2002 MCS NOT have brake pad sensors?
Old Jun 11, 2018 | 04:30 PM
Solamar's Avatar
Solamar
Does a 2002 MCS not have the brake pad sensors? My parts guy said he does not show them for that year, the pads do not currently have sensors and I haven't located the unused plugs anywhere...
Old Jun 11, 2018 | 05:00 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Would think Realoem would have a diagram showing they are either there or not.
Old Jun 11, 2018 | 05:05 PM
MINIAC's Avatar
MINIAC
No brake pad wear sensors on 2002.
No manual boot release on 2002.
Old Jun 11, 2018 | 08:43 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
so much to learn, so little time
Old Jun 12, 2018 | 08:58 AM
MINIAC's Avatar
MINIAC
More early model year trivia ...
Alloy pedals didn't appear on Cooper S models until December 2002.
The power steering fan shared the same electrical circuit as the radiator fan until January 2003.
This meant that if road debris jammed the power steering fan causing the common fuse to blow, the radiator fan would not operate and the engine would overheat.
Putting the power steering fan on a separate electrical circuit was covered under warranty per Service Bulletin M320104.
The power steering fan was unprotected by a grille until October 2003.
For protection many owners added an aftermarket shroud like the stainless steel one shown below:
Old Jun 12, 2018 | 09:15 AM
Solamar's Avatar
Solamar
Great info Miniac, Thank you!
Ive wondered about the comments when disconnecting your battery to be sure not to close the boot. Now i get it
Think I'll add the power steering shroud to my list.
Do the dealers track completed TSB's by VIN? Would they be able to give me a list of completed TSB's?
Old Jun 12, 2018 | 09:34 AM
MINIAC's Avatar
MINIAC
There is a recall on the power steering pump which includes a shielded fan ...
https://www.northamericanmotoring.co...ng-recall.html
If the power steering reservoir or supply lines in your car are leaking have them fixed before going to the dealer for the recall. These aren't covered under the recall and the dealer will gouge you to replace them when installing the new pump and fan.
Old Jun 12, 2018 | 09:43 AM
Solamar's Avatar
Solamar
I had the dealer do the title transfer smog check and at the same time check for open recalls. I specifically asked them if the power steering pump had been recalled and they said my VIN was excluded from the recall. Seemed odd... Wonder if mid 2002's had a different pump?
Old Jun 12, 2018 | 09:49 AM
MINIAC's Avatar
MINIAC
Check for recall yourself ...
https://www.miniusa.com/owners/tools...rt/recall.html
Old Jun 12, 2018 | 10:44 AM
Solamar's Avatar
Solamar
"2002 COOPER S US
No Open Safety and Emission Recalls Were Found For Your MINI"
Too bad they don't show closed recalls and when they were completed.
Old Jun 12, 2018 | 11:08 AM
MINIAC's Avatar
MINIAC
Perhaps the power steering pump on your MINI was previously replaced.
Old Jun 12, 2018 | 01:11 PM
Solamar's Avatar
Solamar
The dealer was able to pull up the complete vehicle history (just got off the phone with them) and my 2002 has only had 2 recalls performed. A crankcase ventilation hose and an ECU reprogram. The service adviser said my VIN is just outside the power steering pump recall.
Interesting, if nothing else...
Old Jun 12, 2018 | 04:10 PM
MINIAC's Avatar
MINIAC
What's the build date of your MINI?
Old Jun 13, 2018 | 01:37 PM
Solamar's Avatar
Solamar
Originally Posted by miniac
what's the build date of your mini?
7/11/2002
Old Jun 13, 2018 | 04:40 PM
MINIAC's Avatar
MINIAC
7/11/2002
Mine completed production on 5/28/2002 and is eligible for the recall.
I believe the pumps were upgraded sometime in February 2005. If your car was built prior that and is not eligible I would have to assume that pump is not the original.
HKSpeed
Nov 16, 2013 12:47 PM
Powashiftin
Tires, Wheels, & Brakes
Nov 23, 2011 09:28 PM
Case1220
May 8, 2010 08:44 AM
SKL
Oct 28, 2007 05:58 PM
