R60 Low Oil Pressure? 2015 Countryman All4 S
Any idea what would cause these codes? Doesn't trip check engine light but during cold start you can hear chattering that goes away. Runs fine after that
BMW codes 3408 = P15A1, Oil Pressure control valve: sticks when under maximum current (minimum oil pressure).
MEVD17.2-BN2000 for N55
Oil-pressure control valve, mechanical: hangs in fully energized position (minimum oil pressure).
The diagnostic function monitors the oil pressure.
Engine Oil Pressure Control, Mechanical, Solenoid Valve Sticking In Fully Energized Position (Minimum Oil Pressure)
The fault is recognized when the oil pressure remains at maximum level despite targeted application of voltage to the solenoid valve.
Potential problem source(s):- Oil pressure control valve defective
Oil pressure control valve defective.
- Replace oil pressure control valve
33FE = P15A0, Engine oil pressure control static: Engine oil pressure to low, backup mode.
N55
Engine oil pressure control, static: oil pressure too low, emergency operation
Engine Oil Pressure Control, Static, Switchover To Limp Home Operation Because Engine Oil Pressure Too Low in Map Operation
the oil pressure drops below a defined level in relation to oil temperature and engine speed.Potential problem source(s):- Defect in wiring harness between oil-pressure sensor and DME
Defective oil-pressure sensor- Oil pressure control valve
- Check wiring harness between oil-pressure sensor and DME
- Replace oil-pressure sensor
- Replace oil pump-
N55
- Replace oil pump-
N55
- Replace oil pump-
N55
- Replace oil pump-
N55
- Replace oil pump-
N55
- Replace oil pump-
No, it's not, or it would have the same number.
For diagnostic purposes, it should give you a bit more info though.
It seems like the solenoid/wiring harness to it is a common problem. That would be a good starting point to check.
The oil pressure regulating solenoid is a common issue on the CMS ALL4.
Being am ALL4 system, it's a bit more troublesome to replace. The transfer case needs to be shifted to the side a tiny bit to remove 1 oil pan bolt.
Why do engineers hate mechanics so much?
The "easiest" way is to remove the intake manifold. Once it's removed, you can see the top 2 18mm for the transfer case bracket. Also, gotta remove the 13mm axel bracket. Tight but doable.
EDIT: Sorry for thread hijacking.
alexkuch
Jul 19, 2023 01:22 PM
INMINIS
Jan 16, 2022 08:55 AM
15minicountryman
Jul 7, 2019 06:08 AM
Robot Jail
12
May 6, 2017 12:07 PM
