R56 brake wear sensor ?
brake wear sensor ?
I'm already planning some work to my Mini, pre- spring inspection time, and figured I'd put some new brake pads in. I understand the Mini also has two brake wear sensors, but if the pads aren't worn to the point that it triggers the sensors is it still a good idea to replace them or can I just leave them be?
Can someone explain to me exactly how the brake wear sensors function on these cars?
The R56 and newer sensors are "smart" sensors so as long as they are not worn half way through you can get away without replacing them. Once they are worn half way through the computer knows how many miles you put on the pads to get half way. It then makes and est on how long it will take to wear through the rest of the pads giving you mileage count down you see in the tach.
We keep them in stock if you need em:
http://www.waymotorworks.com/brake-p...5-r56-r57.html
I bought aftermarket, NAPA. My mechanic said the fittings were the same and it worked, but some of the other bits (clips?) to route the cable were different. He got it to work because that is what he does.
1. Because the sensors are plastic and have been exposed to heat etc, don't be surprised if they crumble as you try to remove them from the pad .. even if they are "good"
2. Folks who do their own maintenance often find the sensors to be a bit silly .. we monitor our pads and know when to change them. You can tie a good sensor back away from the pads, or just clip the wires on a used sensor and tie the ends together which will tell the computer "all is well" and you just monitor your wear ... EASY
The sensor is held into the brake pad recess by a stainless steel clip. If you try to remove an un-triggered sensor, this clip will often 'ping' off somewhere you can't find it, so I use a new sensor each time.
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
Aug 25, 2015 09:18 AM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
