R60 Oil level - not easy
Old Jan 17, 2022 | 11:42 AM
stiksandstones's Avatar
stiksandstones
New to me Countryman, 49k,
checking the oil level “seems” overfilled? But then again this dipstick kinda sucks right?
any thoughts?
Old Jan 18, 2022 | 03:16 PM
Dhynes's Avatar
Dhynes
I found this on the web.
Old Jan 18, 2022 | 06:38 PM
navwizard's Avatar
navwizard
The dipstick is a horrible design.
I use the trick where I wipe it off, then insert it only up to the yellow base, so not all the way in. Do that three times wiping each time, then finally insert all the way to measure.
That method gets rid of the oil from the tube that gives you a false reading.
Or get the craven speed. $
Old Jan 18, 2022 | 07:45 PM
stiksandstones
Thanks, yeah, read some pros and cons about the craven....and some tips on putting some marks in the oem stick. Ill try your trick though and see if I get a better read.
Old Jan 24, 2022 | 07:37 AM
tommydoo66's Avatar
tommydoo66
They have a flexible dipstick on eBay. It has a end with holes. Easy to read. Think $15 or less. You have to cut it about 1 inch or so from them top depending on application. Take a look. Only problem is that the handle is metal and gets hot when checking when engine is hot,
hndle
Sep 7, 2021 12:45 AM
davidg5700
Nov 26, 2013 06:46 AM
mimithemini
Dec 30, 2011 06:07 AM
MiniStupidfun
Sep 21, 2007 03:21 PM
mufflethis
Aug 24, 2007 06:55 PM
