2011 MINI Countryman S Service Bulletins/recalls
2011 MINI Countryman S Service Bulletins and Recalls
I have had my countryman for over a year and have already had 3 issues related in these bulletins.
Make : MINI Model : COOPER S COUNTRYMAN Year : 2011
Manufacturer : BMW OF NORTH AMERICA, LLC
Service Bulletin Number : SIM-16-01-09 Date of Bulletin : FEB 01, 2012
NHTSA Item Number : 10043722
Component : FUEL SYSTEM, OTHER:DELIVERY:FUEL PUMP
Summary :
MINI: INFORMATION PROVIDED REGARDING PROCEDURE OF REPLACING FUEL LEVEL SENSOR DUE TO FAILURE ON THE RIGHT AND/OR LEFT SIDE. *PE
Service Bulletin Number : SIM-12-03-11 Date of Bulletin : JAN 01, 2012
NHTSA Item Number : 10043873
Component : FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
Summary :
MINI: SERVICE ENGINE SOON IS ILLUMINATED DUE TO TANK VENTILATION VALVE (TEV) BEING JAMMED OPEN AND FUEL CAP, WITH EVAPORATIVE SYSTEM LEAKAGE, WAS INCORRECTLY INSTALLED. *PE
Service Bulletin Number : SI-M61-01-12 Date of Bulletin : JAN 01, 2012
NHTSA Item Number : 10043725
Component : UNKNOWN OR OTHER
Summary :
MINI: AFTER DRIVE-AWAY LOCKING ACTIVATES, IT IS NOT POSSIBLE TO UNLOCK THE BOOT. *KB
Service Bulletin Number: SIM-12-02-11
NHTSA Item Number: 10040855
Summary:
BMW: A SOFTWARE ERROR IS CAUSING A HESITATION OR JERKING WHEN ACCELERATING UNDER HIGHER LOADS BETWEEN 3000 ¿ 4000 RPM. *RM
Make: MINI Model: COOPER S COUNTRYMAN
Model Year: 2011
Manufacturer: BMW OF NORTH AMERICA, LLC Mfr's Report Date: JAN 10, 2012
NHTSA CAMPAIGN ID Number: 12V008000 NHTSA Action Number: PE11036
Component: ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:TURBO-CHARGER
Summary:
BMW IS RECALLING CERTAIN MODEL YEAR 2007-2011 MINI COOPER S, 2008-2011 MINI COOPER S CLUBMAN, 2009-2011 MINI COOPER S CONVERTIBLE, 2009-2011 MINI COOPER JCW, 2009-2011 MINI COOPER JCW CLUBMAN, 2009-2011 COOPER JCW CONVERTIBLE, AND 2011 COOPER S COUNTRYMAN PASSENGER CARS MANUFACTURED FROM NOVEMBER 14, 2006, THROUGH JANUARY 18, 2011. THE ELECTRIC AUXILIARY WATER PUMP THAT COOLS THE TURBOCHARGER HAS AN ELECTRONIC CIRCUIT BOARD THAT CAN MALFUNCTION AND OVERHEAT.
Consequence:
THE CIRCUIT BOARD MAY SMOLDER WHICH COULD RESULT IN A VEHICLE FIRE.
Remedy:
BMW WILL NOTIFY OWNERS, AND DEALERS WILL REPLACE THE WATER PUMP FREE OF CHARGE. THE SAFETY RECALL BEGANDURING FEBRUARY 2012. OWNERS MAY CONTACT BMW AT 1-866-275-6464.
Notes:
OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Summary :
Summary :
Summary :
Summary:
Model Year: 2011
Summary:
Consequence:
Remedy:
Notes:
Some of these bulletins are for both models. But the Recall is for the S (turbo) only. I am not sure about the software error one. I would have to research that one a little more.
When are they going to recall every CM built to date to fix the defective thermostats? If ever there was an issue that justified a recall, this is it. Random failures that disable the vehicle at any time. No 'limp home mode'.
If your CM hasn't failed yet, it will soon...
And when it does, there will be no warning, and your car will lose power, and refuse to start. You will then get to listen to twenty minutes of fans running trying to cool an engine that doesn't need cooling.
Mark
Mark
Talked to Mini Customer service and they informed me the recall vin count stops on the 18th of January 2011 and starts back up on the 28th of March 2011?
Well if that doesn't leave me with a warm fuzzy feeling about our car maybe the possible fire that could happen due to ours being built during the recall freeze envelope will!
The recall is for the auxilary water pump which has faulty or underrated wiring to hold the amperage load and can cause a fire!
This seems pretty haphazard and is an obvious disregard for the safety of my family in my opinion.
MINI if you're reading this you may want to step up and take care of your paying customers.
minicoclub
Nov 11, 2015 07:25 AM
dyeLucky
Aug 7, 2015 07:10 AM
