JCW Dynamic Damping missing?
Old Nov 4, 2022 | 12:38 PM
hotchicken's Avatar
hotchicken
So the 2023 JCW supposed to have dynamic damping. I assume that means there is an electrical connection to the suspension components. Normally it’s a wire that attaches at the top of the strut towers that you can see in the front under the hood. I noticed that mine does not have any connections at the top. Does anybody know whether these connections are somehow hidden somewhere that I can’t see them? Otherwise, I think I got shorted the dynamic damping suspension situation.
Old Nov 4, 2022 | 07:08 PM
dpcompt's Avatar
dpcompt
The Dynamic Damping in the 2022-23 models is not adjustable and has no electrical connections. How do I know? I have a '22 JCW Hardtop and asked the same question.The new shocks have a valve that initially releases to soften reaction to sharp road imperfections and it works very well. My '22 is my 5th MINI and even with runflats the ride is really good without any sacrifice in handling.With these new shocks, MINI was able to stiffen the suspension and still not have the jarring ride of many precious models.Hope this helps.
Old Nov 4, 2022 | 08:51 PM
hotchicken's Avatar
hotchicken
great info. thanks!
Old Feb 21, 2023 | 07:53 AM
boki's Avatar
boki
That's great - does that mean that I could get those shocks for my 2019 F56 JCW without dynamic damping and just swap them out? I'm not a big fan of aftermarket coilovers and don't want to lower my car, just looking to get some better damping over harsh potholes. I wonder how much they cost, I'll have to look it up.
Old Feb 21, 2023 | 10:12 AM
Trakwagn's Avatar
Trakwagn
You should be able to, at some point you might even be able to scoop a set of takeoffs for someone who puts coilovers on their car if they are too expensive from a dealer.
Old Feb 21, 2023 | 11:13 AM
hotchicken's Avatar
hotchicken
JCW Suspension
I’ve considered doing coilovers, and I would want to sell my existing set up. It’s from a 2023 with about 5000 miles on it. Where are you located? Shipping would be the big question.
Old Feb 21, 2023 | 11:42 AM
boki's Avatar
boki
I'm in Bronx/NY - 10463 Zip code. PM me what you had in mind pricewise. Thanks.
Old Feb 21, 2023 | 01:00 PM
My guess is its the same technology KONI uses.
Old Apr 3, 2023 | 08:58 AM
blue al's Avatar
blue al
Which MY or production date did old DDC a revert to New DDC ?
I ask as I am window shopping for a new “older Jcw” and have a set of kw coilovers that are DDC compatible sat in a box for the last 5 years
Old Apr 3, 2023 | 11:00 AM
Not sure, but the DDC vs not DDC is the rear shock mount goes from what I believe is a M10 non DDC to an M12 pin so it can hold the wire.
Old Apr 3, 2023 | 11:20 AM
Trakwagn's Avatar
Trakwagn
It was a change to the LCI 2 F56, so 2022 and newer has the updated DDC. Note, this does not apply to F54 or F60 vehicles, they still have the adjustable DDC.
Old Apr 3, 2023 | 06:09 PM
dpcompt's Avatar
dpcompt
2022+ ddc
Just one note: the 2022 JCW with DDC has stiffer springs than previous models
Old May 5, 2023 | 09:09 AM
boki's Avatar
boki
Good info, thanks for that. I mean, how much stiffer could they be, 5-10%? I guess I'd need the whole setup from a LCI '22 model JCW then.
Old Aug 1, 2023 | 12:21 AM
El_Jefe's Avatar
El_Jefe
DCC shocks do not exist currently?
this is from may but August 1 is not that far away.
Iconic package JCW hardtop 2 door
Chulander
Factory JCW Talk (2009+)
30
Mar 21, 2012 06:42 PM
Herk1117
Oct 28, 2010 12:36 PM
Derosi
Mar 16, 2008 10:00 PM
chaincoopers
Suspension
Oct 1, 2007 10:12 AM
