PDA
View Full Version : 1st Gen Countryman (R60) Talk (2010-2015)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. R60 r60 all4 manual clutch
  2. R60 New 2012 Mini Cooper Countryman R60 owner - some questions on fixing a few things
  3. R60 replacing turbo, how about cat?
  4. R60 Clutch question
  5. R60 Won’t Shift into 3rd or 4th
  6. R60 Countryman 2.0 SD (2013 plate) tapping, seems to coming from an auxillary pulley
  7. R60 2015 Countryman S All4
  8. R60 Key Replacements
  9. R60 R60 Differential Question
  10. R60 Rattling noise worse with acceleration
  11. R60 Diverter valve
  12. R60 2011 Countryman S Manual - No Crank
  13. R60 Looking for any aftermarket headlights with the Adaptive feature i
  14. R60 Any way to add CarPlay?
  15. R60 R60 vs Flooded road
  16. R60 DRL LED Retrofit kits?
  17. R60 Countryman S All4
  18. R60 Source for Used Parts?
  19. R60 Front of engine oil leak
  20. R60 Brake wear indicator - reset?
  21. R60 Mini Countryman 2012 R60 offside rear brake
  22. R60 Are these run flats?
  23. R60 Misfire That Isn't Plugs Or Coils With Good Compression
  24. R60 R60 Totaled - what to take?
  25. R60 R60 Navi OEM Screen
  26. R60 P1338 code, cam sensor or timing chain?
  27. R60 2013 R60 JCW: Sticking RR Brake
  28. R60 new to the minis, dumb question
  29. R60 93C3 pass. seat occupancy sensor mat
  30. R60 Low oil pressure after changing valve cover.
  31. R60 Both Key Fobs Won't Start R60 But Will lock/unlock
  32. R60 2010 Countryman cylinder head fit a 2013 Mini base?
  33. R60 Rear lower control arm ball joint?
  34. R60 Silicone Seal for Valve Cover Replacement
  35. R60 Does anyone have experience upgrading stock base speakers to Harmon Kardon?
  36. R60 2014 countryman s all 4
  37. R60 R60 Puking Engine Oil
  38. R60 Jbe module connector pins
  39. R60 Mini r60 won't pass 4000 rpm on neutral
  40. R60 Comfort Access starting to fail (very short range)
  41. R60 P325f
  42. R60 A little help diagnosing
  43. R60 Need some help
  44. R60 MINI Community comes together to help someone in need
  45. R60 R60 Side Mirror Gasket/Seal
  46. R60 How do I get this wiring loom off the thermostat housing??
  47. R60 R60 N18 Turbo Excessive Oil Hot Side
  48. R60 Oil filter housing plug has lost it's home
  49. R60 Cargo rail
  50. R60 Drive belt tensioner question?
  51. R60 "4x4!" warningand Code and DSC OFF
  52. R60 2012 R60 Headlight High Beams Not Staying On
  53. R60 Garage is lost on what can be wrong
  54. R60 suspension
  55. R60 Daytime running lights and locking
  56. R60 Just builds
  57. R60 2012 R60 intake cam Frankenstein
  58. R60 2014 Mini Cooper Countryman SD Diesel (R60). Coolant pipe leak and replacement.
  59. R60 R60 vs Flooded road
  60. R60 Heater control issues..
  61. R60 Relearning Question
  62. R60 Aero front lip
  63. R60 New to me, repairs needed.
  64. R60 Countryman code 2DA2
  65. R60 Odor in cabin on acceleration
  66. R60 2012 Countryman S All4 heater hose replacement help!!
  67. R59 Baby car seat in 2012 Countryman
  68. R60 Comfort Access button on exterior handle
  69. R60 R60 to F60 head unit
  70. R60 2011 Countryman S with red roof
  71. R60 R60 dash alignment
  72. R60 Advice on removing stock exhaust
  73. R60 Rewinding the rear brake caliper
  74. R60 2014 R60 S All4 Yellow half engine light help
  75. R60 Can you tie off brake pad sensors
  76. F55/F56 Countryman specs?
  77. R60 '12 countryman pad replacement turned disaster
  78. R60 Wastegate broken off
  79. R60 Turbo from 2008 Mini
  80. R60 Thermostat
  81. R60 Back in a R60
  82. R60 2013 countryman S smashed curb
  83. R56 What to look for?
  84. R60 Overboost or no boost, but why?
  85. R60 Countryman All4 Center Driveshaft Support Replacement
  86. R60 really need you guys help
  87. R60 Western PA area R60 Countryman OEM Bike Rack for sale
  88. R60 R60 Countryman Tach Gauge replacement.
  89. R60 Chicago Area - Anyone Need an OEM Bike Rack?
  90. R60 Coding Cruise Control in MFSW
  91. R60 Charging system
  92. R60 MFSW Retrofitting (MFSW Column Switch)
  93. R60 Rev9 k04 hybrid f21m billet wheel turbo for 11-16 mini cooper countryman r60 1.6
  94. R60 F60 Style Side Rails on R60?
  95. R60 2012 R60 misfire
  96. R60 To Sell or not to Sell the Countryman
  97. R60 2011 cm
  98. R60 Brake replacement job question
  99. R60 All TPMS light on in the morning
  100. R60 Airwerks turbo upgrade
  101. R60 N18 2DA0 and 2C58 Codes
  102. R60 2012 R60 N18 oil filter housing.
  103. R60 Center Console Removal
  104. R60 P1338 plus other codes - help
  105. R60 Countryman diff
  106. R60 Suspension help
  107. R60 KW V2 Coilovers in the Marketplace
  108. R60 LED Brake Light Bulb Options?
  109. R60 Flatout Suspension Issues
  110. R60 Gas - Octane (again) 2012 Countryman - Not a Turbo
  111. R60 2012 countryman s exhaust flex pipe
  112. R60 My Countryman - a first-time Mini owner adventure!
  113. R60 Won't shift into Park and other Gear Selector Problems
  114. R60 Dreaded Engine Malfunction - Low Power Mode
  115. R60 Choosing Coilovers
  116. R60 Roof Rack T-slot Mod
  117. R60 LED Headlight Blubs - Can't find one that's Error-Free
  118. R60 Towing w/ a Countryman
  119. F60 Countryman PHEV Reversing lights
  120. R60 Front end service mode
  121. R60 2013 R60 Newbie help?
  122. R60 2104 R60 12v Sockets
  123. R60 External Lighting Warning Indicator
  124. R60 Thinking to get 2011 mini copper s countryman
  125. R60 Newbie help - where is the Jack and air compressor
  126. R60 Mini repair shops
  127. R60 Did I brick my radio?
  128. F60 Are there any shops that sell JCW Aero front spoiler separately from the whole kit?
  129. R60 Stripe Install on 2015 Countryman S
  130. R60 Looking to buy a CM,2015, NA, Manual
  131. R60 Countryman S - are the exhaust tips removeable?
  132. R60 Review: MarioKart Stage 2 Tune + Downpipe
  133. R60 2014 Countryman S All-4 leaking coolant from oil coiler
  134. R60 Engine Swap
  135. R60 2nd cat/resonator delete, ecu flash needed?
  136. R60 Break replcement advice
  137. R60 Swerving in rain!
  138. R60 Midway through Joey mod, unsure what not to paint
  139. R60 Help me identify a noise, please!
  140. R60 Headlights
  141. R60 TPMS External Interference
  142. F60 No sound…..
  143. R60 Exhaust and Low-Frequency Noise
  144. R60 P0300 - P0304 code, HELP!
  145. F60 2012 Countryman - Fuel Gauge always Showing Empty/Flashing
  146. R60 Oil pressure light after extended driving
  147. R60 Owners Badges
  148. R60 2012 R60 Countryman Sport Suspension 225 50 18
  149. R60 cooling fan / radiator fan comes on after most stops
  150. R60 Replace foglight dasboard switch lamp
  151. F55/F56 Radio light
  152. R60 MINI COUNTRYMAN 2014 1.6lt 122HP turbo
  153. R60 Dash cam recommendations 2013 R60
  154. R60 2014 R60 throwing codes
  155. R60 Locating specific bolts
  156. R60 Interior Wasted Space
  157. R60 is my MPG mileage normal?
  158. R60 2012 R60 blowing 25 amp fuse
  159. R60 Just Changed the Oil
  160. R60 Thermostat replacement w/harness
  161. R60 coolant type
  162. R60 Bulb out indicator bimmerlink
  163. JCW anyone here recognize this car???
  164. R60 Oil level - not easy
  165. R60 Metallic sounding when cold
  166. R60 2015 Countryman S All4 Clutch
  167. R60 Looking to buy thoughts and advice? MCS countryman
  168. F60 Countryman on Hatch
  169. R60 Driver's door won't open-OUTSIDE ONLY
  170. R60 Noticed preowned countryman has ONE new coil
  171. R60 cold start is rough
  172. R60 My R60's Last Adventures Driving Cross Country To Calgary, Alberta, Canada
  173. R60 Clicking coming on brake pedal ON and OFF near idrive
  174. F60 Does red "P" on shifter always look on?
  175. R60 glove box - what are these?
  176. R60 Mini Connect Update?
  177. R60 What Battery for 2015 Countryman S?
  178. R60 climate control / thermostat dials
  179. R60 +1 tire size
  180. R60 Oil Pan Question?
  181. R60 Shopping for an extended warranty - what and how much?
  182. R60 Big Service - What Else?
  183. R60 R60 brake service indicator issue
  184. R60 Countryman Engine OK?
  185. R60 Opinions requested
  186. R60 2012 Countryman S All 4 oil solenoid harness
  187. R60 Used a Seicane harness and radio, but issue remains…
  188. R60 Pin 16 missing on Radio Harness need 12v switched wire
  189. R60 2015 CM ALL4 S EVAP Leak Tracing- HELP PLEASE
  190. R60 Huge clunk sound followed by smaller clunk sounds and grinding.
  191. R60 Costco 93 octane
  192. R61 FS Paceman incredible!!!!
  193. R60 Engine replacement N18B16A to N18B16C
  194. R60 R60 Knock/Rattle at 2500RPM
  195. R60 Coolant in engine block?
  196. R60 Code reader advice?
  197. R60 Swap out speedometer to Naviplayer dvd radio
  198. F60 Parasitic draw help.
  199. R60 Recaro sport seat install
  200. F60 What tune should I get?
  201. R60 P15FE - Engine shutdown time, signal: Missing/Electrical Fault
  202. R60 A/c has stopped cooling
  203. R60 Valve Cover Leak
  204. R60 New Owner 2012 R60 - Maintenance Questions
  205. R60 Is a clutch repair possible myself, if so, should I dare attempt?
  206. R60 Just sold my 07 r56 and purchased a 14 r60 s all 4
  207. R60 Biggest tire size for r60 with 2.5" lift
  208. R60 Prop shaft install for All4 S
  209. R60 Changing Seats, need Braket Recommendations
  210. R60 2011 Countryman S speedometer/navigation upgrade
  211. R50/R53 2012 Countryman All4 Common issue
  212. R60 Sunroof not fully closing?
  213. R60 Tail/brake lights
  214. R60 Window visor vent shade
  215. R60 Car is down on power
  216. R60 New owner! Throttle issues
  217. R60 Oh FFS!
  218. R60 Can't find what engine model I have!
  219. R60 Reduced Power Icon
  220. R60 Timing chain tensioner
  221. R60 Is this R60/Jungle Green?
  222. R60 2012 R60 Rear Tire Killer
  223. R60 2C57 Error and Turbo Options
  224. R60 Afe pro dry drop in filter question.
  225. R60 P0336 + trouble starting + multiple dash lights + limp mode
  226. R60 Strut tower brace question
  227. R60 Bc racing br series coilovers
  228. R60 Burned up ECU from JB+ posible?
  229. R60 Long term secondary car
  230. R60 R60 from cigarette lighter replace with usb
  231. R60 Bluetooth pairing issues 2011 Countryman advice appreciated!
  232. R60 How to open the hatch w a dead battery?
  233. R60 Oil & Filter Change Questions
  234. R60 Stripes or no stripes?
  235. R60 Low Oil Pressure Under Hard Driving
  236. R60 Where to buy Bilstein B12 Pro Kit
  237. R60 R60 Coding Equipment
  238. R60 Countryman Engine Questions. JCW or S
  239. R60 Replace springs with shocks?
  240. R60 Overheating issues
  241. R60 camber mod for countryman?
  242. R60 Countryman hit by a school bus...now what? 😞
  243. R60 Oil warning light
  244. R60 Transmission Drain Plug Torque
  245. R60 AC issue - trying to diagnose
  246. R60 Water temp gauge
  247. R60 2016 R60 R141 Anthracite wheel color /code?
  248. R60 2014 Countryman All-4 Engine Issue
  249. R60 Air Intake hose super oily
  250. R60 "new" 2012 Countryman S All4 Thoughts?
