- 2014 MINI Countryman R60 AC compressor not engaging - only takes 100-150g
- leaking brake booster tube
- Can't Get It to Start.. '12 Countryman S ALL4
- Cold start issue on Mini Cooper Countryman R60 1.6 S (2015, 90k km)
- 2013 R60 CMS Transfer Case Recommendation?
- Can I cut the dash to access the CAS? Is it just under the dash cover?
- Fluctuating Idle RPMS after Cold Start
- Wheel well liner retainers.
- Rear Main Seal Leak?
- Question on Charging System
- Sunroof shade
- Engine Codes after 3 wk vacay. 2EFE, 2EE0, 2F01
- P053a countryman s
- Traction issues
- Mini Cooper Countryman R60 2015 Comfort Access not working correctly
- 2016 countryman rear hatch ground strap /ribbon
- 2016 R60 N18 Engine Oil 0W-30 A5/B5
- Sunroof left open, water in car, no display on radio, air bag light on :(
- Mini R60 AC issue
- R61 Oil cooler re-seal
- Goes into limp mode but not in sport mode
- R60 Passenger Side Oil Leak
- 2C56 code after replacing turbo
- R60 radiator fan low speed
- Service Bulletin List for R60
- 2016 mini countryman s no crank no start
- Deka Battery Registration
- Big Spark when Removing the Water Pipe
- No Audio
- Is the oem vacuum pump the only one available right now?
- 2012 R60 All4S Manual, how do I get the passenger axle out?
- Doors won't unlock
- Footwell Module failed to communicate?
- Wheel Bearing Manufacturer Recommendation
- Two engine lights?
- Wheel Bearing Maybe?
- Possible JBE issue?
- 2012 Countryman R60 -- issues
- Running Poorly After DME Cloning
- Oil Control Solenoid Repair
- R60 shaking problems
- R60 limp mode head gasket?
- 2016 R60 (N18) Relay Box layout
- FRM3 Issues
- flat towing
- Need some help, guys.
- Help! Broken Grounding Strap Bolt
- R60 2c01 issues and front wipers don't work
- 2012 R60 Countryman S ALL4 6spd - oil on bottom of transmission
- R60 SAll4 MT pulling out of 6th gear.
- 2012 Countyman automatic oil cooler replacement
- What happened to this turbo?
- R60 Countryman S All4 Won't Start After Replacing Thermostat Housing
- R60 Code 2C03 high pressure fuel plausibility too low
- 2011 R60 S - Multiple Diagnostic Trouble Codes After Buzzing Fuse Box
- R60 2014 Spark Issue
- R60 Base MT Replacement Advice Needed
- R60 Tail light issue
- Auto trans issue
- Replace VVT Solenoids? Where are they???
- R60 AC compressor pulley size
- 2C57, 2C58, and 2C91
- Issue with R60
- Countryman SD pulley wobble and tapping noise , help needed please!
- Body Module Replacement
- Bad battery or alternator?
- Engine malfunction reduced power
- Proximity sensors on rear bumper aftermarket
- Part identification and sourcing
- N16 - Slight knocking?
- Help-Maybe Bad New Fuel Pump
- Headlights always on
- Chirp on start up
- Mystery oil leak
- Tpms failure
- 2014 R60 s ALL4 front CV axle with or without bracket?
- Codes 2C57 and 2C91
- Wires In Passenger Fuse Box
- Radio or center display F45 Fuse blown plus no display or radio
- Driver's wing/side mirror don't move as they should
- Replacement connectors/pins for jbe module
- FMR Good - WTF?
- Need Help - Revving Noise at Idle - No codes or lights
- Not sure where this plug goes?
- The Curious Case of the Melting Ignition Coils
- R60 Not turning over - Fuel pump?
- Lost AWD
- Climate control issues..
- Sunroof problems
- R60
- 2012 Countryman S New Cloned DME issue
- Battery or alternator?
- Mini r60 coding issues
- 2012 Mini Cooper Countryman S ALL4 - NO idea about these issues - HELP please...!!!
- Low boost
- Now its Overheating and Boiling Out Expansion Tank
- Camshaft position sensor code bank 1
- Rear Sunroof stuck on one side
- 2013 Countryman S "Limp Mode" Experience
- R60 2C57 After Turbo Change
- Radio will not turn on without pulling the fuse
- R60 replaced Speg , now have 2 error codes A87E C91
- Front break wear sensor cable harness broke
- '12' CM-S R60 N18 Engine Electrical Harness
- 2012 CM R60 N18 Stutter oddity
- City light not working - no power at socket
- Transmission and/or Possible Axle Issue?
- 2016 R60 Reverse Lights don't work
- Error code PO100 & 102 question
- 2C57, 33FD, 3405, 3401, 2C91 Where do I start?
- 2014 R60 Rear Tire Inner Wear
- R60: Navi GPS Issue
- P0015 after replacing timing chain and more
- Front end service mode
- 2015 Countryman S - Manual Transmission has 4th - 3rd grind of gears
- Sunroof problem
- Photo: Thermostat: Does someone know where this wire goes? please post photo
- Photo: can someone take a photo of this in their engine and send me?
- Need photos of engine wiring please r60 All4 S turbo
- My aircon isn't cold (R60 Countryman)
- 2015 R60 2C3F code
- Problem changing front wheel bearings
- Flywheel lock hole on automatic transmission
- replace timing chain tensioner on R60 184
- Car run rough
- 2013 CMS All4 Periodically Struggling Uphill
- SWC harness identification
- R60 Carpet removal
- Please help me help my Countryman
- What else should I replace?
- N18 Wastegate Flapper same as N14?
- 2016 R60 issues
- Vacuum pump interchange
- Is this stock? What is this plug all about?!
- Battery drain
- Old gas
- Paceman Snapped Hood Release Cable!
- MINI R60 torque wrench settings
- Hood Release Latch clicking at hood but not opening
- Odd noise when backing
- R60 rack and pinion mounting bolt
- 2012 R60 Oil Hemorrhage
- Radio Issues
- windshield washer activation is switched with rear glass washer
- Clutch "Clunk" Noise: Please help me identify this bar?!?
- 2011 Countryman S Fuel Tank Vent Valve Location
- Messed up my differential 13’ countryman
- Reverse Light Switch location
- SUN ROOOOOOF! won't close 2013 R60
- R60 error codes alternator is missing
- What to look for- used 2011Countryman S ALL4
- 2012 Mini countryman S All 4 Half Check engine light
- Door lock actuator replacement
- R60 Oil leaks on valve cover
- No brake/tail lights
- Advice: Clean your MAF sensor
- Wastegate rattle :(
- 2011 R60 Countryman S A/C Problem. PLEASE HELP
- 2013 Countryman S Manual Wont Shift
- I got a few engine codes related to K CAN BUS '15 R60 S ALL4
- Horrible Banging Noise
- 2012 Countryman S All4
- R60 Brake hose / Caliper
- Stripped timing chain guide bolt hole
- name that sound! spun bearing/rod knock? clutch issue?
- Battery/Alternator Issue
- CEL, P2421 EVAP valve stuck open.
- Solenoid valve
- Set timing
- How to drop the oil pan (...or how can a relatively simple job can be so difficult?)
- F60? Armrest
- 2015 R60 stock radio, barely low end frequencies
- EVAP Codes and Rear Gas Vapor Smell R60
- 2011 R60s Issues with new thermostat
- Hazy interior rear view mirror
- Oil leak from topside air intake duct? Is that possible?
- Reoccurring Check Engine Light
- Help: RDC Module Location
- Driver window switches not working
- New issue regarding Mini cooper Limp mode.
- Front End Noise????????
- Half Yellow Check engine light
- Water pump ....grrrrr
- Help: Low oil pressure
- Missing hose to intake
- 2012 Countryman S Limp Mode
- Rattling sound from rear end. Cooling fan.
- Acceleration Sputter with video
- Troubles after Battery Change
- Oil leaking
- P0015 after timing chain replacement on 11 R60
- Passenger Occupancy Sensor - Airbag
- low tire pressure warning/4WD!
- Car won’t start...Key fob or electrical snafu
- Fluid leak between transmission and transfer case (MT)
- Misfires, limp mode, fault code help
- No Brake Warning Light
- R60 Fuel smell inside cabin coming from engine compartment
- Scuttle light snafu
- Red oil light on and Amber Check engine after oil change
- 2012 R60 Misfire (I know, another thread)
- Flappy paddles work, but pushing transmission into Manual mode doesnt work?
- Sounds like a high pitched squeaking passenger side
- 2013 Countryman JCW, crank but no start
- N18 Timing chain - do it myself?
- Blown Fuses?
- 2012 MINI Countryman R60 Justa - Hard Shifting Manual Transmission when Warm
- Problems with the new turbo
- Where is the starter motor in my 2012 R60 All4
- Sudden power loss
- P1338, P1339, Limp mode. Help please!
- Questions: Won't Start & Hood Release Broke
- 2012 MINI Countryman R60 N16 Engine Intake Valve Operation
- R60 Smoke on acceleration
- I think my R61 S, fuel pump just gave out.
- 2011 Mini Cooper countryman R60 Engine Malfunction and leaking
- Interesting limp mode experience
- Pop noise when brake depressed
- PVC vent hose leak
- R60 ALL4 S steering wont self center
- Parts and service repair software
- My horn is stuck
- Rattling Noises (Not Death Rattle)
- how change the hood cable ? countryman S 184
- Ever wonder what the inside of the t-case looks like?
- 2011 R60 S / AT no start wheel lock P0974 (shift sol A)
- Does anyone have a diagram for the AC air duct system?
- Help, I can’t find the gremlins
- HELP! dead animal in air duct system
- Red Oil Light in low RPM
- Borrowing tools?
- Power loss randomly
- r60 S all4 drivetrain binding
- R60 Front Axle Nut Torque - Wheel Bearing Replacement
- JCW shock replacement
- R60 - 3 door locks stopped working
- 2013 r60 rear shock/spring broke
- Airbag Light and Issues?
- Trip a check engine while acceleration..
- Does this sound like a dead battery?
- power on, no start checklist
- Issues while in sport mode
- 2012 R60 - Standard Build, not S - Oil Leak - Unsure of Source
- P173b code w/o CEL after thermostat housing upgrade
- What part is this and other questions from newbie
- Used wrong coolant how do I flush?
- 2014 countryman s all 4 boiling over
- How much to fix this?
- Loud Engine?
- Rear Suspension Creeking/groaning noise going over bumps
