PDA
View Full Version : R58 :: Coupé Talk (2012+)
Pages : [1] 2 3 4 5
  1. R58 Anyone kno how to remove headliner
  2. R58 Electrical Problems
  3. R56 NGK 97968 spark pugs gap adjustment
  4. R58 What ecu wire is tach signal
  5. R58 Bumper Identification S or JCW for R58
  6. R58 Picked up a 2012 R58 S and Rotors Wanted / Discussion
  7. R58 R58 JCW Water / Spoiler / Footwell Issues
  8. R58 Oil pump replacement
  9. R58 Anyone lower the drivers seat with a different bracket?
  10. R58 What shocks would you use ? Car pulling going over bumps
  11. R58 Speaker Upgrade
  12. R58 Picking up R58 JCW and no boost
  13. R58 Newbi jcw coupe
  14. R58 R58 Rear water leak
  15. R58 2012 jcw r58
  16. R58 Tail light ghost
  17. R58 Fitting and retraction of R58 Wing
  18. R58 Front bumper cover
  19. R58 Trans
  20. R58 My "Racing GT" R58 Spoiler Solution from eBay + 3D-Printed Braces
  21. R58 Friggin deer
  22. R56 No power to fuel pump
  23. R58 Increased battery discharge issue
  24. R58 Do these fit the R58
  25. R58 Coolant leak and then none
  26. R58 C pillar trim removal
  27. R57 DIY Top Replacement
  28. R58 Not another exhaust question?
  29. R58 Horn suggestions
  30. R58 ECSTuning??? Side marker lights...
  31. R58 Lights/electrical
  32. R58 Fog lights OEM? '12 JCW R58
  33. R58 Reverse Camera 2015 R58
  34. R58 R58 Digital Rear View Mirror???
  35. R58 Donor car teardown
  36. R58 Anyone try using an Altronix timer to default spoiler to manual mode?
  37. R58 Low on power, out of ideas R58 S
  38. R58 Bummer of a day
  39. R58 2014 R58 JCW suspension question
  40. R58 Coupe S to JCW Caliper Conversion Q’s.
  41. R58 What year R58 JCW is best?
  42. R58 Mini R58 ISSUES!
  43. R58 Value advice on 2012 R58 S
  44. R58 How rare is this?
  45. JCW Battery Train
  46. R58 Coolant leak and mysterious loose hose
  47. R58 I'm Back! And I need some input
  48. R58 Questions on a few odd things.
  49. R58 Extended coverage
  50. R58 Missing interior pieces
  51. R56 New to the group, help is appreciated!
  52. R58 Front window chip
  53. R56 Delete
  54. R61 At my wits end needing some help or advice
  55. R58 Shocks Struts
  56. R58 For Sale
  57. R58 Did a little off roading in the Coupe
  58. R58 Lost key Fob
  59. R58 combustion misfire, cylinder 2
  60. R58 Acceration Lag/hesitation
  61. R58 Acceration Lag/hesitation
  62. R56 How to diagnose code P0087 fuel pressure to low
  63. R56 How to diagnose code P0078
  64. R58 xenon
  65. R58 Samakhan's R58 build thread
  66. R58 FS: '14 JCW Coupe $18K
  67. R58 Had some codes and limp mode
  68. R58 Restraint System Malfunction due to water, but now it is gone?
  69. R58 radar detector hardwire help
  70. R58 Do I Really Want an R58 or Keep the R56?
  71. R58 Next Friday's fun drive
  72. R58 Front end clunking noise on bumps
  73. R58 LED Fog Light Question
  74. R58 How rare are they
  75. R58 Twin Tubro/Supercharge
  76. R58 Timing Chain Tensioner install question
  77. R58 Stripe removal
  78. R58 Stripe specs
  79. R58 Shock Strut Absorber replacement
  80. JCW R58 idle sound
  81. R58 3RD Brake Light replacement.
  82. R58 2013 JCW Coupe Keyfob Issues
  83. R58 Retrofit union jacks R58 coding
  84. R58 Engine cutting out
  85. R58 Had to buy another
  86. R58 Mike's R58 MINI Cooper JCW Build
  87. R58 N18 over heating after new temp sensor
  88. R58 Whining noise under load
  89. R58 2013 r58 N14 base model coupe using oil
  90. R58 Clueless in Seattle, head light bulb question.
  91. R58 Dealer scam?
  92. R58 Water under carpets behind seats.
  93. R58 Build thread: 2013 Cooper Coupé
  94. R58 TB question
  95. R58 Bonnet / roof stripes - suggestions?
  96. R58 need opinions and info
  97. R58 Turbo oil supply line replacement labor cost
  98. R58 I need information to buy.
  99. R58 “Amber” Turn Signals in Rear Light Units ???
  100. R58 What Should I be Looking out for on this 2012 Coupe with 100,000 miles ?
  101. R58 leak coolant
  102. R58 How many R58/R59 were built?
  103. R58 Shock and Coil Spring Assembly question
  104. R58 Tell me about oil catch cans
  105. R58 WTB *** JCW MINI Hardtop Coupe ***
  106. R58 Greetings from the North
  107. R58 Trouble codes
  108. R58 Scan Tool Brake Light Test
  109. R58 Suspension Refresh
  110. R58 Traction Control Module Location?
  111. R58 Need help deciphering MINI messages
  112. R58 Grill Trim, 2015 JCW Coupe
  113. R58 Limp mode - p2101, p1638 - throttle body issues
  114. R58 Installed JCW brakes and tuning kit
  115. R58 Big Brake Kit
  116. R58 GP Coupé Project
  117. R58 New Coupe JCW Owner
  118. R58 Anyone own this cover?
  119. R58 Reduced power warning light?
  120. R58 Valve Controlled Exhaust for R58 JCW Suggestions?
  121. R58 Request for Info/Advice on Coupe S/JCW Issues from potential owner
  122. R58 The JCW Coupe is Gone.......
  123. R58 I have a pair of Cocomats for someone's Coupe.
  124. R58 2013 Coupe tail gate open light
  125. R58 Adios to the 2014 JCW Coupe
  126. R58 buy coupe JCW
  127. R58 backup (reverse light) not working on 2012 R58 JCW
  128. R58 upgrade intercooler or not?
  129. R58 water in passengers side, engine cranks but does not start
  130. R58 Need opinions on some wheels.
  131. R58 Need opinions on some wheels.
  132. R58 Need Help finding R58 parts.
  133. R58 I need a small light cover on rear bumper
  134. R58 Battery Replacement
  135. R58 Pathway lights
  136. R58 Oil pump solenoid repair kit
  137. R58 2012 Coupe S Longevity
  138. R58 DAB aerial location?
  139. R58 Rear Wing ideas for my R58 JCW?
  140. R58 Body kits for the f58
  141. R58 Well... the time has come, saying good bye to my Bonnie
  142. R58 Cold air intake?
  143. R58 Driver Seatbelt roller cover squeeks/crunches
  144. R58 R58 S front park lights
  145. R58 B pillar cover
  146. R58 Tires/ Rims/ Track Days
  147. R58 Hard Start - Sputter - Stall - on cold starts
  148. R58 Wheels Questions
  149. R58 Best short shifter and coil over
  150. R58 JCW Exterior Bodyparts
  151. R58 '13 Cooper S a Better Option??
  152. R58 Oil Catch Can Help
  153. R58 Oh, how it feels so good to be back.
  154. R58 I need new headlight rings!
  155. R58 How does the smart alternator system work?
  156. R58 Power supply/cig lighter doesn't work
  157. R58 iCarSoft Review
  158. R58 New floor mats :)
  159. R58 Squeak, squeeling noise
  160. R58 My Bonnie and a quick recap after 88K miles, 6 years of owning..
  161. R58 ? About sirus xm
  162. R58 My 2015 S Coupe
  163. R58 Did my 1st oil change myself
  164. R58 Water Pump Replacement
  165. R58 What is this sensor? Or part?
  166. R58 Questions on buying used 2012 Coup
  167. R58 Car alarm?
  168. R58 Handling quirk
  169. R58 Recommendations for R58 Cooper S daily/track build
  170. R58 Stock Roof Stripes
  171. R58 Opinions
  172. R58 Best 1st mod
  173. R58 Lowering spring
  174. R58 Radio Code?
  175. R58 Coming out of warranty
  176. R58 Help to decide on a stripe
  177. R58 value question on '13 Coupe S
  178. R58 Tire size
  179. R58 Crack in windshield:(
  180. R58 What Did Your Mini Do For You Today?
  181. R58 Frozen wiper washer fluid
  182. R58 New owner
  183. R58 Seat height modification?
  184. R58 water leak from driver's door seal
  185. R58 Seat swaps
  186. R58 Broken Hood Latch
  187. R58 Great price on wipers
  188. R58 Price Check on 2015 Coupe S
  189. R58 Door Puddle Lights........
  190. R58 Seeking knowledge / help for troubleshooting Issues
  191. R58 Cat Back system
  192. R58 Sway bar question
  193. R58 Summer RF Tire
  194. R58 Hood Surround Chrome Trim Fasteners......
  195. R58 Broke down and got one
  196. R58 Service manual needed for r58
  197. R58 Brake boots
  198. R58 steering wheel cover
  199. R58 R58 rear reverse/fog light removal
  200. R58 R58 2014 Several Questions
  201. R58 Recall
  202. R58 Coupe Speedo/Radio/Navigation
  203. R58 Destroyed the R58 Stripes...Help
  204. R58 Will the 2013 Mini Coupe be a classic??
  205. R58 Extended Warranty for a 2014 Mini Coupe S R58
  206. R58 Anyone looking for a JCW rear sway bar
  207. R58 Why are my Vogtland drop springs higher in front?
  208. R58 Tire Sensor part
  209. R58 My Bagged 58
  210. R58 Picked up a bruised '14 today, here goes the rebuild
  211. R58 My Bonnie and Coupe Update: 4 1/2 years later
  212. R58 Dash/rear cameras
  213. R58 Possible NAM Changes & Updates
  214. R58 Countryman Section Discussions
  215. R58 Has Anyone Driven the mk7 GTI?
  216. R58 Brake question
  217. R58 Your thoughts on NAM going political
  218. R58 Coupe Wiper Blades.......
  219. R58 In love but worried or “My R58 Coupe S vs MN winter”
  220. R58 Sway bar installation
  221. R58 Driver Sports Seat Backrest.......
  222. R58 How to tell the difference
  223. R58 scooter lift
  224. R58 MarioKart catless dp CEL lights?
  225. R58 Installing new Mini LED Fog Lights
  226. R58 Oil pressure range
  227. R58 high flow downpipe vs factory downpipe
  228. R58 Brake light bulb carrier/housing
  229. R58 Installing Cover Flap, headlamp washer
  230. R58 Radar detectors
  231. R58 Good source for side mirror caps
  232. R58 2013 Black Roof Paint Code.........
  233. R58 Hood scoop
  234. R58 Cabin Microfilter..............
  235. R58 2012 and 2014 coupes same car?
  236. R58 Window Problem on 2012 Coupe S
  237. R58 r58 coupe with 16 inch wheels
  238. R58 I'm gonna do the Stage 1 Tune (finally).
  239. R58 Door handle replacement
  240. R58 2013 coupe s
  241. R58 Roof Spoiler Removal
  242. R58 Oil Pressure Gauge install
  243. R58 2013 Grill Trim
  244. R58 Oddball R58
  245. R58 Best Exhaust Mod for R58
  246. R58 Aftermarket tail light question
  247. R58 What else can I do to get more speed on my R58?
  248. R58 Missing sensor below intake pipe?
  249. R58 ▀▄▀▄▀▄▀ PLEASE READ: Before creating a new thread!▀▄▀▄▀▄▀
  250. R58 Love my Coupe S; are they collector's items yet?
