R60 Serpentine belt shredded.... dang it!
Old Aug 14, 2024 | 01:51 PM
jo.Nathan's Avatar
jo.Nathan
So my serpentine belt shredded, so I end up replacing my water pump, and also since there was a coolant leak i replaced the thermostat housing assembly. now that the serpenine belt is on, the tensioner pulls in place, the water pump installed, and thermostat housing installed, I await not having an issue where i am getting a lot of smoke, and a rubber burning smell when I turn it on. Any Ideas on what to check next?
Old Aug 24, 2024 | 06:30 PM
MikeL's Avatar
MikeL
Keep an eye out for oil leaks now. I had a belt shred and it took out my front crankshaft seal.
Old Sep 19, 2024 | 06:43 AM
jawilli6's Avatar
jawilli6
My thoughts exactly.
Old Oct 12, 2024 | 03:18 PM
Bennyblast's Avatar
Bennyblast
Were you able to figure this out?
Old Oct 12, 2024 | 03:19 PM
Bennyblast's Avatar
Bennyblast
Was the repair ever posted?
Old Oct 16, 2024 | 07:11 AM
jawilli6's Avatar
jawilli6
The original poster only has this one post, and it was back in August. There is a likelihood they won't return here at this point. If you're still stuck, you might want to create your own post with your own specifics if you're trying to solve a problem.
Old Nov 19, 2024 | 07:14 AM
supazuk's Avatar
supazuk
I had the same issue this past spring wrapped around behind the pulley
Old Feb 1, 2025 | 11:44 PM
jo.Nathan's Avatar
jo.Nathan
Yes I did figure this out... now i have new issues...
with the amount of oil that was leaking, I finally replaced as many seals as i could get to and got it all to stop leaking....
But now I was driving on the interstate, and getting onto the off ramp everything felt fine, and then all the sudden, my transmission won't engage, the car will go into gear, but it will not even think about going into gear... I have seen a few other posts about the same thing but no one ever answers... there was no warning, and no issues just came straight outta nowhere
iissac22
R60/R61 Stock Problems/Issues
14
Apr 27, 2023 02:35 PM
pbkirby
R58 :: Coupé Talk (2012+)
May 16, 2019 06:01 AM
David E Holguin
Jun 12, 2017 10:12 PM
MattSaint
May 12, 2015 02:18 PM
05Greenie
Sep 8, 2012 09:19 PM
