F55/F56 Rotors required to be replaced???
Old Dec 17, 2024 | 10:09 AM
dannyh's Avatar
dannyh
Hi all,
I'm not finding concrete info on this, so appreciate the help first and foremost. The car is complaining about the brakes now, and my shop is telling me my rotors HAVE to be replaced on my JCW at the same time as the pads. They haven't seen the car in awhile. There's no way the rotors are worn as I only have 19k miles on my 2017 F56. The shop is wrong about this, right?
Danny
Edit: https://www.northamericanmotoring.co...placement.html
Old Dec 17, 2024 | 12:14 PM
cmt52663's Avatar
cmt52663
Originally Posted by dannyh
Hi all,
Danny
Dunno if they are correct in assessing the wear, but they are right about the rotors. The only time I ever tried to cut that corner the results sucked, and I immediately did the rotors , then all was well. If the rears are fine you might consider that the eLSD on our cars can eat brakes quickly. My first set fronts went 30k. Then I put in a Quaife and now get 60+k on a set. Do you drive in a “spirited manner”? ;-)
Cheers,
Charlie
Old Dec 17, 2024 | 12:43 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Here is my rationalization... If you're paying a shop to do the work, rotors do not NEED to be replaced, but new rotors will help the pads bed in faster. If you're doing the work yourself, the little bit extra you would pay for a decent set of rotor blanks will still net you a lower cost than paying a shop to do just the pads.
By the way, a brake job is one of the easier maintenance tasks that home DIY-ers can perform.
Old Dec 17, 2024 | 01:40 PM
bluonyx's Avatar
bluonyx
When I had my 19' JCW, I needed rotors after 20K. Thought it was ridiculous but the stock rotors and pads really were worn down and that's with daily canyon driving.
Old Dec 17, 2024 | 01:59 PM
Yep, seen people burn through them due to driving habits, we have you covered with our new v5 rotors. I have the old v4 slotted ECS rotors. https://www.ecstuning.com/Mini-2017-...raking/Rotors/
Old Dec 27, 2024 | 10:56 AM
WhatV8's Avatar
WhatV8
If your rotors are still greater than the MIN spec, then they technically can be reused. Personally I replace mine for peace of mind. If you do keep your rotors and only do a pad change, I would strongly suggest giving the pad surface a good scuffing with an abrasive wheel or pad to remove the thin film from the old brake pads. This will give the new pads a 'clean' surface to bed against and prevent potential vibrations due to inconsistent friction around the ring from the old vs new pad material bedded onto the surface. YMMV.
jserra
Jun 2, 2022 03:54 PM
wjfield
May 9, 2019 05:53 PM
NJ Mini
Feb 24, 2013 03:43 PM
CBR600RR
Tires, Wheels, & Brakes
39
Apr 20, 2007 05:55 PM
lexbomb
11
Apr 24, 2006 01:39 PM
