R60 Anyone has pictures around oil pan area for R60 S ALL 4?
Old Feb 13, 2025 | 10:22 AM
jzhou0222's Avatar
jzhou0222
Post Anyone has pictures around oil pan area for R60 S ALL 4?
Hi all,
I will replace the oil pump solenoid since it prompted me a code. So far, I cannot really find a good picture or pictures of that area, and I forgot to take pictures since I flushed the ATF last time. Pictures between oil pan and torque arm insert will be great. Thank you for your help!
Old Feb 14, 2025 | 05:58 AM
anaustin's Avatar
anaustin
I have the below video I can send right now. It doesn't show the area behind the oil pan, but you can see the lower engine mount behind the pan.
Are you interested in knowing what's involved with the work? I just replaced my oil pump twice. See here for explanation. You need to remove the right-side axle so you can remove the engine mount so you can access the solenoid's wire harness. I wrote a Word document with step-by-step instructions and torque specs I can send you if you like.
Old Feb 14, 2025 | 01:49 PM
Here you go:
https://www.northamericanmotoring.co...ssue-help.html
Old Feb 15, 2025 | 08:53 AM
jzhou0222's Avatar
jzhou0222
video of oil pan
Thank you for all these. I've gone through several instructions in the past few day, I guess my question is if it is possible to not taking out the lower engine mount down there? Like if you take off the oil pan, did you have enough room to access the wire hardness? On top of that, I guess it was your Reddit post, do you had issues with the Bremmen Parts?
Old Feb 16, 2025 | 08:46 AM
anaustin's Avatar
anaustin
You must remove the engine mount to access the harness. See ECS's picture, which is excellent. The four threaded holes surrounding the harness' egress are for the engine mount's bolts.
In the picture's bottom left, you can see the transmission's output. The CV axle must be removed because it blocks access to the engine mount.
Regarding the Brennan oil pump, I can't recommend it. I went with a genuine Mini pump, part number 11 41 7 647 376, because I wanted the latest redesign for the oil wicking problem.
Old Feb 16, 2025 | 05:11 PM
jzhou0222's Avatar
jzhou0222
When you did yours, you didn't remove the transfer box right? I bet it is quite challenging to remove the lower engine mounts bracket (this dang wire literally sits behind the bracket)? Would you be able to recall the steps? Thanks for all these verbal guidance
Old Feb 17, 2025 | 09:05 AM
anaustin's Avatar
anaustin
I sent you private message with detailed instructions. First remove the axle. The second instructions are for replacing the oil pump, which you may or may not need.
These procedures are one way that I used to perform these tasks for my specific circumstances. I think they will serve as a starting point for you.
Old Mar 10, 2026 | 07:51 PM
Piah167's Avatar
Piah167
Sorry to dig up this old thread and my very first post on here. Would you mind sharing your procedure with me? I replaced my son's timing chain around Christmas and he has been getting low oil pressure just recently. Not sure if there is anything in the pickup but didn't see any fragments broken off guides. I think I should pop the pan, I am kicking myself for not doing it when I did timing and exhaust.
Thank you!
Jerry
Old Mar 10, 2026 | 08:02 PM
Piah167's Avatar
Piah167
Also thank you for your review of the Bremmen oil pump, I was about to drop the hammer on that thing to have it just in case. Going to see if scanner can check oil pressure tomorrow and if not I ordered a mechanical gauge and will pull sensor.
Old Mar 11, 2026 | 02:34 PM
anaustin's Avatar
anaustin
I'm happy to share the instructions. Your profile doesn't allow private messages. Can you enable?
Old Mar 12, 2026 | 08:01 AM
Piah167's Avatar
Piah167
Awesome, thank you! Not exactly sure how to do that just yet ..
Old Mar 12, 2026 | 05:36 PM
Jeff Wysocki's Avatar
Jeff Wysocki
Thank You for the pictures and the process. Insightful
gpetersttu
Sep 20, 2021 03:37 AM
Montreal300
Dec 10, 2020 10:11 AM
cdietman
17
Jun 5, 2014 12:38 PM
mandd
Oct 28, 2013 12:36 PM
