Suspension JCW Suspension VS Koni FSD
Originally Posted by rick714
Any thoughts which would be better?
2006 MSC /wJCW, R99 wheels, Toyo T1R tires...
Here's my before/after with FSDs (scale 1-10; 10=best)
Cornering: before-7 after-9
Ride quality: before-5 after-9
Lowering springs and/or coilovers
Ride quality: before-5 after-4
Originally Posted by Kellzir
So you think the koni fsd's ride better than coilovers?
I would of thought that coilovers woiuld ride better than just shocks and springs. What coils have you tried?
they should work fine, however i do not think that the JCW springs lower the car visible enough, so i say is it worth it?
Hello,
I am probably going to go with a JCW suspension package w/o the shocks.
Think the Koni FSD's sound good marketing wise. Has anyone had experience with the FSD on an 07 MCS or other sport car?
Hearing so many bad comments on the sport suspension, not so on JCW.
But do not plan on doing track days. Just want a sweet ride on rogh roads as well performance when needed.
I will ask Koni about the shorter springs w/JCW than stock. If they respond to email.
I think that the JCW suspension is pretty good but it is a little firm and does not lower the car as much as some other aftermarket springs. On my 03 MCS I had H&R springs and stock shocks. On my 06 GP and have JCW springs and shocks. The JCW springs (on the GP) appear to have a higher spring rate than my H&R springs. I like the JCW springs/shocks better than the H&R springs and stock shocks. When I talked to Koni, they did not recommend the FSD with the H&R lowering springs, they suggested adjustable Koni yellows when using the shorter springs.
Your posts states JCW suspension vs Koni FSD but it is not clear to me what you are trying to compare. When you state JCW suspension do you mean JCW springs and JCW shocks? When you state Koni FSD, what springs do you plan to use with the shocks? It is the combination of spring rate and shock that is important. Also, you need to consider the type of driving you plan for the car and how low you want the car.
For a daily driver that you want just a little lower, the JCW spring and FSD shocks would work well. I think that the FSD would be fine with the only slightly shorter spring. That would make sense if you already have JCW springs and are just upgading shocks. If you are buying springs, you can probably find equivalent springs at less price.
How many miles did you put on that setup? What made you get rid of it? I ask because I'm considering this same setup.
Yep - and I'm still lovin the FSD's - perfect for my needs - about to add TSW springs to drop it a bit and will be golden.
Minibeagle
Aug 13, 2015 10:00 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
