess I did to!) :-)
I'm going to guess that this is the HPFP (High Pressure Fuel Pump) issue that resulted in a recall for a certain run of 2010-2011 R60 Countryman. Are you seeing that same code? Only definitive way of determining what it's for is to get the dealer or a knowledgeable independent who understands MINI/BMW codes to run a diagnosis. Recommend that you also read up on and search this forum's threads for "HPFP recall". There are a lot of posts on the subject.
Old Apr 2, 2021 | 11:22 AM
Ernesc's Avatar
Ernesc
Cool P0087 Resolution
I purchased a used 2011 Countryman with 100K miles from a car dealer. I live in Florida, US. The yellow check engine light started coming up on and off intermittently and it would lose power. Took it to mechanic who detected the P0087 code. It got fixed after I used a product sold at AutoZone called "Sea Foam" Motor Treatment. I added to fuel tank and after a couple of fill ups the problem went away (Read instructions well). I guess it cleared up the obstruction/dirt in the fuel filter. You might want to try this before taking car to mechanic/dealer. Cheers
shrevemini
Nov 20, 2019 03:42 PM
ophale
Apr 5, 2017 05:19 AM
Wanderlustsrt
Jan 16, 2017 12:03 PM
Enduser
Mar 1, 2012 02:43 PM
peekinde
Sep 26, 2007 08:46 AM
