R60 replaced Speg , now have 2 error codes A87E C91
Old Sep 3, 2022 | 02:36 PM
kentuckynet1's Avatar
kentuckynet1
hello i have a 2012 mini cooper s countryman, water had gotton into the lowest pins in one plug on the speg module/fuse panel.
Car would turn over but not start tons of error codes, got a good used speg replaced (exact number replacement), all error codes gone but two
A87E ultrasonic sensor wire fault
C913 No message lin
Car almost started but didnt,(meaning it fired) turns over windows doors locks radio everything works fine but just wont start
Any ideas would certainly be apprecated
water dint get any higher than stated , didnt get into anything but floor board on passenger side just to botton of lowest plug and the lowest pin, replaced pin that was corroded in plug, and fuse panel speg whatever you call it
thanks again
mack
Old Nov 28, 2023 | 03:04 PM
lun's Avatar
lun
i have the same issue on my countryman 2016.water gets in, and my fuse box all wet, i hv repair the fuse box, but still show 00c913 fault codes
the garage specialist has checked the oil pump, battery, all hv no issue. now still need to check and try one by one
but still no idea what happen...but should be ecu / wiring / fuse box
may i know what happen on my car?
how you finally fix your car?
mini845
Jan 13, 2026 01:51 PM
freddmc
Oct 6, 2021 01:24 PM
Klasse Act
Oct 3, 2014 05:57 PM
soopercuper
Apr 4, 2014 09:42 AM
cartar452
Electrical
Dec 1, 2008 05:37 PM
