PDA
View Full Version : JCW Garage
Pages : [1] 2 3 4 5
  1. R50/R53 Loss of Power Steering
  2. GP3 Is there such a thing as a tune for the automatic on a GP3?
  3. JCW Replace while Tranny out
  4. R50/R53 De-Chrome Solutions
  5. JCW Best adjustable shocks / coilovers for 2025 JCW Convertible (F67) — comfort + track
  6. JCW F60 Hard Pipe Kits?
  7. F55/F56 Lowered my JCW with H&R spring
  8. JCW Anyone tried NM EVO power module for the 301HP Clubman/GP3
  9. F55/F56 What coilovers to replace EDC struts?
  10. JCW F56 mpg vs R53 mpg
  11. JCW Anybody have these rims?
  12. JCW Gen 3 boost and charge pipes: Plastic?
  13. JCW Rear Seat Delete - Also remove the seatbelts?
  14. JCW Titanium Lug Bolts?
  15. JCW Upgraded Intercooler for a stage 1 tune?
  16. R56 Looking for OEM Brake Kit for 2013 JCW Hardtop
  17. JCW JCW 2020 idle sound/noise normal?
  18. F57 2.5 Year Ownership Update
  19. F55/F56 FMIC recommendations?
  20. F55/F56 F66 JCW Wheels on F56 JCW? Spacer Size?
  21. JCW Help Identify JCW Exhaust Key Fob
  22. F55/F56 Review: LOVE the MDM Montage JCW Pro Exhaust Flap Solution!
  23. F55/F56 F56 JCW Test Results: Stock Tune vs BootMod3 93 Octane Stage 1
  24. R56 2021 JCW For Sale at Dealer -It Was Mine
  25. F55/F56 Who has added a Catch Can to the B48 JCW?
  26. JCW I/C upgrades for a 2020 Clubman jCW?
  27. F55/F56 antenna base removal
  28. JCW CAI Recommendation for 2020 Clubman JCW?
  29. JCW F54 jcw jb4
  30. JCW Recommendations for B48 catted downpipe?
  31. F54 2019 JCW looking to purchase
  32. F55/F56 14k Mile 2022 6-Speed JCW no reserve on EBAY
  33. JCW If a pre 06/20 B48e gets factory updates from dealer does it then need Femto unlock?
  34. GP3 2023 F54 JCW Clubman wanting a tune/piggback suggestion
  35. JCW F56 JCW BBS XR 17x7 ET +45 fitment
  36. F55/F56 Post Jun 2020 ECU cloning journey (ModdedMini.com)
  37. JCW Anyone know "new generations Cooper"?
  38. JCW Removing rear wheel arches
  39. F55/F56 B48 Engine Main and Rod bearing torque settings
  40. F55/F56 Rotors required to be replaced???
  41. JCW 2021 JCW and Eventuri intake.
  42. JCW Jcw manual clutch has anyone needed to replace it ?
  43. F60 Retrofit fog lights from S onto JCW?
  44. JCW Ready whenever you are, Winter!
  45. F54 Tuning options ...I can disable seasonally, or better yet, on the fly
  46. R50/R53 Racing Dynamics Header with Sport Cat
  47. F54 Brake pad options?
  48. F55/F56 EDC connector
  49. F55/F56 Wheel Spacers - make the rear equal to the front?
  50. F57 Snow Tire Rim Advice
  51. JCW What engine do I have? 2024 JCW F57.
  52. JCW Dinan Sport Performance Tuner - Yes !
  53. F55/F56 DME unlocking for 2020+
  54. F60 2022 JCW F60 Ceramic Brake Pads Recommendation Please
  55. F55/F56 Made a jump to 3rd gen
  56. F55/F56 Real Oem for 2022 build Jcw
  57. JCW Blackstone Oil Analysis @ 21k miles (8sp auto)
  58. JCW Software Tune only mod for 306hp 2.0 -which one?
  59. JCW 1 to 6 Matte Paint Protection Film?
  60. F55/F56 2024 F56 JCW mudflap Options?
  61. F54 oil change on 2020 Clubman JCW All4 - quick question
  62. JCW Summertime pic of my JCW convertible
  63. JCW Anyone Running H&R Lowering Springs On A 23-24 JCW?
  64. F55/F56 is there switched power when selecting "Sport Mode"
  65. F54 Drive train error - code showing spark plugs are worn out
  66. JCW F60 JCW Brake Squeal
  67. JCW Amazon- Cordless buffer/polisher - quick review
  68. JCW Roll bar and rear seat delete
  69. JCW Bad Transmission
  70. F55/F56 JCW 1 to 6 Special Edition
  71. JCW Dongle Recommendations?
  72. JCW F56 2019 B48D sub assembly torque specs
  73. F55/F56 Help Re attaching paddle shifter
  74. JCW Headlight LED Ring Swap
  75. F55/F56 do 18x8 JCW aftermarket F54 JCW Clubman wheels fit F56 JCW?
  76. R58 New battery for 2020 JCW Clubman $450!
  77. JCW TPMS replaced > no special tool required to reprogram
  78. JCW Navigation upgrade options!!
  79. JCW Remote tunes
  80. JCW JCW - Is an upgraded exhaust (still with muffler) worth it?
  81. JCW Just ordered 24 JCW F56
  82. JCW Retrofit 2025 DC tranny into an earlier Mini?
  83. R56 Lsd
  84. F55/F56 Who knows this Anniversary JCW?
  85. JCW Upgrade my intercooler, just for street use?
  86. JCW Will these wheels / tires fit?
  87. JCW JCW Brakes - Any way to make them engage more smoothly?
  88. F55/F56 Mods or Chip-Tuning, for more low-speed torque?
  89. F55/F56 loss of compression and warranty
  90. F57 Oil Changes 2024's
  91. JCW Brembo / rear caliper colour code?
  92. JCW F56 JCW shift
  93. JCW JCW Pro Exhaust
  94. JCW 2023 JCW 5,000 mile update > first oil change
  95. JCW Key Fob Upgrade JCW
  96. JCW Insane Brake Dust...
  97. JCW Anyone Makes Factory Style Mud Guards 2024 JCW
  98. JCW 17" wheel Fitment on my 2024 F56 JCW
  99. JCW Will 215-40-18 With 18X8 Et45 Work?
  100. F57 2022 and new JCW convertible loud?
  101. F55/F56 F56 sport steering weight override
  102. JCW dirty black oily substance under my '22 JCW
  103. F55/F56 Exhaust recommendations for 2021 MINI JCW
  104. JCW 2023 F56 JCW hardtop Ground Clearance
  105. JCW What Is This White Connector?
  106. F55/F56 Malone flash tune on F56 JCW manual
  107. F55/F56 Need help for a seat problem !
  108. JCW F56 LCI2 (22+) - JCW Pro or Remus exhaust compatibility
  109. JCW Springs and Sway Bar Done!
  110. JCW KWv2 without EDC on a car with EDC
  111. JCW Lowering Springs With Dynamic Damping?
  112. JCW What Size Wheel Spacers With 18" Wheels
  113. JCW Lowering Springs and Sway Bar Install
  114. F55/F56 Thinking of getting a Racing Dynamics Intercooler
  115. JCW Harman/Kardon Standard Feature?
  116. JCW What is this Trim Piece Called?
  117. JCW 17x7.5 JCW aftermarket enkei
  118. JCW 2022 JCW convertible brake sensor reset
  119. JCW 2023 F56 rear brake pads different?
  120. F57 Cold Air Intake Recomendations
  121. JCW sfactorfabrication splitters
  122. JCW 2019 Catted Downpipe Question
  123. F55/F56 just bought a 2018 from Carmax--thoughts?
  124. F55/F56 20K 2016 JCW Refresh
  125. JCW 2022 Mini Cooper JCW
  126. JCW 2023 JCW HT Nanuq white with Red Multitone roof
  127. JCW New 2023 convertible
  128. F55/F56 2017 JCW high milage/low wear
  129. JCW 2023 JCW Convertible in Detail
  130. JCW Lower Grille Difference (Hardtop vs. Convertible)
  131. JCW Finally Setting Up my 2019 Mini JCW 4 2023 AutoX
  132. JCW Any Rubbing Issues (JCW Coilovers/18x8 wheel)
  133. JCW A few questions.....possible reunite with JCW
  134. JCW reverse JCW stripes.
  135. JCW 2023 JCW convertible - One month Review
  136. JCW 2017 Hardtop JCW Build Thread
  137. JCW Just got a 2015 jcw
  138. JCW Just bought a 2023 JCW convertible > Rebel Green
  139. JCW 2023 JCW ride quality question
  140. JCW Zunsports grilles
  141. F54 Best Rear Spoiler For My JCW Clubman 22?
  142. JCW Dynamic Damping missing?
  143. JCW Lower Grille for 2023 JCW??
  144. F60 New plate fitted to Ricky
  145. JCW Powerflex Lower Engine Mount - Do It!
  146. F55/F56 New DP and Exhaust!
  147. JCW Just bought my first Mini! What should I know?
  148. JCW 2023 Blue leather Interior
  149. F55/F56 2020 Jcw changes
  150. JCW CG Valve Controller for JCW Pro Exhaust
  151. JCW New Craven Speed knob
  152. JCW New JCW need pop & bang
  153. R56 DME question
  154. JCW My new 2023 JCW
  155. JCW Exhaust Question for F56 JCW Owners
  156. JCW JCW Downpipe?
  157. F55/F56 Hood replacement on 2016 f56 JCW
  158. F54 2020 JCW Clubman - Oil Consumption
  159. JCW After 7800 miles on my '22 JCW Hardtop👍🏻
  160. JCW Anyone recognize this 2018 JCW
  161. JCW KW Suspension Dealers/Installers in SoCal
  162. JCW KW V3 - Setup & Experience
  163. JCW JCW Battery
  164. JCW Spark Plugs for Tuned F56 JCW
  165. F55/F56 how much rear camber after lowering
  166. F55/F56 60th Anniversary Edition JCW - pro exhaust?
  167. JCW Dinan stage 1 performance engine software - mini b46/b48 engine Reply Subscribed
  168. JCW 2019 F56 JCW Break Pad Replacement
  169. JCW Owners Club Signature Images
  170. JCW Rubbery shifting
  171. GP3 Anyone here prior owner?
  172. F55/F56 New tires after only 10k miles?
  173. JCW 2019 JCW: 215 to 225 tires need spacers?
  174. F55/F56 Screw MPG retake
  175. F55/F56 “Dinan X Tuning” anyone use or know of this?
  176. JCW Auto High Beams
  177. JCW New - to me…
  178. JCW Retrofitting GP3 intake to F56 JCW
  179. JCW 2022 JCW Clubman Dynamic Damper Control vs JCW
  180. JCW 2022 JCW Clubman Dynamic Damper Control vs JCW
  181. GP3 ECU Tune for GP3/B48E in america yet???
  182. F55/F56 DYNAMIC DAMPER CONTROL Lowering Springs
  183. JCW Riddle me BM3's gains!
  184. JCW 2021/2022 JCW Mini Questions
  185. JCW JCW Hardtop compression test results
  186. JCW Tire Choice?
  187. F55/F56 New JCW tire size ordering
  188. F54 Has anyone tuned the latest 300bhp from factory JCW Clubman?
  189. F55/F56 My new 2022 F56 JCW Hardtop Auto6
  190. F54 JCW Clutch Issue
  191. F55/F56 Lowering springs on a JCW HT with DDC
  192. JCW VW GTI's suck. Apparently.
  193. JCW Color of headliner in 2021, 2022 JCW Hardtop
  194. JCW When do GP's appear?
  195. F57 Oil change help
  196. F55/F56 What happened to vetsvette
  197. JCW More Current Avatar
  198. F57 Oil change.
  199. JCW 2022 Clubman JCW Updates
  200. F57 New arrival JCW Conv.
  201. F55/F56 Missing programmable keys, and two more questions
  202. F55/F56 Over boost after hard pipe kit install?
  203. JCW Will traction control engagement , overload the clutch?
  204. F55/F56 F56 JCW standard exhaust res delete vs JCW Pro exhaust
  205. F55/F56 2022 JCW Hardtop
  206. JCW Coolant volume?
  207. JCW 2019 JCW Mini new brakes at 22k miles
  208. JCW F54 Dinan Spacers installed
  209. JCW First time in a JCW today - 2021 Countryman
  210. JCW OEM Sport Suspension Rear Sway Bar on DDC Car?
  211. F55/F56 F56 JCW TUNING: What Else Do I Need?
  212. JCW Did all International Orange editions come with DDC?
  213. F55/F56 Solaris orange edition
  214. F55/F56 Back for more!
  215. F55/F56 ComputerScales/Sway Bar Links/Alignment
  216. F55/F56 Why no 60-0 braking data for JCW?
  217. F55/F56 Does tuning effect all modes?
  218. F55/F56 2021 F56 JCW w/JCW Pro Exhaust, JCW Pro Suspension, NM Engineering 22mm Sway Bars...
  219. F55/F56 Harperperformance Downpipe?
  220. JCW Need help :( Torn dust boot on rear caliper piston
  221. F54 Alternate tire size on JCW Clubman
  222. F55/F56 Passenger Sports Display
  223. F55/F56 Anyone Knowswho this 16 jcw belonged to? engine fire
  224. F54 Paint correction, ceramic coating, and ceramic tint.
  225. F55/F56 Modifications/Tuning
  226. F55/F56 ‘21 F56 JCW ECU Remap or Tune Box?
  227. GP3 GP3 tow hook license pate frame and luggage securing options
  228. JCW Is removing Cat cost effective F56
  229. F55/F56 Another Question as to Knight's Edition vs. Loaded 2020
  230. GP3 GP3 tears up the Lightning Lap
  231. F54 How to drag race with a tree
  232. JCW 2021 JCW AC fan stays on after turning off car
  233. JCW 2019 Clubman JCW suspension upgrade options.
  234. F54 Spark plugs for JCW vs S
  235. JCW F56 JCW on order....
  236. GP3 First Mini - starting with a GP3
  237. F54 New 2019 Clubman JCW Owner with a few questions.
  238. JCW Loaded 2020 JCW vs 2019 Knight's Edition
  239. F55/F56 Mini highest rated brand by JD Power
  240. JCW What's the Peanut Gallery's Thoughts on This Spring Setup?
  241. JCW Camber Plate pulled apart...aluminum
  242. JCW Looking for some BIG FENDER FLAIRS for my 2019 Mini JCW F56
  243. F55/F56 2015 JCW snow tires wheels!
  244. JCW Configurator Speed JCW Clubman
  245. GP3 Next GP will be electric???
  246. F54 2020 vs 2018-2019 with tune
  247. JCW Winter Rims from CLA?
  248. GP3 Jeremy Clarkson's Review of 2021 MINI JCW GP
  249. JCW Dinan Elite CEL all of a sudden
  250. GP3 New GP Talk sub-forum for 3rd Gen F56 GP3
