PDA
View Full Version : 1st Gen Countryman (R60) Talk (2010-2015)
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. R60 Is there a way to open the R60 rear hatch door from the inside?
  2. R60 Rear end clicking. Follows vehicle speed
  3. R60 All4 Manual Transfer Case issues
  4. R60 Time to refurbish the old girl OR move on
  5. R60 R60 Rear Brace?
  6. R60 Differential and transfer case fluid change on R60 JCW ALL4?
  7. R60 Countryman S Radiator Fan Connector
  8. R60 Rough Idle/fuel too rich
  9. R60 Suspension knock is fixed!!
  10. R60 2012 R60 view of top of rear strut from inside the car
  11. F60 2014 All4 crank but no start. Some diagnosis complete
  12. R60 Please Post instructions-to remove the '2014' Countryman front wheel well liner
  13. R60 S engine vs JCW engine
  14. R60 Transmission/Differential/Oil pan fill bolts
  15. R60 2011 Mini CM, Automatic S, FWD Flex plate/Flywheel
  16. R55 2001 Wipers Not Working
  17. R60 Key will not unlock/lock doors
  18. R60 R60 All4 Drive Shaft Removal, subframe drop
  19. R60 Hail Mary Post
  20. R60 What 'donut spare tire'-fits the R60 Countryman- to use as a spare?
  21. R60 Advise me
  22. R60 Startup fuel pressure issues - Another HPFP replacement?
  23. R60 High Fuel Pressure Drop - No Start
  24. R60 Foglamp alignment adjustment
  25. R60 How do you reset the 'pressure monitoring system' [PMS]- after installing new tires?
  26. R60 Retrofitting MSFW paddle shifters inquiry
  27. R60 N18 countryman low boost no codes
  28. R60 Clutch Slave Cylinder Leaking
  29. R60 Right Front Door Speaker replacement quote
  30. R60 Help identifying part: turbo related
  31. R60 Hood foam seals ... possibly the hardest part to find!
  32. R60 Sealed key FOB,cannot replace battery-What are my options
  33. R60 RIDICULOUS Online Parts shipping costs - what am I missing?
  34. R60 How many miles on your R60 Countryman-What repairs have you done to it?
  35. R60 N18 No Compression / Good Timing Chain
  36. R60 Hood release inop
  37. R60 Does anyone know where to get the "Big" JCW Lip?
  38. R60 Fan Running
  39. R60 K-Can Errors
  40. R60 Car turns off immediately on startup.
  41. R60 Alternator only spins counter clockwise
  42. R60 How do I fix backlight issue of the buttons on the steering wheel
  43. R60 Need assistance identifying this part
  44. JCW R60 AT turbo lag question
  45. F60 Potential purchase with engine codes
  46. R60 Center jack point
  47. R60 2012 Countryman S crank no start?
  48. R60 Weird codes
  49. R60 No power to Driver window switches or mirror adjustment
  50. R60 2012 Countryman - All sensors going off after valve cover replacment
  51. R60 OK to use 0W-30 oil for R60 JCW
  52. R60 Engine Out Clutch job on 2012 R60 S All4
  53. JCW Cost of replacing JCW turbocharger
  54. R60 Water pipe replacement
  55. R56 Cylinder 3 misfire
  56. R60 Transfer Case Options
  57. R60 R60 fuel pressure
  58. R60 Help Identify this Cable/Plug
  59. R60 Trouble getting back driveshaft in the front driveshaft won't slide in. Even marked i
  60. R60 R60 Positive Cable Replacement Help
  61. R60 Front Control Arm Inner Ball Joint Torque
  62. R60 Brakes just quit! Really hard pedal. please help
  63. R60 Turbo Replacement with out unbolting whole front end
  64. R60 R60 Rear Suspension Noise
  65. R60 Anyone know someone in the Milwaukee WI Area
  66. R60 2012 Countryman - Acclerator Postion Sensor Intermittant Issue
  67. R60 2016 MCS All4 issues
  68. R60 TPMS Controller location?
  69. R60 BWM style 230 19 inch rims on R60 Countryman
  70. R60 Cut Off This Axle Nut?
  71. R60 The ole oil housing gasket job
  72. R60 13’ R60 s all 4 oil leak troubleshoot
  73. R60 R60 Spare Tire Kit (space saver) For Sale
  74. R60 Coilovers that preserve stock ride height?
  75. F60 2013 Mini Countryman S won’t start after spark plug change
  76. R60 R60 countryman crank no start
  77. R60 Mini won't move
  78. R60 2012 Countryman S All4 N18 timing chain jumped and bent valves. Is it worth fixing?
  79. R60 ABS Issue Sensor/sensor ring
  80. R60 Mini N18 weird noise.
  81. R60 Correct Coolant?
  82. R60 HELP! Oil Leak
  83. R60 R60 S waste gate question
  84. R60 Turbo or Valve Stems or ??
  85. R60 Dashboard Scratches/Scuffs - How to fix them?
  86. R60 Installed cloned ECM, Transmission DTC's
  87. R60 A few codes and some bucking at higher speeds?
  88. R60 Tips on changing thermostat housing
  89. R60 Bumper Comfort Access Antenna
  90. R60 Aftermarket Lighting Issues
  91. R60 Countryman s all4
  92. R60 R60 S All 4 stuck passenger cv axle
  93. R60 Reinstalled ECU, car won't turn over
  94. R60 JCW CF gear knob
  95. R60 lower alternator bolt n47d16 2010
  96. R60 Anyone has pictures around oil pan area for R60 S ALL 4?
  97. R60 Fuel Pump, Level Sensor or Both?
  98. R60 2014 Mini Cooper S Countryman ECU/DME replacement
  99. R60 9CC2 Attention Electronics on the right headlight (SMC) reports errors
  100. R60 R60 Passenger airbag matt sensor
  101. R60 no crank no start
  102. R60 Larger cross applicable front discs
  103. R60 Back in a Mini
  104. R60 Replaced THermostat - broke few things, need help figuring out what Parts i need
  105. R60 2012 Countryman R60 Automatic, 287D and transmission won't engage
  106. R60 SOS: wife bought a mini a week ago, now lots of codes
  107. R60 Installing 2014 motor in 2012 countryman
  108. R60 Possible causes of super tapping? R60 countryman
  109. R60 Handful of CELs; Odd Hex Values; Inlet/Outlet Temp
  110. R60 Parts replacing and maintenance for my 13’ R60 S All 4
  111. R60 Engine valve cover peice
  112. R60 cooling fan
  113. R60 R60 Rear Tail light not working
  114. R60 FOB quirk: second unlock lowers drivers side window by an inch
  115. R60 200,000 miles
  116. R60 Aluminum thermostat housings
  117. R60 ABS Fault
  118. R60 Bottom alternator bolt
  119. F60 Rear clutch pack trigger voltage?
  120. R60 2BC0 and Falsely High Fuel Economy
  121. R60 PVC gasket (On top of valve cover)
  122. R60 2012 countryman engine mount bolts loose?
  123. R60 Random multiple misfire after timing chain replacement
  124. R60 No Heat!!?!
  125. R60 Am I missing a hose?
  126. JCW R60 clutch
  127. R60 2011 Countryman Turbo S Oil leak
  128. R60 radiator fan problem
  129. R60 Blowing fuse 4 in Engine bay
  130. R60 Infotainment Center display only "Mini"
  131. R60 Engine Replacement
  132. R60 R60 head unit- confused!
  133. R60 2012 Countryman R60 - Rear parking lights only work when hazard lights are turned on
  134. R60 Multiple Front Crankshaft Seal Leaks
  135. R60 Dash removal DIY for the R60 Countryman?
  136. R60 Red bezel reflector on tach
  137. R60 Replaced turbo, now seeing 20PSI of boost!
  138. R60 Roof rack accessories
  139. R60 Noise in drive while stationary
  140. R60 Looking for a Bolt part Number
  141. R60 2014 Mini Cooper countryman S All4 (R60)
  142. R60 20 psi of boost?
  143. R60 2011 Entertainment System Software Issue
  144. R60 Cheap Exhaust?
  145. R60 Sheared Sway Bar Bracket Bolt
  146. R60 Subframe Rust - How much is too much?
  147. R60 Bluetooth stabilizer bar end link
  148. R60 0W-30 vs 5W-30 in a 2016 R60 N18 Countryman
  149. R60 Exhaust band clamp size for Axle Back?
  150. R60 Serpentine belt shredded.... dang it!
  151. R60 2011 R60 Fuel pump relay cheapest solution
  152. R60 Transmission disengaged
  153. R60 Had a lot of oil in my intercooler to intake pipe, anyone drill a weep hole anywhere?
  154. R60 Multiple Water Pump Variants Help
  155. R60 2015 burning (not leaking) oil, where to start looking?
  156. R59 Filling auto trans?
  157. R60 How to I tell if I have the Anti-Theft Package? I need to order a door latch...
  158. R60 Fault code 4E21 and Limp mode stock 3rd gear
  159. R60 Rear Bumper Hardware
  160. R60 '13 Countryman N16 - Crank No Start
  161. R60 A0B6 Code (CAS: Selector-lever interlock)
  162. R60 Mini Countryman Wastegate Failure
  163. R60 Subframe?
  164. R60 Transfer Case for 2012 CM S ALL4
  165. R60 Mini bucks/stutters while turning at low speeds
  166. R60 R60 diverter valve no shift at wot
  167. R60 Halogen to Xenon Harness
  168. R60 CRanks, no start, no headlighst, some dash lights missing
  169. R60 car wont start after timing chain
  170. R60 Anyone Autocross R60s?
  171. R60 R60 window/mirror fault
  172. R60 2014 Mini Countryman S Oil Leaks
  173. R60 R60 won't start
  174. R60 Starting to smell hot(not burned) oil after drives
  175. R60 3 antenna wires in the back of OEM radio
  176. R60 Aftermarket Head Unit
  177. R60 Comfort access system module location
  178. R60 fog lights in place of parking lights
  179. R60 fog lights in place or parking lights
  180. R60 Strange knock/rattle in low RPM accelrating
  181. R60 P1339 code crankcase position sensor location
  182. R60 Pioneer DMH-C5500NEX
  183. R60 Just bought
  184. R60 Engine troubles at 75k
  185. R60 Mini countryman low power issues
  186. R60 Mini countryman 2.0l sd ecu programming
  187. F60 2016 countryman P0368, 300E, 2c58
  188. F60 Ignition Connector Release Help
  189. R60 R60 Ignition won't turn on.
  190. R60 Squeaking noise from steering - R60 CM S ALL4
  191. R60 Just Bought an R60
  192. R60 2015 countryman s help!!
  193. R60 2013 Countryman S ALL4 R60
  194. R60 R60 Chassis Wiring Diagram
  195. R60 USB and 3.5mm jack connection
  196. R60 Radio Upgrade Question
  197. R60 2013 PCV diaphragm cover
  198. R60 Snap-In Adapter / iPhone Cradle
  199. R60 P1338, 2D5A & 2DA0 Codes
  200. R60 Determining Suspension Setup
  201. R60 Wires Through Firewall
  202. R60 No crank - good battery and starter - power seems good
  203. F60 Hard start and clancking noise
  204. R60 2012 Countryman-engine malfunction light
  205. R60 2012 Countyman S automatic oil cooler replacement
  206. R60 Windshield Washer Line Fitting
  207. R60 2014 countryman
  208. R60 Help identifying these side skirts
  209. R60 replacement connector plug source
  210. R60 R60 Short Shifter Compatibility
  211. R60 raised air intake
  212. R60 Timing chain top guide rail.
  213. R60 Oil pressure
  214. R60 Airport guy jumped my car, now nothing works.
  215. R60 Single Cylinder Continuous Misfire Help
  216. R60 2015 Countryman Interior Door Handle Replacement
  217. R60 Struts/Shocks replacement
  218. R60 Rough idle after turbo feed line replaced
  219. R60 Changing oil pan gasket on ALL4?
  220. R60 HPHP Fuel Feed Line Connector Broken
  221. R60 Connector ID Help Under Intake Manifold
  222. R60 Close-up, proper windshield fitment photo request
  223. R60 Mini cooper countryman R60
  224. R60 Error code 2c58 and 2DA1 timing chain replacement
  225. R60 Vanos adaptations after timing chain install?
  226. R60 Fan Runs@turn-off:2015 CMS All4-Bad Temp Sensor?
  227. R60 Pig tail and connectors
  228. R60 Intake snorkel pipe
  229. R60 Exhaust manifold stud torque specs
  230. R60 Need Help - Coolant Sensor
  231. F60 Heater issues
  232. R60 Are Base and S Gearboxes the Same?
  233. R60 Timing chain install order
  234. R60 Current pricing on Timing Chain replacement
  235. R60 Fan stays on longer after thermostat replacement
  236. R60 Brown Ring On Cylinder Wall
  237. R52 murmurmur
  238. R60 Low Oil Pressure? 2015 Countryman All4 S
  239. R60 How to Remove Headlights?
  240. R60 Rear main seal oil leak
  241. R60 Multiple Cylinder Misfire - DV?
  242. R60 Downpipe
  243. R60 Fuel Injector Harness
  244. R60 Multiple codes; where to start
  245. R60 Reading all the codes
  246. R60 Picked up a used 2012 R60 - How can I update the maps on it?
  247. R60 r60 all4 manual clutch
  248. R60 New 2012 Mini Cooper Countryman R60 owner - some questions on fixing a few things
  249. R60 replacing turbo, how about cat?
  250. R60 Clutch question
