R60 Fault code 4E21 and Limp mode stock 3rd gear
Old Jul 17, 2024 | 04:44 PM
skullboy's Avatar
skullboy
hello I've been looking for a fix for my R60's transmission problem and so the short version is that i replaced the valve body and now is tuck in limp mode withe the code 4E21 (Electronic pressure control valve SLT) a local mechanic said that it can be solenoid but I've had the same code withe 3 valve bodies so far and cant seem to get out of limp mode and I'm here to see if anybody as had the same problem and knows the fix for it allegedly may be the transmission control unit but I'm not sure and can't buy another TCU at this moment. beside that the engine runs well
Old Jul 23, 2024 | 10:11 AM
skullboy's Avatar
skullboy
Exclamation help with aisin transmision
UPDATE: replaced the solenoid that was giving me problems as what the scanner pointed but now is tuck in 5th gear (M5) and still cant shift out of it. can somebody help me please
Old Jul 24, 2024 | 06:51 AM
jawilli6's Avatar
jawilli6
Are the valve bodies you're swapping in and out from a reputable source? I'm just surprised you'd jump to the whole valve body instead of just the solenoid. Unless the solenoids are integral and can't be swapped individually. I don't know. Could there be spools in the installed valve body that were removed from a car in 5th gear? Maybe there is a way to move them? Maybe put the original valve body back in with known good solenoids? Most solenoids I know of can be tested by applying the correct voltage to its pins.
Old Jul 30, 2024 | 10:53 PM
skullboy's Avatar
skullboy
thanks for the response and yes the solenoids can be swamped individually nut i did that ones to no avail this is a used valve body i got from Allmag.com said it was an OEM used valve body and for the price it was not bad currently when i scan it it give me another solenoid code (4E35 Electronic pressure control valve SLC1) apparently its another solenoid so what I'll do is swap all the solenoids for one that i know are good and later down the line get brand new one.
minis are pain
Old Aug 4, 2024 | 09:30 AM
skullboy's Avatar
skullboy
Update
the problem was just a bent pin in solenoid #5 N92 and now is running like a dream now.
robbeard.11
Nov 1, 2021 08:42 AM
erbair
Jan 3, 2021 05:00 PM
poweredbydvot
May 12, 2010 11:07 AM
COR BLMY
Dec 12, 2006 05:02 AM
Finalstatic
Oct 31, 2005 10:59 AM
