R60 Carpet removal
Old Mar 22, 2022 | 10:18 AM
daleph's Avatar
daleph
R60 Carpet removal
Hello all,
Due to water ingress into the drivers footwell (RHS UK) I need to remove the carpets.
How?
I have removed all trim, seats, centre console , accelerator pedal.
The carpet is in one piece and goes under the heater box, the air con drain also seems to go out through the bottom
How do you remove the carpets without removing the heater block?
Many thanks
Dale
Old Jan 12, 2023 | 04:36 PM
clearness's Avatar
clearness
Also looking for instructions on r60 carpet removal. Been raining quite a bit in california and passenger side floormats are soaked.
Old Jan 13, 2023 | 11:33 AM
Hello,
You can find some stereo installs. But not one picture of a full take apart.
Full carpet.
https://www.realoem.com/bmw/enUS/sho...diagId=51_8240
All the break down of the trim and pieces are here: Trim center console... etc
https://www.realoem.com/bmw/enUS/par...r_S_ALL4&mg=51
Hope that helps.
If it gets wet put it in a warm garage with a fan blowing on the interior, should dry it out in a day or two. Also check the drain tubes on the sunroof, they can get clogged or separate from the tube
You can fix it with clamps
https://www.ecstuning.com/b-ecs-part...51738197504kt/
https://www.northamericanmotoring.co...rain-leak.html
VariableR58
Apr 25, 2016 02:02 PM
Sachmach
Oct 29, 2015 05:32 AM
Carlo Recio
Jun 28, 2015 12:41 PM
mellowmcs
Feb 5, 2012 02:52 PM
KatsMini
May 7, 2011 04:52 AM
