R60 S engine vs JCW engine
Old Mar 25, 2026 | 03:30 PM
North of 60's Avatar
North of 60
Wife is looking for an R60 or R61 JCW to replace her old 2015 All4 JCW that was written off parked in front of our house.
We found a really nice R61 (true JCW, and not JCW appearance package) that is for sale and has had the motor replaced due to a timing chain disaster.
So turns out they installed a lower mileage S motor, but retained the JCW turbo and ECU. It runs great, but curious where this would fall with regards to power? Somewhere between S and JCW? or exactly like a JCW? All other running gear, exhaust, etc is JCW.
Thanks for any info you can provide…the really nice R61 is her favourite colour, red, and everything else she liked about the old R60….lounge leather seats with red piping, H/K, nav, etc..
Thanks!
Old Mar 30, 2026 | 04:52 AM
BlazingE60's Avatar
BlazingE60
From the MINI Technical Training literature...
The table provides an initial technical overview of the new features in the N18B16T0 engine in
comparison to the N18B16M0 engine.
Engine mechanics
• Piston with modified piston crown
• Purge air line in all country versions
• Tank ventilation line with heating element
• Adaptation of the dual-mass flywheel
• Friction-gear servodrive without actuator
Cooling
• Position of coolant temperature sensor
Intake and exhaust emission systems
• Twin-scroll exhaust turbocharger with larger diameter
of the compressor housing
• Diameter of clean air duct with gaiter increased
• Higher measuring range of the pressure sensors in the
intake system up to 3 bar
• Steel manifold
Fuel preparation
• Bosch high pressure pump with fuel pressure of 150 bar
Engine electrical system
• Bosch MEVD17.2.7 engine control unit
Ideally the "lower mileage S motor" would be from a 2013 or newer that has the Bosch high pressure fuel pump.
Old Mar 30, 2026 | 11:55 AM
North of 60
Thanks for that info.
Motor came out of a 2014 R61 Paceman S
Old Mar 30, 2026 | 12:29 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The Cooper S engine had higher compression and different DME tuning. So, running and S engine on a JCW turbo and DME, your power will be slightly higher than stock JCW. I would double check the turbo nameplate to see which turbo it has. If it has an S turbo, then your power will be down compared to JCW, but higher than stock S due to different boost targets in the JCW DME.
The Cooper S turbo ID number will end in either 0181 or 0163
The JCW turbo ID number will end in either 0146 or 0298
https://www.borgwarner.com/aftermark...product-search
Turbo ID nameplate is here:
Old Mar 30, 2026 | 07:55 PM
North of 60
Thanks for that info. I knew on the B48 the JCW has a lower compression ratio than an S, but wasn’t sure on the N18 motor. The car is in British Columbia, very close (<1 mile) to RPM Power….was thinking of Stage 2 tune by Lorenzo…wife’s car, but I get to drive it too!
I will let them know it is S motor, with JCW turbo and DME, will be valuable info.
Thanks again!
A383Wing
Sep 22, 2024 10:31 AM
shaggy32
Nov 24, 2011 06:07 PM
Heermann
Aug 27, 2003 04:29 PM
