R58 What ecu wire is tach signal
Old Mar 3, 2026 | 09:16 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Can someone please lmk what # and color wire from the ecu is the tach signal wire ? I am going to be installing a shift light very soon and I don't remember what wire I used to run the jcw shift light off in my last r58..
it is a 2013 jcw n18 r58 too btw...
Any help is always much appreciated !
Old Mar 3, 2026 | 12:26 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Try this guide:
https://motoringfile.com/howto/jcw_indicator.pdf
Linked from here:
https://www.minitorque.com/threads/rpm-signal-wire.53393/
Old Mar 5, 2026 | 05:36 AM
MiniManAdam
Community Builder
that is for r50/r53...
I need r58 ecu wiring output.i know it different than the n14s wiring also. That's my problem, I can't find **** on the pin layout or anything. ****ing typical, never any info on these r58/r59 especially the n18, most info is cross references from r56 which in most cases ARE WRONG.
and in the article, I still didn't see where it said what pin output in the ecu is tach signal. Thats all i need..
lol like wtf is this ?? No offense but geez , what a shitshow of instruction guide my god lol I can't make sense of their diagrams..
is that a pic of the back side of the obd port ????
I believe I connected my last one but that was my n14 but i swear I remembered something about pin#9 and it was a purple wire I believe ???
Old Mar 5, 2026 | 03:30 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
For an OBDII-compatible shift light, you can get the rpm readings from the OBDII port CAN-bus pins 6 (CAN High) and 14 (CAN Low).
Old Mar 5, 2026 | 04:00 PM
MiniManAdam
Community Builder
AWESOME , thx you !
does the high or low have and differences in the signal ?
I will probably have to halfway remove the port so I can see what color wires then correspond to those pins..
Old Mar 5, 2026 | 04:06 PM
Maybe, maybe not
Community Builder
I believe that an OBD-II compatible shift light must be connected to both pins 6 and 14. What specific shift light do you have and what do the instructions say?
Some shift lights require a single rpm signal wire, which is different from obtaining engine rpms from the CAN-bus.
Old Mar 5, 2026 | 05:39 PM
MiniManAdam
Community Builder
last time I hooked up a 3x wire shift light ( found my old thread ) this is the pin#/ wire color i used on my r53.. i must have used the same one on my last r58 because I never made a post about howto..
Old Mar 5, 2026 | 05:40 PM
MiniManAdam
Community Builder
That's the shift light I got again.
Old Mar 5, 2026 | 05:50 PM
Maybe, maybe not
Community Builder
Is OBDII pin 9 absent from or present in your 2013 R58?
If it's absent, you can use one of the coil signal wires for your shift light.
Old Mar 7, 2026 | 05:20 AM
MiniManAdam
Community Builder
I haven't checked my pin layout or anything yet but I will this afternoon because the shift light is finally out for delivery.
I'd like to get it installed before Monday so I can enjoy it on my 5hr round trip. I'm taking my older brother to go possibly bring home an r58 S..
lololol I took him for a ride in mine in October and I guess he's been hunting one down to buy ever since amd has one lined up in Indiana..
Soooo Id liiiiiiiiiike to have this in there then..
Old Mar 9, 2026 | 04:18 AM
MiniManAdam
Community Builder
Just encase anybody else searching this :
the engine speed/tach signal IS pin #9 ,violent w/ white stripe wire..
Old Mar 9, 2026 | 04:22 AM
MiniManAdam
Community Builder
I'm pretty sure this doesn't match our obd port.
my pins and wires were all different and pin #9 isnt listed in the pic and thats the one I used..
MiniManAdam
May 29, 2022 01:15 AM
jwconnexion
Sep 11, 2012 06:06 PM
NFCooper
Electrical
Jun 27, 2007 01:45 AM
wahwah
Dec 24, 2004 10:18 AM
