R60 Just Bought an R60
Old Mar 29, 2024 | 06:16 AM
pluffmud's Avatar
pluffmud
Just Bought an R60
Seems pretty nice - only had it a couple of days. Keeping the R56 as well (clearcoat peeling). Perusing the board to see what could possibly go wrong and empty my wallet. It's quieter than the R56, handles pretty well, and the extra room is handy.
Old Mar 29, 2024 | 06:41 AM
Congrats,
Same thing as the n14 but less problems. Water Pipe, thermostat, waterpump, valve cover, etc
On the R60 check the rear springs as they rust and can crack.
Old Mar 29, 2024 | 12:11 PM
pluffmud's Avatar
pluffmud
Well, I jinxed myself. Front passenger door won't open from the inside - feels like the cable is loose or disconnected, so I guess I'm pulling a door card tomorrow.
Old Apr 11, 2024 | 05:22 AM
jawilli6's Avatar
jawilli6
Well if that's as bad as it gets you're doing alright!
Old Apr 12, 2024 | 06:07 AM
pluffmud's Avatar
pluffmud
Annnnndd . . just detected the dreaded clicking at low speed turns - prob the half shafts and I'm not pulling those myself - there goes another 2000.00 +.
Old Apr 19, 2024 | 05:40 AM
pluffmud's Avatar
pluffmud
Well, we have a very good Mini shop here, so I just took it in and am having them do the work - this will be my wife's car, so it needs to be sorted pronto instead of when I get around to it. New CV shaft, new w. pump pulley and belt, new urethane c. arm bushings, new brake sensor, driver's door fixed so it will open from the inside, and a couple of side markers. 2800.00, but that's sorting everything that showed up on the inspection. IDK if that is steep or not any more - they have always done superior work on my other Mini, so I'm going to cough up the $$$ for the peace of mind.
Old Apr 19, 2024 | 06:02 AM
jawilli6's Avatar
jawilli6
Bummer, but like you said, peace of mind. Doesn't sound an unreasonable price for all that, at least where I live.
Old Apr 19, 2024 | 08:24 AM
2014 MC's Avatar
2014 MC
I was quoted $1400 to replace a CV that had a small tear/leak in the boot. It was an outer boot. I pulled it and replaced the boot myself fairly easily with a kit for less than $60. Nothing wrong at all with the shaft... Peace of mind is expensive at the Mini dealer for sure and sometimes you still don't achieve peace of mind (at least in my case). They quoted me several thousand more $ to fix an electrical issue causing all sorts of codes and they still didn't guarantee me, so I said no way... It turned out to be an intermittent bad main relay between the computers in the engine fuse box (luckily I found and figured this out on my own). $40 relay. The page of codes went away after the fix.
Old Apr 19, 2024 | 09:05 AM
pluffmud's Avatar
pluffmud
I hear you - I figured I could have done all the work myself, but this go round I needed it fast and with a warranty as my wife will be using it - so I'm biting the bullet this time. Our independent Mini shop is very good, so I at least have no uneasiness about their work - I will never take it to a dealership. Anywho, the 2007 R56 is all mine now, so between that and my 2001 Rodeo Sport I'll have plenty to do - maybe I'll make the R56 into a track car and spend my Saturdays running in to hay bales and telling lies with a bunch of old farts like me.
Old Apr 20, 2024 | 03:36 PM
eljay's Avatar
eljay
As I'm sure you already know since you own R56, the first thing a Mini owner must do: clean those sunroof drains behind the wheel well liners!
Old Apr 20, 2024 | 04:07 PM
pluffmud's Avatar
pluffmud
The R56 throwing 0420 code - the O2 sensors replaced a few months ago so I'm afraid it might need a new cat - MPG down from 35 to 34.5. Have to take the front damn near apart for that job. Not looking forward to that. R60 exhaust looks new, no codes, but I don't have detailed service records.
Rs812
Aug 2, 2021 06:54 PM
CzyKats44
Oct 26, 2017 04:22 PM
loifs8
Suspension
May 9, 2016 02:51 PM
Roxspin72
Suspension
Mar 16, 2015 07:58 PM
z3bum
Electrical
Jul 18, 2012 07:55 PM
