R60 PVC gasket (On top of valve cover)
Old Nov 18, 2024 | 08:30 AM
b.coate's Avatar
b.coate
I just replace my valve cover and it started leaking from the PCV gasket. Not sure what it actually called but its not the membrane. I have included a image below.
If you know what this gasket is called please let me know. Thanks
Old Nov 18, 2024 | 08:31 AM
b.coate's Avatar
b.coate
Also if someone could tell me what the heck this thing is and how to put it back.
Thanks again.
Old Nov 18, 2024 | 03:33 PM
jawilli6's Avatar
jawilli6
What do you mean by leaking? Hissing? Only thing that should be in there is air from venting crankcase pressure and often a bit of oil vapor. You have a fancy aftermarket valve cover/pcv assembly, all aluminum and red, cool. Mine is just black thermoplastic and the pcv doesn't come apart, ultrasonic welded or something. I think this means it really isn't meant to come apart. Hopefully someone will chime in because I have no idea if it can be reassembled.
Old Nov 18, 2024 | 05:30 PM
b.coate's Avatar
b.coate
So at the top of the first image where my finger is pointing, there is a bit of gasket that is bowed out. That had popped out causing a sucking sound on acceleration.
Old Nov 18, 2024 | 06:08 PM
jawilli6's Avatar
jawilli6
Gotcha. That is indeed pretty bowed out. I'm not sure how you could resettle that and expect it to have a good seal. Where'd you buy it from...I'd imagine they can help you find a replacement gasket that isn't so stretched. I don't see that specific subassembly gasket on ECS Tuning unfortunately. Maybe they can even help with reassembly of those weird things. I assume they're a check valve mechanism or maybe an oil vapor diverter but unsure.
Old Nov 19, 2024 | 07:12 AM
We dont have those on their own, its a whole new cover. Those are part of the top cover that you took off from what it looks like.
Please contact our CS so they can get a new one out.
Old Nov 19, 2024 | 09:57 AM
b.coate's Avatar
b.coate
Well crap. I was hoping just to replace the top cover gasket as there is a good seal on the valve cover. I guess I'm out of luck.
Old Nov 19, 2024 | 11:47 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Those types of gaskets can be finicky to lay down into the channel. If there is ANY amount of stretch, the groove will keep it stretched, and it won't fit all the way around and you'll end up with a loop like in your fist picture. You can try removing the whole thing and lubing the gasket with a light oil or WD-40, and then trying to carefully pack it back into the groove. It might take a whole bunch of patience, however.
OR, you can try running a bead of RTV into the groove, just proud of the top, letting it cure, then reinstalling the cover.
Kcwabo
Mar 3, 2022 10:42 AM
Standman
Nov 5, 2015 07:44 AM
EricMOTOR
Jan 30, 2012 05:42 AM
kennedy71809
Feb 3, 2011 09:56 AM
