R60 Can you tie off brake pad sensors
Old Nov 20, 2022 | 07:57 AM
Coochas's Avatar
Coochas
Hi,
I searched a bit but couldn't find the R60 specific answer.
I'm getting ready to change the pads on a 2015 Countryman JCW and am wondering if I can just zip tie the pad sensors out of the way (no warning lights).
TIA
Old Nov 20, 2022 | 08:23 AM
MReiland's Avatar
MReiland
The sensors are on their own wire and clip into the brake pad. If they are already tripped then you will probably need to short the wire somehow on your own to make the connection again. They can be tied back all the way to where there is a connector in the wheel well if you don't want them to ever trip again. If they aren't worn through yet, even though they say to replace them with the pads, you can reuse them. They are also pretty inexpensive.
Old Nov 20, 2022 | 08:27 AM
Coochas's Avatar
Coochas
Originally Posted by mreiland
the sensors are on their own wire and clip into the brake pad. If they are already tripped then you will probably need to short the wire somehow on your own to make the connection again. They can be tied back all the way to where there is a connector in the wheel well if you don't want them to ever trip again. If they aren't worn through yet, even though they say to replace them with the pads, you can reuse them. They are also pretty inexpensive.
thanks
Old Nov 20, 2022 | 02:05 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
My suggestion would be to get new sensors and wire them out of the way. An old, worn sensor will trigger the brake warning and not allow the service counter to be reset.
Old Nov 20, 2022 | 02:08 PM
Coochas's Avatar
Coochas
Thanks. I will do this.
Old Nov 29, 2022 | 12:16 PM
Leora83's Avatar
Leora83
Or just wire the two old sensor wires together, tape it up, then tie them out of the way. I can't imagine why you'd buy new sensors just to not use them, even if they aren't very expensive aftermarket.
I did this on my 2013 JCW then reset the brake service light. No issues.
minimtx
Oct 17, 2019 07:12 AM
Solamar
Jun 13, 2018 04:40 PM
njaremka
Nov 5, 2017 07:44 AM
PSU 98
Jan 5, 2015 11:11 AM
pimpedout97x
Tires, Wheels, & Brakes
17
Feb 20, 2008 05:17 AM
