JCW 2022 JCW Clubman Dynamic Damper Control vs JCW
I am trying to configure a clubman JCW and am not sure which suspension I would like. Unfortunately their are none to test drive within a 200 mile radius. I do enjoy a fairly stiff suspension but am a little apprehensive with some of the reports I have read. I have been trying to reach a knowledgeable MINI sales consultant but have not had any luck. I have also called "Ask MINI" four times to speak with someone but have not had any luck there either. If someone has any answers to the questions below I would appreciate the help.
1) Does the Dynamic damper control have the same sway bars as the JCW?
2) Is the JCW suspension 10 mm lower than the DDC?
3) If I configure with Classic trim or Iconic trim I can delete DDC. If I configure with Signature trim it will not allow me to delete DDC? (strange).
4) I can select High Performance summer tires but am not sure if they are non runflats. It appears that only 19" are available with non runflats.
5) Is their a way to add Apple car play to the standard touchscreen media display? Has anyone done any stereo upgrades to the standard system?
Thanks for your help, Steve
THE ITCH
F54 :: Clubman Talk (2015+)
Mar 6, 2022 06:50 PM
