R58 What shocks would you use ? Car pulling going over bumps
Old Nov 20, 2025 | 09:51 AM
Meanygreenie's Avatar
Meanygreenie
Hi! Hope every one is doing well !
im looking to get a few parts for the 14 mini cooper coupe jcw - so far so good with the car !
any one install new shocks all around ?
My car has been pretty harsh over bumps and on some bumps it pull quickly to one way or the other , on the highway it could be a little nerve racking !
do you guys have that ?
how do you fix it , is it the suspension?
I would like to make it’s but better maybe softer, but I know it’s a jcw so harsh ride maybe it ?
any suggestions of correct parts or thoughts appreciated,
Old Nov 20, 2025 | 10:16 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
How many miles on the car?
I would be tempted to upgrade the lower front control arm bushings to poly first. When those go out, handling will be inconsistent at best.
That being said, for shocks, I would recommend Bilstein B6 all around for best handling option. Damping will be spot on for the JCW.
If replacing shocks, also consider this installation kit:
https://www.ecstuning.com/b-assemble...1306772749kt4/
Old Nov 20, 2025 | 01:37 PM
Fly'n Brick's Avatar
Fly'n Brick
+1 on Bilstein B6.
Old Nov 20, 2025 | 04:59 PM
Meanygreenie
hi !
the car has 60,000 miles . So not super high -
but thanks for the advice on the bushings , handling is a bit off -
ill check out the bilsteins , thank you very much -
Old Nov 21, 2025 | 03:43 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
At 60k miles the OEM shocks are likely done. The rubber control arm bushings at 10+ years are likely done, too. Way Motor Works sells pre-installed Powerflex control arm bushings. They can be swapped without fully dropping the subframe, but much easier if you can. I would start with the bushings, and see how the car responds.
Old Nov 21, 2025 | 04:35 PM
MCS02's Avatar
MCS02
MINI Alliance Ambassador
You can check the control arm bushings by kicking the front of the front tire and see if it moves any. But I agree with @njaremka
sidthekid
Feb 21, 2012 06:45 PM
sgachko
Suspension
14
Dec 26, 2011 04:49 AM
rick714
Suspension
Dec 22, 2008 06:26 AM
mcswrks
SCCA Solo and ProSolo
44
Nov 16, 2006 02:58 PM
blammo
Suspension
16
May 23, 2006 04:17 PM
