R60 2012 R60 Rear Tire Killer
Hello, I've got a 2012 Countryman and it's been eating rear tires for several years. A few years ago I discovered extreme cupping wear on the rear tires 18k miles after installation. The car had about 51k miles on it. I replaced the rear shocks and mounts, tires and had it aligned. I am now seeing cupping again to the wear indicator by approximately 18k miles on the new pair. Admittedly, I have not rotated them. The only other thing I can think of is the control arm bushings, I would not have expected them to be worn that early? Is there anything else I should be looking at?
Thanks, Jason
Thanks, Jason
I have a 2016 CMS All4 and it is also cupping the rear tires badly. When I bought it at 30k miles the dealership had replaced one of the rear control arms due to it not being able to get into alignment... At my last oil change (now 60k miles) at the dealer they noted the rear shocks have leaked and are ineffective. I bought some new Bilstein B6's to get put on soon and will then do another alignment. I was told by 2 different Mini owners the OE shocks (Bilstein B4's) are only good for about 30k miles tops. So the combination of crappy shocks and run flats (mine has the Pirellis) may lead to cupping. Hoping that the upgraded shocks will help. My independent shop says the cupping for sure is coming from the shocks. My have to do more regular rotations also.
I second the recommendation for better shocks.
I would also suggest a set of trailing arm bushings:
https://www.powerflexusa.com/shop/pr...=1488#attr=925
Replace the shocks with Bilstein B6s, add the bushing inserts, then get a quality alignment. Make sure your toe and camber numbers are the same from side to side.
The trailing arm bushings reduce the compliance of the front of the trailing arm, which keeps your toe in check as the suspension moves around. Makes the handling more predictable.
OK great, I purchased them to do it at the same time since I have to get the B6's put on and get an alignment. Thanks for the suggestion.
I don’t think there are B8s available for the Countryman… However, the B8s on their own will not lower the car. Neither will the B6 shocks. The ONLY difference between the B6 and B8 shocks are the B8s are designed for use with lowering springs. The damping profile is exactly the same between the two.
You don’t need control arm bushings. The OEM bushings are tight enough that you won’t see any difference going with poly. Plus the installation is a rough task since you have to fully remove the OEM bushings.
How's it feel?
Rides really good, I didn't realize how much noise it was making in the back with the shocks shot on bumps. Its still definitely a firm ride with Run Flats, make no mistake but it feels better with the shocks and the inserts (and new top mounts)
7rhSon
Jan 13, 2020 05:40 PM
Jwanck11
Nov 1, 2018 08:16 PM
