Drivetrain Reuse Brake Pad Sensors?
Yes you can. EBC Red Stuff and Brembo Ceramic and popular low dust pads. One of the listed vendors carries them. I frequent Way: https://www.waymotorworks.com/
Vendor
On the R56 once the sensor is worn half way it has to be replaced and can't be reused as the car uses them to calculate how far they can go on the remaining pad. So once the sensor is worn half way the computer knows and calculates how long they will last based on how long it took to get half way.
We do keep them in stock
https://www.waymotorworks.com/brake-...5-r56-r57.html
Moderator
I've re-used them....the only problem is that the plastic can become very brittle and break when you re-install them....leaving you with a warning light until you get a new one. I like the OEM sensors best....they just seem to fit better...length of wire and insert nicely into the pad.
On a car that you don't put lots of miles on and have the opportunity to inspect...like when you change wheels for events, then tieing them (unworn ones) off isn't a big deal.
