R60 Intake snorkel pipe
Old Nov 3, 2023 | 09:21 AM
Minir602014's Avatar
Minir602014
Intake snorkel pipe
Does anyone know if this part is supposed to click into place? It just sits on top and if I turn it over it falls out. There are tabs on it but it does not click together.
Old Nov 3, 2023 | 10:01 AM
2014 MC's Avatar
2014 MC
If all the tabs are there and the slots on the other main part are not broke (all appears to be ok), then you need to ensure the hook on the tab makes it past the slot to retain. Might have to push the thin outer wall of the slot to retain if they are deformed.
Old Nov 3, 2023 | 10:11 AM
Minir602014
I'll double check all the tabs and try to push the lip on the tab over the connecting portion and see if that works. If I doesn't I'll probably just zip tie it together. Pretty sure gluing it together wouldn't be the right way to go since it seems like it was supposed to come apart. Thank you
Old Nov 3, 2023 | 10:17 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Eh, its just an air guide for fresh air to the intake. I would dap a small bead of silicone on the seam and stick it together.
2014 MC's Avatar
2014 MC
I think it was designed to go together easy with the snaps on the assembly line is all. Only reasonable way to produce that elbow shape with injection molding is two pieces and assemble. It would be OK to permanently have those pieces together with bonding. Running a zip-tie sounds like a good way to keep them together if the snaps are compromised.
Old Nov 3, 2023 | 10:36 AM
Minir602014
Awesome! Thank you guys. Now, does anyone happen to know the torque on the clamp that connects the downpipe to the exhaust? I've heard 33ft and 18.4 ft pds.
Old Nov 3, 2023 | 10:44 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
25 ± 3 Nm (which converts to 18 ± 2 ft-lbs)
Old Nov 3, 2023 | 11:12 AM
Minir602014
Thank you for that clarification!! Have a great weekend!
JosephM635
Oct 31, 2025 01:07 PM
nd-photo.nl
11
Dec 1, 2020 01:56 PM
johnnyb2016
Sep 27, 2020 01:01 PM
peterpan101
May 30, 2013 07:52 AM
Tüls
Dec 15, 2006 06:26 PM
