F60 Retrofit fog lights from S onto JCW?
Old Dec 8, 2024 | 03:21 PM
Calypso's Avatar
Calypso
I'm interested in an F60 JCW but I hate how there are no fog lights. It seems absurd, not just for safety, but also for a brand that is iconic for having fog lights????
Is it possible to retrofit factory fog lights from an S like these? https://www.minimania.com/part/G3NMX...F60-Countryman
Can you just swap those bottom trim pieces, or are the clip mounts or size too different? Is there an "open right" trim piece with a fog light? Would it disrupt the auxiliary cooler?
Old Dec 10, 2024 | 08:05 PM
bluonyx's Avatar
bluonyx
I believe you have to swap to a JCW bumper cause the lower grill air vents are a different shape and size. Was going to do this on my wife's S Countryman but we to decided that the fog lights were to important so I never went and did the swap.
Old Dec 11, 2024 | 10:32 AM
Calypso's Avatar
Calypso
Thanks for the info, although I actually want to do a reverse of that. I want to add fog lights to a JCW, ideally in a way thats more integrated than strapping extraneous ones on. It sounds like I may have to put an S bumper on! Kinda silly lol
Old Dec 11, 2024 | 10:43 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I'd be weary changing the front bumper and adding factory fog lights to the JCW. The fog lights were removed, and the bumper redesigned to favor the extra cooling needed from the horsepower increase. The fog light locations house additional coolers that won't get the airflow needed when you change the bumper and add the fog light shrouds.
If I were you, I would add a rally light kit, and keep the JCW bumper and ducting.
https://www.cravenspeed.com/the-rall...t-bracket-kit/
Old Dec 11, 2024 | 01:40 PM
Calypso's Avatar
Calypso
Thank you! I figured that was the case but wanted to ask folks here who knew more in detail. The S still lets airflow in but I wasn't sure if the cooler takes up the whole space or more of the outer half. If the latter, it wouldn't lose much cooling power. But the overall system has enough trouble with cooling as it is so I respect the need to keep it in top shape.
BTW I gathered some materials as a backup for anyone who wants to do the same. Aside from the usual circular button you can add from the S, there's a trim piece that can house an additional auxiliary lights button: https://www.pelicanparts.com/More_In...OE&SVSVSI=MF60
Old Dec 12, 2024 | 05:48 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Be aware that button is for the OEM driving light kit. It will not work with aftermarket lights. Since Mini uses a CAN bus system, the switch doesn't latch like you would expect, but send a voltage change / current differential signal to the OEM lighting controller, which senses the button press as a command to turn on the lights.
Old Dec 12, 2024 | 08:44 AM
Calypso's Avatar
Calypso
That's very helpful to know. Another thing to consider for OEM vs aftermarket...
Eclipseon
11
Mar 8, 2021 12:41 PM
Evasive
Apr 7, 2011 11:51 AM
bond007
Aug 4, 2008 11:14 PM
bpetzold
Electrical
Oct 30, 2006 03:47 PM
bigpmj
12
Jun 6, 2004 10:17 PM
