R58 Retrofit union jacks R58 coding
Old Nov 17, 2021 | 10:09 AM
Fatalix's Avatar
Fatalix
Did a retrofit of tail light union jacks on a 2014 R58 mini.
Im having troubles disabling rear brake light errors. These are the only faults indicating.
Ive added FSW_PSW.trc read out from car. FRM software is FRM3_R56.C36, anyone can take a look at it and correct whats wrong and needed?
WARMUE_BL_M2_43_M2_9 and KALTUE_BL_M2_43_M2_9 was already set to "nicht_aktiv".
But still FRM indicates brake light faults in ISTA. CC_MELDUNG_BL only has got wert_01 to wert_04 values, would of thought this one shouldve been "nicht_aktiv" but according to NCS Dummy hex values are already "00,00".
Did also code the exact same parameters as retrofit of lci rear lights for BMW E89 series with same FRM module, but still fault shows up. Need desperate help!
File Type: zip
Old Nov 17, 2021 | 01:45 PM
We have Union Jack that fit the R58, no coding? https://www.ecstuning.com/b-helix-pa...oupe-cooper_s/
Maybe you did not get the correct ones or the pre 2011 versions?
Matthew Hallmark
Apr 16, 2021 01:41 PM
volksfragen
Electrical
Feb 5, 2021 08:17 PM
AlexFac
Sep 17, 2018 04:45 AM
troylees
Electrical
May 11, 2013 12:18 PM
qwertmonkey
Jul 30, 2006 08:51 AM
