Please help me help my Countryman
2012 Mini Countryman All4 S.
Running rough, service lights on, errors reported.
You know when you try and try to do something and after a lot of effort you havn't done the thing and you start to feel insane and need to break the cycle? Yeah that's what is happening. I need to consult a higher power, someone who can guide me. Please help me.
Here are the generic fault codes pulled via Torque
Edit-
new spark plugs and two coil packs and it is back up and running
P0300 - Powertrain
Random/Multiple Cylinder Misfire Detected
CURRENT FAULT
P0301 - Powertrain
Cylinder 1 Misfire Detected
CURRENT FAULT
P0302 Powertrain
Cylinder 2 Misfire Detected
CURRENT FAULT
Via Bimmerlink I have pulled an error report. Please advise me, I am just about to loose my sanity here.
Error Memory
Date: 3/12/22 10:48:45 AM
VIN: REDACTED
00 Safety and information module (SIM)
1 error
A86D:
HECKSCHEIBENHEIZUNG_RELAIS_DEFEKT_ODER_LEITUNG_ZUR _HECKSCHEIBE_UNTERBR
OCHEN
01 Safety and information module
1 error
93D0: Supply voltage - undervoltage
02 Switch center, steering column
1 error
9E31: undervoltage
12 Motor electronics
10 errors
2EFE: 0x2EFE combustion misfire, multiple cylinders: detected
2F00: 0x2F00 combustion misfire, cylinder 2: detected
2EE2: 0x2EE2 Misfiring, multiple cylinders: harmful after start-up
2EE9: 0x2EE9 combustion misfire, cylinder 2: exhaust gas harmful after starting process
2EE1: 0x2EE1 combustion misfire, several cylinders: harmful to the exhaust gas
2C57: 0x2C57 boost pressure control, plausibility: pressure too low
2C91: 0x2C91 Diverter valve, mechanics: suspected open recirculating diverter valve
2EE8: 0x2EE8 combustion misfire, cylinder 2: harmful to the exhaust gas
2EFF: 0x2EFF combustion misfire, cylinder 1: detected
Edit-
P0300 - Powertrain
CURRENT FAULT
P0301 - Powertrain
CURRENT FAULT
P0302 Powertrain
CURRENT FAULT
Error Memory
VIN: REDACTED
1 error
A86D:
OCHEN
1 error
1 error
9E31: undervoltage
10 errors
Hello there I understand that your post was from 3.5 years ago. You stated that new plugs and coils fixed the issue. Was that all you had to do? The codes I pulled from my 2011 R56 were mostly the same, but after new plugs and coils were installed... This was your one and only post. I am afraid that you don't own the Countryman any more, because if you do, for sure there'd be more problems... 😅
dddaaannn93
Dec 22, 2020 06:18 AM
FrankBlack
R55 :: Clubman Talk (2008+)
Nov 5, 2019 10:22 AM
Jesperss
May 2, 2013 06:58 AM
