R60 Driver Side Outer CV Boot - Automatic
Old Nov 12, 2019 | 10:48 AM
2014 MC's Avatar
2014 MC
Hi everyone,
What is the best place to get a replacement 2014 R60 Outer Driver Side - Automatic CV replacement boot/kit from? Found some REALLY expensive stuff, but wondering if anyone has a good and reasonable source they are satisfied with?
Old Nov 15, 2019 | 09:58 AM
2014 MC's Avatar
2014 MC
No one replaces their CV boots on a 2014 R60? Mini dealer is the only option?
Old Nov 15, 2019 | 11:42 AM
Hello,
R60 NON S, All4?
Old Nov 15, 2019 | 12:47 PM
2014 MC's Avatar
2014 MC
Hello,
R60 NON S, All4?
Thank you, yes R60, NON S, NON All 4, BASE.
Old Nov 15, 2019 | 01:07 PM
here you go, for right now its just genuine. The interior and exterior kit. I dont see any aftermarket.
https://www.ecstuning.com/Mini-2014-...vetrain/Axles/
Grease is separate, its like 2 packs per axle. : https://www.realoem.com/bmw/enUS/sho...09#31609806467
Old Nov 15, 2019 | 01:26 PM
2014 MC's Avatar
2014 MC
Thank you. I had actually checked your site and found the boots (oem) and it just kills me that these are more pricey than I can get an entirely rebuilt axle for less than $100... Wonder where they get their boots from?
Old Nov 15, 2019 | 01:31 PM
Welcome, sorry thats all they have right now. For that cost possible Taiwan and they might be universal boots that you find the closest size to.
Old Nov 21, 2019 | 09:46 AM
2014 MC's Avatar
2014 MC
Update: So I ordered the MINI kit. Super expensive boots (ridiculous to me). I received the MINI kit in the mail (inner/outer). Turns out you have to do the inner to get to the outer...
My inner was just fine and the outer one had a slight tear at the big end of the clamp. I suspect it was like this from the factory. Workmanship issue. Anyway, the goop inside both joints was pretty runny. Hence, why even with a small cut near the big end of the clamp it sprayed lube juice all over the place and made a big mess yet could hardly find where it was even coming from!
Unfortunately, the MINI factory kit was missing the CV grease I realized when I went to button up the unit. That sucked so I had to run out and source the CV joint grease $1.99 x 2 to complete it... Two special clamp crimping tools as well.
I was originally planning to do the boot on the car because of horror stories out there about stuck shafts in the trans. With a friends help, I was able to leverage and get it popped out so I could do on the bench. No rust in there luckily to make popping the shaft out difficult/impossible.
t went back in fine and should be good to go now.
Old Nov 21, 2019 | 09:49 AM
Thanks for the update, yep i mentioned above the CV grease is separate, on most MINI kits they include it but for some reason on the R60/R61 platforms they dont. Glad you were able to get it fixed.
sch
14
Feb 15, 2025 08:49 AM
jbluesky
Aug 31, 2019 06:41 AM
loifs8
Jun 15, 2016 06:34 AM
VariableR58
Apr 25, 2016 02:02 PM
Carlo Recio
Jun 28, 2015 12:41 PM
