PDA
View Full Version : 1st Gen Countryman (R60) Talk (2010-2015)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. R60 don't understand engine air flow
  2. R60 Tunein: Anybody else lose the direct control with their latest software update?
  3. R60 Fumoto valve
  4. R60 2011 Countrymna S ?
  5. R60 What kind of deal did you get for your JCW Countryman
  6. R60 New to Me 2011 R60 smoking on startup
  7. R60 New strut bar install
  8. R60 Brake light electric problem...not the bulb or board
  9. R60 Indy Locals wanna trade
  10. R60 Chrome LED DRL
  11. R60 Purchased high mile countryman.. Whistling under hood
  12. R60 150k Mile Countryman S All 4.. Thoughts??
  13. R60 Little Random Accessories
  14. R60 She drowned but recovery on the way R60 edittion
  15. R60 R60 Controller 2013
  16. R60 Put a Chrome gas cap on a 2012 Countryman S?
  17. R60 Service reset
  18. R60 Spark Plug choice
  19. R60 Two questions
  20. R60 Mini Cooper Countryman (NOT S MODEL)
  21. R60 Where do you get your oil changed?
  22. R60 Left Outer Tie Rod & Thermostat @ 65k
  23. R60 Rear wiper
  24. R60 Driver's seat lumber failed?
  25. R60 N18 tuning questions.
  26. R60 82% OFF Genuine MINI Floor mats & Free shipping
  27. R60 Front strut replacement
  28. R60 Upsized, R56 to R60
  29. R60 Has Anyone Installed The JCW Sport Gauges?
  30. R60 Excessive front tire wear and cupping
  31. R60 Side mirrors
  32. R60 '13 CMSAll4 End Links
  33. R60 Countryman R60 Power Window Moves Incrementally
  34. R60 Countryman ALL4 Trim Question
  35. R60 Wife got hit in her Countryman All4...
  36. R60 BC vs. Megan Racing Coilovers
  37. R60 WMW Res Delete Pipe
  38. R60 coolant leak
  39. R60 Doors have to be closed to open the windows
  40. R60 2013 JCW Countryman Cuts Out at around 4K rpm
  41. R60 Service mode?
  42. R60 Oil Filter housing leak - repair manual
  43. R60 MINI Connected help
  44. R60 Timing alignment holes in flywheel
  45. R60 Clutch Time
  46. R60 K&N Filter
  47. R60 Just not happy with Dealership
  48. R60 Paint or punt?!
  49. R60 Preferred replacement winter wiper blades?
  50. R60 New Body Kit for Mini Cooper Countryman!!
  51. R60 New Clutch Install
  52. R60 Radio button... How screwed am I?
  53. R60 Lower front grill won't stay on
  54. R60 What tires to purchase
  55. R60 windshield washer check
  56. R60 Transmission Fluid Question
  57. R60 Custom Exhaust on the way!
  58. R60 2011 R60 1.6s - Vacuum hose missing question
  59. R60 2011 R60 can't get terminal 15 which is ignition (PLZ HELP)
  60. R60 Hi! I'm back
  61. R60 Extended warranty, worth it? 4K for 2 years
  62. R60 Hello
  63. R60 Oil Chage question
  64. R60 Increased battery discharge
  65. R60 Check engine loose of power
  66. R60 2011 Mini Countryman S needs snow chains for Tahoe
  67. R60 Rear Seat Delete
  68. R60 Mud Flaps for 2017
  69. R60 Auto-to-Manual Transmission Swap?
  70. R60 2011 Mini Countryman leaking or losing oil
  71. R60 "New" 2014 Countryman
  72. R60 R60 Countryman S All4 Performance Upgrades
  73. R60 R60 Countryman S All4 Performance Upgrades
  74. R60 2012 R60 s all4 error code help
  75. R60 New to me '13 Countryman JCW
  76. R60 Need some info please
  77. R60 replace xeon light bulb
  78. R60 Suggestions before I order?
  79. R60 what motor is my mini
  80. R60 2012 Countryman - my "turbo is going"??
  81. R60 Service Bulletins
  82. R60 Hawaii Peeps, Go Buy My Mini!
  83. R60 R60 Headlight Alignment after repair?
  84. R60 Carly for a '17 or '18?
  85. R60 Maintenance Plan Upgrade
  86. R60 Engine ventilation heating, activation: line disconnecting
  87. R60 How to remove speedo/tach cluster
  88. R60 Multiple errors on dash
  89. R60 Fog light assembly cover
  90. R60 Noisy Steering Wheel
  91. R60 JCW Sport Gauges or 2nd Gen Types?
  92. R60 Has Anyone Bought A Rearview Mirror/DashCam?
  93. R60 MINI Countryman Driving/Fog lights
  94. R60 Where do these go?
  95. R60 Parking Brake Question...
  96. R60 Tilting the seat bases?
  97. R60 Cooling after turn off?
  98. R60 Countryman 3rd Brake Light - 1 LED out
  99. R60 Replacing Exterior Trim Grill
  100. R60 Bulbs Out Conundrum
  101. R60 New Countryman owner
  102. R60 towbar for r60
  103. R60 1.6 Turbo low on torque?
  104. R60 What brand and color viny stripes will match?
  105. R60 Replacing Center Consol With Retro Fit In A Paceman
  106. R60 Roof Top Box Dimensions
  107. R60 Chasing Gremlins.....
  108. R60 Broken SP. Be sure to check
  109. R60 countryman s all4
  110. R60 Twin Power Turbo
  111. R60 Lifted my Countryman and now....
  112. R60 Paceman Upgrade Suggestions on Countryman Talk
  113. R60 Got the NM cold charge pipe in today
  114. R60 Is there any way to stream music via iPhone cordlessly?
  115. R60 To lower or not to lower? That is the question.
  116. R60 Oil Control Valve Failing @ 58500 Mile
  117. R60 Headlight washers
  118. R60 Driving light cover?
  119. R60 Gauge(s) bracket
  120. R60 radiator fan and thermostat
  121. R60 No JCW exhaust on my CM JCW?
  122. R60 My new Countryman
  123. R60 Apple CarPlay
  124. R60 We already knew that!!
  125. R60 [Engadget] Mini's new plug-in hybrid packs thrills into a compact cruiser
  126. R60 How to tell if your Countryman is an LSI
  127. R60 Left the Mini World
  128. R60 Some regret
  129. R60 Popping the coils
  130. R60 Engine won't turn over
  131. R60 Off-road Styling Bumpers
  132. R60 2012 mini countryman no power to F44
  133. R60 2017 Countryman S new - won't start issue
  134. R60 F60:Spoiler?
  135. R60 Torque arm insert is a must do.
  136. R60 Name that part - CV Axle housing bolt? Something...
  137. R60 How are turbos cooled?
  138. R60 Thermostat / Housing replacement
  139. R60 AC Issues
  140. R60 Spark plug gap for the r60 s
  141. R60 OEM Bike Rack for Sale
  142. R60 What kind of oil to run
  143. R60 coolant additives
  144. R60 does this face look familiar?
  145. R60 gas milage, not bad, but different
  146. R60 a/c and cv axle questions
  147. R60 OEM oil filter or another brand of filter?
  148. R60 Creaky Doors !!
  149. R60 vibration
  150. R60 Post Warranty Maintenance Suggestions?
  151. R60 Vinyl Dealers?
  152. R60 Apple Car Play Non 2018 Countrymans
  153. R60 F60 Cooper S minimum wheel size?
  154. R60 Backup light drivers side
  155. R60 Wooden roof racks for R60
  156. R60 High Pressure Fuel Pump Sensor Adapter??
  157. R60 Connected Software Update for 2015 Countryman S
  158. R60 Any tips on what should be done?
  159. R60 Fuse for Radio
  160. R60 Tires
  161. R60 horn sounds when turning right!
  162. R60 Newly purchased 2011 Countryman S ALL4
  163. R60 Anyone using a 20+ CF roof box?
  164. R60 Bluetooth for 2012 Cm
  165. R60 Worried about oil...
  166. R60 CD formats?
  167. R60 Just bought a Countryman S ALL 4 yesterday
  168. R60 R60 New plugs and coil packs still misfires all 4
  169. R60 Struts for lifted cm?
  170. R60 Update: Stutter/Stumble on Cold Start and More
  171. R60 MINIUSA Hybrid Configurator is Live!
  172. R60 Hood release failure
  173. R60 R60 - Vleds Tail Light Bulbs - For Sale
  174. R60 R60 Spare Tire Kit (space saver) For Sale
  175. R60 COUNTRYMAN letters (measurements)
  176. R60 Are the dealer roof bars made by Thule?
  177. R60 Rain sensing wipers...
  178. R60 Aftermarket Android Systems(Radio)
  179. R60 2012 CMS Power Steering Removal
  180. R60 Spark Plug Help Please
  181. R60 R60 Countryman Base power
  182. R60 Dealer requests new engine!?!?!?
  183. R60 Changing clutch and dual mass flywheel after 62000Km's
  184. R60 Clutch slipping
  185. R60 Ongoing motor issues.
  186. R60 F60 July 2017 Builds
  187. R60 2" Countryman Trailer hitch (for bikerack)
  188. R60 Blinking and then solid engine light
  189. R60 Replacement hood stripes?
  190. R60 What happens next may make or break me for MINI
  191. R60 listening through the stereo from my samsung android phone
  192. R60 New Owners Thoughts/Questions
  193. R60 Scheduled Maintenance
  194. R60 Best bang for buck mod for power
  195. R60 2017 Countryman boot dimensions....
  196. R60 Coolant change DIY
  197. R60 2018 Cooper S E Countryman
  198. R60 New exhaust tips on 2011 Countryman S
  199. R60 2013 Supercharger Reduction Pulley
  200. R60 2017 Countryman wind noise
  201. R60 Cross bars (2012 All4)
  202. R60 Low oil pressure warning (where is the oil pressure switch?)
  203. R60 Could it drift?
  204. R60 Rattly rusty luggage ties.
  205. R60 45K mile service items?
  206. R60 Software Update 2017 Countryman
  207. R60 2012 R60 Auto Tranny - Does it need to be flushed?
  208. R60 Hi guys, navi question.
  209. R60 Purchasing 2015 Countryman All4 S
  210. R60 R60 tow hook
  211. R60 Mirror caps
  212. R60 Room in the garage
  213. R60 Option Codes
  214. R60 ▀▄▀▄▀▄▀ PLEASE READ: Before creating a new thread!▀▄▀▄▀▄▀
  215. R60 2017 Countryman More of a BMW?
  216. R60 The 2017 Mini Countryman Is Your Large Adult Mini For Your Large Adult Life
  217. R60 Rear Camber
  218. R60 [MotoringFile] MINI USA Prices the Countryman Hybrid
  219. R60 Trying out Bolt-on exhaust tips
  220. R60 Front bumper alignment / adjustment
  221. R60 Code exhaust pop without enabling Sport mode?
  222. R60 Rand McNally Wireless Backup Cam
  223. R60 Scorpion front section
  224. R60 18.5 lbs of boost in my countryman.
  225. R60 Can't figure this one out 🤔😩😧
  226. R60 ECU Tuning in NJ?
  227. R60 Yellow mini rally lights
  228. R60 Catless DP and exhausts for R60
  229. R60 Best independent Mini shop in SF Bay Area?
  230. R60 MotoringFile Review: 2017 MINI Countryman Cooper S ALL4 (Manual)
  231. R60 Programming Used Key FOB
  232. R60 2017 Countryman - An Appreciation
  233. R60 Any Brake DIY's Available ?
  234. R60 Sport mode retrofit??
  235. R60 This is pretty hilarious, and apparently true...
  236. R60 Rough idle in cold temps
  237. R60 Wiring from bumper into boot
  238. R60 MiniUSA.COM Build It
  239. R60 Exhaust Diameter
  240. R60 Found out something new today.
  241. R60 Potential Buyer - 2011 Countryman 4D-S - Quick Help Please
  242. R60 R60 2011 Countryman
  243. R60 Aftermarket Catless DP or just delete cat
  244. R60 Thoughts on YELLOW Rally lights?
  245. R60 '12 CMS Brake Warning Light
  246. R60 2017 lounge leather black vs grey
  247. R60 [Autoblog] Longer, wider, still a Mini | 2017 Mini Countryman First Drive
  248. R60 2011 R60 ALL4 rear sway bar same the FWD model rear sway bar?
  249. R60 Removing S badge from grille
  250. R60 F60 19 inch what tires
