JCW Looking for some BIG FENDER FLAIRS for my 2019 Mini JCW F56
Old Nov 18, 2020 | 04:53 AM
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
I finally want to get some huge rubber on the ground and am looking for some fender flairs that will let me jump up from my 17x7.5" NM Wheels with 235's Front and 225's Rear.
I want to slide in some 9" wide wheels and tires that fit...I know Mini Mania has these Carbon Fiber Flairs
https://new.minimania.com/part/G3NMX...hoC9f8QAvD_BwE
Pics are Welcome
Old Nov 18, 2020 | 03:10 PM
TheBigNewt's Avatar
TheBigNewt
Will they paint them to match your car's color? If they would that would be a very good looking mod IMO. As I recall people have paid $1,000 just to have their stock plastic arches sanded, finished and painted body color.
Old Nov 22, 2020 | 03:54 PM
Agbullet25's Avatar
Agbullet25
The flare's aren't your issue. It's the actual metal fender behind the flare that'll need to be reworked to allow the wider wheel/tire combo. That's also assuming you can find wheels with the proper backspacing and offset which then would clear the shock assembly.
Old Nov 26, 2020 | 10:10 PM
NamBot3000's Avatar
NamBot3000
I've been thinking of flares too. In addition to the ones carried by Mini Mania, I've also found some universal ones made by Clinched used on some Minis here on instagram https://www.instagram.com/explore/tags/clinchedmini/
The people at clinched recommended the follow options from their line of universal flares:
  1. Glider front and Slider Back available in 7 and 12 cm
  2. NewSchool available in 4,7,10cm
  3. Muscle if your wheels are sticking out 10 or more centimeters
The only thing that has been stopping me from doing this is fear of cutting my fenders lol. If anyone in the DFW area is about to do this, I wouldn't mind helping just to get the practice.
Old Nov 26, 2020 | 10:20 PM
NamBot3000's Avatar
NamBot3000
Also, the folks at Mini Mania shared with me instructions (attached) for flare installation so I could get a sense of how much work is involved.
File Type: pdf
Old Nov 27, 2020 | 07:35 PM
bluonyx's Avatar
bluonyx
You could also do these... they are having their Black Friday Sale right now. Half the price of those other ones, I've been following them on Instagram.
Aesthetic Wide Body Flares
Old Nov 28, 2020 | 11:07 AM
NamBot3000's Avatar
NamBot3000
Has anybody tried the Aesthetic Flares linked above? I like the idea of using the existing mounting points.
The description says 20mm in front and 30mm in back, but, just eyeballing, the pictures provided look much more than 30 mm.
Old Nov 30, 2020 | 08:19 AM
TheBigNewt's Avatar
TheBigNewt
Those look great. 30mm is 1.2" so it looks like that to me. 20mm is 0.8".
Old Dec 2, 2020 | 07:43 PM
Darbys2019MiniJCW
30MM Rear / 25mm Front
Old Dec 3, 2020 | 12:21 PM
TheBigNewt's Avatar
TheBigNewt
So they have to remove the plastic wheel arches and THEN cut the metal underneath to make a wider wheel opening and THEN drill mounting holes in the metal that will allow the bigger (not just wider) wheel arches to be mounted. So the wheels/tires will be bigger around (circumference) than the stock ones not just wider right? I sure wouldn't want bigger circumference wheels like that on my car no sirree. That would slow me way down.
Old Dec 6, 2020 | 11:57 PM
Clutch Wotan's Avatar
Clutch Wotan
https://www.rsic6.com/product-page/w...rglass-version
Old Dec 7, 2020 | 08:45 AM
bluonyx's Avatar
bluonyx
Apparently the Aesthetic fenders use the existing mounting points, I believe the RSI fenders are just held on with double sided tape. You can even see the tape if you zoom in enough on the above post. Kind of near the bottom of the fender where it meets the other piece.
Here's a better pic, you can see the tape near the front...
Old Dec 12, 2020 | 08:34 PM
Clutch Wotan
Iam sure their McLaren and Porsche customers would have said something, if the tape wasn't good.
Ch28Kid
Mar 11, 2020 08:52 AM
jburroughs12
Jan 14, 2020 10:30 AM
Bartosz Storonowicz
Oct 7, 2019 07:47 AM
carfixer100
Jul 23, 2015 09:44 AM
marcussoori
Oct 23, 2014 03:06 PM
