R58 Front end clunking noise on bumps
I think I have some sway bar bushings worn out. I am getting a heavy clunking noise whenever I hit a decent bump.
Any suggestions of what else to check/replace if I have it apart? In order to replace the bushings, I have to drop the lower subframe.
After searching multiple threads, it sounds like I should try the sway bar end links 1st. I wouldn't have to drop the subframe and they are reasonably priced.
Several post stated clunking noise in the front end order of precedence is end links, then sway bar bushings then front strut mount.
geekd4d
R60/R61 Stock Problems/Issues
Apr 14, 2020 07:13 PM
legweak
Jul 22, 2019 01:30 PM
tiny s
May 31, 2012 08:34 AM
