PDA
View Full Version : R59 :: Roadster Talk (2012+)
Pages : [1] 2 3
  1. R59 Missing Lower Engine Cover Bracket
  2. R59 Torque Solution Short Shifter
  3. R59 Passenger Seatbelt Warning After Seat R&R
  4. R59 Thoughts on wheel spacers
  5. R59 RETROFIT R59 or similar rear parking sensors
  6. R59 Wireless aa/carplay and backup cam installed
  7. R59 Run flat or regular all season tires?
  8. R59 Half cover recommendations?
  9. R59 Has anyone actually done an auto dimming mirror swap?
  10. R59 hood problem
  11. R59 Wheel Alignment Specs for the Roadster
  12. R59 Brand new to Mini
  13. R59 Body computer module
  14. R59 August Night
  15. R59 My new baby
  16. R59 Back glass has separated from convertible top
  17. R59 Top down time?
  18. R59 Error Codes for ALL THE LIGHTS!!!
  19. R59 Permanent Passenger Restraint System Malfunction Error Code? R59
  20. R59 Piston blow by ? ELectric conversions?
  21. R59 Covertable Top Drain Issue Water leak into Boot
  22. R59 Gages removed but which ones?
  23. R59 Paddle shifters inop, any suggestions?
  24. R59 R59 JCW Soft top not operating
  25. R59 Heavy rain - water in trunk
  26. R59 Mirror caps
  27. R59 Anyone have these on their car?
  28. R59 R59 US Spec Battery Removal "How To"?
  29. R59 2015 Roadster Copper S with 62K millage.
  30. R59 leaking connection
  31. R59 I saw this at the grocery store today !
  32. R59 I have ascended to the fixed wing Roadster ranks
  33. R59 Grip with Bridgestone DriveGuard Plus Tires
  34. R59 R59 Top replacement
  35. R59 Missing SAT icon for my factory radio
  36. R59 Rear spoiler stuck in upright position
  37. R59 Roadster trouble starting
  38. R59 Codding List / Help R59
  39. R59 Windows auto up?
  40. R59 R59 Sunshade
  41. R59 Pillar trims is R59 the same as R56?
  42. R59 Has anyone seen this interior?
  43. R59 ISO Roadster; advice?
  44. R59 Adjusting the rear spoiler
  45. R59 Help Identifying Part Underside
  46. R59 Snow chains on a Roadster?
  47. R59 Just fix something that you may need to know
  48. R59 Going from 195/55/16 RF to 205/55/16
  49. R59 Thermostat Housing Questions
  50. R59 Help me understand the shadow/black line rear lighting kits
  51. R59 what is this bumper trim part called?
  52. R59 Adding the belly pan kit (side panels) to a UK R59 - modification? JCW
  53. R59 Oil service display stuck at 3,100 miles
  54. R59 greasy carburetion N18 Cooper s
  55. R56 2013 Roadster badged as S JCW upgrade
  56. R59 Instructions for taking apart the bulkhead behind the seats?
  57. R59 Battery Replacement for 2014 Roadster S (R59)
  58. R59 Oil temperature sender location on N18?
  59. R59 r59 Black Headlights
  60. R59 HEATED SEATS in ROADSTER
  61. R59 roof not working! as of this morning
  62. R59 Persistent problem even after engine rebuild
  63. R59 All sound stopped working
  64. R59 Audio unit upgrade
  65. R59 3rd brake light replacement
  66. R59 Metal oil filter housing cap?
  67. R58 Rear floor boards wet
  68. R59 "Sport" Mode Button ...
  69. R59 Carbon Fiber Mods !!! for the JCW Roadster ...
  70. R59 Aux Input Volume Stuck on Mute
  71. R59 Tpms
  72. R59 MINI Retrofit Xenon Headlights
  73. R59 Scan tool recommendations?
  74. R59 Conveneient ground connection/post inside the cabin?
  75. R59 I need info on these fuse pictograms
  76. R59 Race Chip
  77. R59 New R59 JCW Owner !!!
  78. R59 Rear suspension camber R59 coupe
  79. R59 2014 Mini Cooper S Roadster R59
  80. R59 Rear spoiler compartment filling with water
  81. R59 Hello, new R59 owner here
  82. R60 2013 countryman oil filter cap leaking oil
  83. R59 Just bought a 2015 JCW roadster with 4200 miles. This will be my build thread.
  84. R59 Fuel Tank Filter replace
  85. R59 want a FREE new top?
  86. R59 Wilwood Tips
  87. R59 Engine cut out into limp mode
  88. R59 Leather seats care
  89. R59 Boot under panel removal
  90. R59 What is the name of these cross braces?
  91. R59 Pre Purchase Inspection Points for 2012 R59 S
  92. R59 Aero kit for 2014s roadster
  93. R59 Looking for opinions/suggestions what to do next? Mods
  94. R59 new to me R59 and first mods
  95. R59 2014 Roadster top issue
  96. R59 195/55R16 runflat noise...Hankook H426 experience?
  97. R59 A new issue for a new day
  98. R59 Looking at lowering springs NM or AST?
  99. R59 Playing with my R59 Need help
  100. R59 Need Help Accessing Area Under Roll Bar
  101. R59 Intermittent A/C: fan, resistor, or ???
  102. R59 Cockpit Cover
  103. R59 Seat Belt Jam
  104. R59 Rust Problems
  105. R59 JCW engine bay emblem
  106. R59 Buying A Roadster~Any Input on this Car?
  107. R59 Buying A Roadster~Input Needed
  108. R59 Recaro Seat Option
  109. R59 Openometer Delete - 11/2018
  110. R59 New Owner - Origin Story
  111. R59 Gp2 calipers on a white silver roadster
  112. R59 Fun day in my R59
  113. R59 Painting Bits
  114. R59 Good sales price?
  115. R59 OEM suspension option quandry
  116. R59 Fair Price
  117. R59 wtb-r59 in spice orange
  118. R59 Soft top error message...won't operate
  119. R59 Leather seat L to R swap
  120. R59 Footwell Module (FRM)
  121. R59 Wheel alignment spec
  122. R59 Anyone knows this JCW 13 r59 from GA?
  123. R59 Engine Temperature
  124. R59 Bass Reinforcement
  125. R59 New to me 2013 Roadster
  126. R59 My R59 JCW from South Africa
  127. R59 Top down rattle fixed.
  128. R59 Roadster top failure!
  129. R59 Car/Options List question.
  130. R59 Way to clean the boot cavity?
  131. R59 Equipped for the long haul...
  132. R59 Re: Door Lock
  133. R59 r59 active rear spoiler stuck up
  134. R59 Changing incandescent bulbs to LED or brighter bulbs
  135. R59 Stuck antenna mast!
  136. R59 Aiming Bi-Xenon headlights
  137. R59 Need Seatbelt tensioner help
  138. R59 Just bought 2012 JCW Roadster
  139. R59 Wife wins First pLace in Car Show
  140. R59 2013 Roadster Battery replacement?
  141. R59 is your R59 still under warranty?
  142. R59 New to the Mini. Hope to learn a lot.
  143. R59 Roadster 3rd brake light, cosmetic change
  144. R59 Possible NAM Changes & Updates
  145. R59 Countryman Section Discussions
  146. R59 Catless Downpipe for roadster
  147. R59 Your thoughts on NAM going political
  148. R59 Tried fuel filter replacement DIY in r59 yet?
  149. R59 Would you buy one of the very 1st roadsters ?
  150. R59 bmw/mini snap in adapter?
  151. R59 Considering selling 13 Roadster
  152. R59 Headrest Fairing?
  153. R59 Nuts in air cleaner
  154. R59 Dms stage one 183kw
  155. R59 Manic Roadster?
  156. R59 R59 A/C problems
  157. R59 How to Remove R59 3rd Brake Light
  158. R59 Balance on the edge
  159. R59 New R59S Owner, 100% British Garage
  160. R59 What is the little stump to the right of the tach on the R59?
  161. R59 Roadster front license plate surround
  162. R59 Bird bombed
  163. R59 Rear View Mirror Cover
  164. R59 Just took this home!
  165. R59 Best way to add some exhaust noise?
  166. R59 ▀▄▀▄▀▄▀ PLEASE READ: Before creating a new thread!▀▄▀▄▀▄▀
  167. R59 How long have you had your car?
  168. R59 New-to-me R59
  169. R59 Driving hat?
  170. R59 Show your "Fun Size"
  171. R59 Class of 2013!
  172. R59 Front of my roadster wrapped in XPEL
  173. R59 Growing NYC MINI CLUB (NY MINIons)
  174. R59 My ROADSTER arrived last night
  175. R59 Getting ready to pull the trigger
  176. R59 Stock Speaker Install HELP
  177. R59 Front Bumper Removal on R59 S
  178. R59 Nope
  179. R59 Reading the damn oil level
  180. R59 Potential purchase advice
  181. R59 Maintenance mileage indicator
  182. R59 Sadly saying goodbye...
  183. R59 Thinking of a roadster for spring-summer
  184. R59 New MINI Roadster S video!
  185. R59 One touch window for my Roadster friends...
  186. R59 Tires and ennui on 2013 Roadster
  187. R59 R59 brake change - What's needed?
  188. R59 New Owner, lots of questions, factory workshop manual ?
  189. R59 Spoiler wrapped
  190. R59 Tempted to keep it!
  191. R59 Roll Cage
  192. R59 Westchester mini meet/cruise tommo
  193. R59 How to keep spoiler UP all the time?
  194. R59 Help with map light and puddle lights not working
  195. R59 Extended Warranty????
  196. R59 New-to-me 2013 Roadster JCW - WOW!
  197. R59 MINI Takes The States
  198. R59 CoverKing Seat Covers Installation and Review
  199. R59 Just got my first-ever MINI! <3 (2015 Roadster S)
  200. R59 New 15 orphan
  201. R59 Just received car back from body shop and have issues(new forum member)
  202. R59 JCW Underbody panels
  203. R59 Hello Jackson - Goodbye Trinity
  204. R59 Is it normal for manual 2014 roadster s transmission and flywheel replaced
  205. R59 New Mini Roadster
  206. R59 Stiff Door Handles
  207. R59 Said goodbye to a good friend!
  208. R59 JCW intake
  209. R59 Chrome rear fog trim
  210. R59 New Summer tires, what best?
  211. R59 Four years today!
  212. R59 Woo hoo! New (to me) Roadster!
  213. R59 New Member - one question
  214. R59 18" runflats on R59, unbearable ride?
  215. R59 how to install a Mouting strip, cover, firewall.
  216. R59 Total Number of Roadsters Produced?
  217. R59 2014 Pepper White
  218. R59 Oil light?
  219. R59 Would you buy one that had been through auction?
  220. R59 Pulled the trigger!
  221. R59 2015 R59s: ditch the run-flats?
  222. R59 Okay- one more question. Thanks in advance!
  223. R59 New Roadster???
  224. R59 Considering a 2012 JCW roadster
  225. R59 Pass through?
  226. R59 7 Deals of Christmas Holiday Sale!
  227. R59 R59 Dashcam Hardwire, "A" pillar question
  228. R59 Roadster tire wear
  229. R59 R59 known issues
  230. R59 R59S tire speed ratings?
  231. R59 What am I missing?
  232. R59 Mama's new wheels
  233. R59 Should I be wary?
  234. R59 Brought home a Mini
  235. R59 R59 vs Z4
  236. R59 R59S 41 PSI on the door jam sticker?
  237. R59 JCW Exhaust
  238. R59 Wood trim interior
  239. R59 Roadster floor liners
  240. R59 Rubber Seal Separating
  241. R59 2015 MX5 might be the answer..
  242. R59 Sunscreen recomendations
  243. R59 Mileage?
  244. R59 M7 Speed Major Announcement!!!
  245. R59 Any loaded 2015 S Roadsters out there??
  246. R59 Any changes?
  247. R59 All about your roadster today!
  248. R59 Motorin' Noob No Longer?
  249. R59 M7 Speed Father's Day Sale
  250. R59 What to do?
