R59 greasy carburetion N18 Cooper s
hi guys, i have a problem with my mini roadster cooper s n18 with a stage 3 rpm, with the catalyst removed. A few weeks ago the car started to have a very greasy carburetion, before it was perfect, the car emits black smoke and soot, as well as stinks from the exhaust. I don't know if it is related to this but every now and then at full acceleration I have super knocking on one or two cylinders random. I have no errors in the dme, I have done several scans but I only find super knocking codes.
Stage 3 means you have meth injection? (at least it should have meth) The black exhaust is normal for a car with no cat and a tune. Running rich with fuel means black smoke on boost. Super knock codes means you’re running on the ragged edge of timing. Anything from bad gas to bad plugs or coils could also be an issue. What are your engine mods?
Check your plugs, and check down in the spark plug holes. After I sprayed my engine off, water was down in the holes and caused a knock code for me. I dried the holes out the best I could with plugs, then swapped plugs, drying the rest with plugs out. Then did a just in case oil change. Everything has been good.
unfortunately using the translator I did not understand your last message, but I can tell you about the sparks that are new, they have very few kilometers.
Matej
Jan 20, 2026 11:30 PM
