How To How To: Replace Fuse Box SPEG on R56
Old Sep 18, 2020 | 01:53 PM
  #26
alertjean's Avatar
alertjean
Hi @3d914
Thanks for excellent post on your FBE debug.
I am having same issue for my 2011 Mini Cooper R56. Where is the fan relay located? Which is blown fuse you are referring to?
Jean
Old Sep 23, 2020 | 04:51 PM
  #27
Russell Gadbury's Avatar
Russell Gadbury
Did you sell your FBE?
Originally Posted by 3d914
Decided to update this posting. After buying a replacement FBE the dealer informs me the ECU has to be reprogrammed before the new unit can be used - since it has some changes. So I can't just install it myself. OK, so I let the dealer do it. Unfortunately it didn't resolve the A/C issue - so I'm back to square one.
That and some of the programming didn't appear to take. My wife notices the remote keys don't work, there's no driver-select shifting option, and the remote engine start (without the key fob in the receiver) doesn't work either.
Take it back and it turned out all of those issues were due to a blown fuse. They also resolved the A/C issue by replacing the fan relay - go figure! So at least everythings working again. The original FBE part will go up on Ebay soon.
Did you sell your FBE, the garage thinks mine is suspect _ car keeps cutting out and will not restart then runs fine for weeks, large relay getting hot. I am in Canada would you post it if you still have it? I will of course cover any shipping costs.
Old Oct 18, 2020 | 04:37 PM
  #28
Russell Gadbury
Great guide on how to remove the SPEG fusebox! 😊
It made removing and inspecting my unit straightforward, thanks for posting the info 😊👍
Old Mar 19, 2021 | 12:00 AM
  #29
Yoshimura 1's Avatar
Yoshimura 1
I definitely need to replace one of these in one of my vehicles mine had some water in it.
Old Feb 21, 2023 | 12:19 PM
  #30
The photos are not showing up and i can see them in google with a search, wayback machine looks to have no data.
Any luck reposting?
Old May 8, 2023 | 02:41 PM
  #31
komet155's Avatar
komet155
Does anyone have pictures showing removal? All the relevant pictures seem to have disappeared.
Old May 8, 2023 | 02:51 PM
  #32
komet155's Avatar
komet155
I appear to have an intermittently faulty FP relay.
A new replacement JBE is on national backorder as per my local stealership.
Has anyone tried one of the repair services which test and replace any failed components such as the fuel pump relay which is soldered to the board?
I was looking at this one:
2007-2014 Mini Cooper fuse box fuel pump relay replacement | Lifetime Warranty – Automotive Circuit Solutions
Old May 8, 2023 | 02:54 PM
  #33
Lex2008's Avatar
Lex2008
can you just unsolder and resolder a new relay? Its not rocket science.
Old May 8, 2023 | 03:29 PM
  #34
komet155's Avatar
komet155
Thanks for your helpful input, but no.
Old May 8, 2023 | 03:33 PM
  #35
Lex2008's Avatar
Lex2008
you may have no choice. Buy another relay and bring it to an electronics shop and ask them to put it on.
Old May 8, 2023 | 04:38 PM
  #36
komet155's Avatar
komet155
Thanks for your helpful advice. Does anyone else actually have experience with using an repair service like the one above?
Old Jun 23, 2023 | 07:04 AM
  #37
War_Drobe's Avatar
War_Drobe
No, I don't have experience using the service but I do think I can handle the electronics repair. It probably isn't too complex.
I'm having the same problem you are -- my fuse panel is not supplying power to the low pressure fuel pump. Panel likely busted. The fact that the service exists, and you also have the problem, suggests this is a "common" problem area.
I'll take out the fuse panel, examine the PCB, and report back on my results. It might just be a blown trace, it might be there's a relay that ... powers the LPFP fuse? or some other electroncis surrounding the LPFP. But probably not too complex like I said, and I anticipate just a matter of replacing the broken trace or part with an equivalent (or superior) part, plugging it back in and driving off. Wish me luck!
Old Jun 23, 2023 | 07:24 AM
  #38
Lex2008's Avatar
Lex2008
LUCK!
Post pics.
Old Jun 23, 2023 | 08:41 AM
  #39
War_Drobe's Avatar
War_Drobe
LUCK!
Post pics.
Thanks.
It looks like this walkthrough is what I would need to do. My car is at the mechanic and I would like to drive it home before taking out the fuse panel and fixing it. So my plan is to power the low pressure fuel pump directly with 12 v to get fuel pressure, then drive the car home and do this process.
It's a bit sketchy messing with electrical right next to the fuel. I will update here how I do it or if I decide there's a less risky way to go about this. In any case, looks like that video describes how to fix the panel.
update:
This post describes the connector pinout/wiring to power the low pressure fuel pump directly. It's all sealed up so not so sketchy to power the pump. My back seats are already out so I won't have much trouble reaching this. Hopefully I can just connect a second 12v battery here direct, drive home, then fix my JBE!
https://www.northamericanmotoring.co...gnose-diy.html
Old Jul 7, 2023 | 12:47 PM
  #40
Just posted up some more update here on the OEM parts:
https://www.northamericanmotoring.co...-fuse-box.html
Old Feb 21, 2024 | 09:19 AM
  #41
Update: Looks like this is back in stock as well as others: 61353457582
https://www.ecstuning.com/Search/Sit...Box_SPEG_High/
Old Feb 11, 2025 | 08:34 AM
  #42
mhabibian1's Avatar
mhabibian1
can't see the images, is there any way to restore them?
GT350
Jun 18, 2023 04:42 PM
CPWillys
F54 :: Clubman Talk (2015+)
Dec 17, 2021 06:17 AM
DarkMiniCooperS
158
Nov 25, 2019 07:27 PM
dogcowdaddy
Oct 25, 2014 05:48 AM
e_rkk
Jan 18, 2008 10:00 PM
