Replacement connectors/pins for jbe module
Hello all, I think I asked this question in the wrong place the first time. I'm replacing my fuse box assembly (jbe) located behind the right side kick panel due to rain water intrusion from a leaking/clogged sunroof drain. I have 2 connectors that have 4-5 damaged pins each. I need the pins or part number so I can order them as I really do not want to disassemble my entire car to replace the entire harness. I can get pictures of the good pins if it would help. I've already been to several junk yards and what I found there was either in worse shape than what I had or already cut out. Thanks in advance for any assistance.
Same situation here. Did u find a solution?
Female pins are here: # 3 - #14 and the sizes needed. The electrical warning points to which harness plug into.
https://www.realoem.com/bmw/enUS/sho...05#61359813620
Pin Removal out of the comb: https://www.ecstuning.com/b-schwaben...ieces/ce-70-2/
JBE removal and install.
https://www.northamericanmotoring.co...-on-r56-2.html
E34M5
R58 :: Coupé Talk (2012+)
Mar 19, 2020 06:02 AM
