JCW Powerflex Lower Engine Mount - Do It!
Old Oct 8, 2022 | 03:54 PM
hotchicken's Avatar
hotchicken
Just installed this upgrade. I never thought the engine felt sloppy under acceleration or when shifting, but the before and after is amazing. Completely smooth and flat acceleration and shifting now. Can’t recommend this highly enough. The only difficult part about the whole thing is getting the old rubber insert out of the factory mount. The trick is to cut around and remove the outer edge on one side, and then push it through. Don’t cut your finger off while you’re at it!
Old Oct 15, 2022 | 09:15 AM
jcubwf56's Avatar
jcubwf56
Adding this to my future mods list.
Old Oct 15, 2022 | 01:37 PM
nodrog321's Avatar
nodrog321
Waiting to do my oil change to put this on lol. Did you put the black insert?
Old Oct 19, 2022 | 05:59 PM
hotchicken's Avatar
hotchicken
I did not use the black insert. Saw negative things about vibration. Currently I have very slight additional vibration at idle. Not sure I would notice it if I had not anticipated it happening.
Old Nov 1, 2023 | 12:18 PM
Cableaddict's Avatar
Cableaddict
Is this useful for street driving, or just track use?
Also, I wonder if this can be done on my F57 convertible? There are, sadly, several good F56 mods that don't work because of the F57's extra bracing. Sigh ...
Old Nov 1, 2023 | 12:53 PM
hotchicken's Avatar
hotchicken
I only daily mine and am pleased with the difference.
Old Nov 2, 2023 | 11:26 AM
Cableaddict
Good to know, thx.
I may have ALL my bushings changed to soild or poly. I'm hoping that might also slighlty tighten up the steering, which has too much give in the center for my liking.
EmedpaDHSc
F54 :: Clubman Talk (2015+)
Feb 25, 2023 04:20 PM
CRoth
Jul 10, 2010 10:30 AM
Neufusion
Jun 25, 2010 04:04 PM
sprp85
Jan 22, 2009 09:13 AM
DmOcRsI
Jan 8, 2008 01:16 PM
