I was able to install the craven short shifter over the weekend, I took some photos of the process to share. This took me 3 hours to do, I do not have photos of every step but this is an outline for those who are interested in DIY.
From: Manassas, VA where the Civil War resides.....
Nice job! As one of the first F54 owners to install the cravenspeed shifter, I applaud you! I did the install without removing the seats. After we finished, we concluded that removing the seats would have made it a little bit easier. Enjoy! It made a tremendous amount of difference in the shifting action, both in travel and precision.
Thanks for this instructional guide! I've been slowly taking apart the console to replace the shifter as well and am getting down to dismantling the final bits around the shifter assembly. For anyone that's done this themselves, does the entire shifter need to be removed from the vehicle? Or can it be done like the instructional guide from Cravenspeed on the F56. See the attached image for comparisons:
To follow up on my question, yes you do have to dismantle everything around the shifter. I tried everything I could without taking out the console frame. The Cravenspeed instructions to "tap" the ball joint didn't work for me and I tried a bunch of different suggestions but I did not feel safe putting significant pressure on the shifter linkage and risk bending it. I've attached a info graphic to help with anyone attempting to try this themselves, it was hilarious how easily it came out.
Once you get the rear air duct out from around the shifter, you can access the rod from the passenger side. Drop a crescent wrench in around the joint and leverage it up against the wider section of the shaft, then push the shifter to the right and it will pop out with very little effort.
Nice job! My mini mechanic did it for me. Took them 5 hrs and they had to cut and replace some carpet to do it.
What was the carpet replacement for? I checked and at the lowest setting for the short shifter, the linkage/shifter cables actually rub the carpet! Was it because they noticed this? Good thing I looked after seeing your post.
I raised the shifter about a 1/2 cm and it's not touching the carpet anymore.
I think that was probably the case. Glad my post helped.
