Rear Suspension Creeking/groaning noise going over bumps
Ok, So I'm 9 months into my Mini countryman ownership and this month's problem is: (drum roll please)
I'm not getting a creeking/groaning noise when I go over bumps coming from the rear end.
I had just replaced the rear sway bar bushing due to a nice clunking noise from the rear, the clunk is gone, but now there's this groan/ creeking noise. (that's the only way to describe it. like an old bed or couch)
the struts seem to bounce just fine when rocking the car..
Going to take it all apart next week to put new bearings in, what should I be looking for?
Inside? outside? both?
I was going to replace the links while I was swapping out the bearing hubs while I had everything apart for good measure. (already ordered ones with zerk fittings)
These were the ones I got - Not the super stiff poly ones. 16mm ones.
Going to try this hopefully tomorrow or Monday if not when it actually gets into the 50s
thanks!
My rear sway bar bushings were getting a bit creaky over bumps and lubricating them did the trick.
