Drivetrain How-To for Lower engine mount bushing?
Old Mar 26, 2008 | 05:35 PM
sprp85's Avatar
sprp85
I am looking for some way to reduce the crazy bucking when lifting throttle and I saw that lower engine mount is the way to go.
Anyone got info on how-to change the bushings?
Thanks in advance.
Old Mar 26, 2008 | 05:39 PM
jhiggs26's Avatar
jhiggs26
Jack up front of MINI and support with stands.
Remove mount.
Press out wee end bushing. Press in new bushing.
Install inserts for big end bushing.
Re-install mount.
Lower MINI.
Enjoy!
Jeremy
Old Mar 26, 2008 | 06:14 PM
sprp85's Avatar
sprp85
any special instruction in removing the mount?
how many bolts do i have to remove @ what tq?
thanks
Old Mar 26, 2008 | 06:19 PM
freeskier's Avatar
freeskier
pictures and bushings used?
Old Mar 26, 2008 | 06:41 PM
verveAbsolut's Avatar
verveAbsolut
https://www.northamericanmotoring.co...5&postcount=49
Originally Posted by verveAbsolut
For the Lower Engine Mount:
This is what I mean about a flat deck. The bushing inserts need to be the same height as the steel insert (in the middle). There was NO way in hell it would fit until I ground/sanded it down (on my 04/03 build at least). It was relatively tight even now - I could get it into position but the bolt holes were difficult to align - I ended up using a screwdriver through the bolt hole to line it up first . You can see that I did the small end as well - the insert provided by Powerflex for that location had to be cut and ground as well...it jutted out about a centimeter beyond the purple bushings:
This is what I mean about doing the two big bolts (top and middle) before the 4 smaller ones in the bracket attached to the oil pan. For reference, the top bolt will be longer than the middle bolt. The involved parts have also been cleaned up as well:
Completed install. I apologize for the dirt...I was pulling a Tommi Makinen around an under-construction portion of the neighborhood. You can see where I had to break out the WD-40 and brush:
That all aside, you need:
- Ramps or Jack Stands
- 13mm Socket
- 16mm Socket
- Torque Wrench
- Good Music
- Good Lighting (Like all things automotive)
- 20 Minutes (I needed extra time this time around to grind down the bushings and clean up the area; 20 minutes if you know what you're doing, probably 30-40 first time you **** around under there)
REALLY easy to do. One of the cheapest and best mods for this car. No need to drop a load on engine dampeners...this will get you the same effect, using essentially stock parts, at a lot less cost.
- Matt
Addendum...small bolts are 24 lb/ft I believe...large are 74 lb/ft.
Oh, and my underbody is near spotless now. =)
- Matt
Old Mar 26, 2008 | 06:52 PM
PGT's Avatar
PGT
are those specific to the older models? I have an '06 and my IE bushings look a bit different (maybe just because they're not installed in this pic):
Old Mar 26, 2008 | 06:54 PM
verveAbsolut
I actually bought a replacement dog-bone piece (I thought I was having an issue with one), and it was identical - they've always had the same part number. Inserts made for any R53 should fit. Mine are the Powerflex ones, both the large and small ends, so that would explain the color difference. Installed, they should look the same physically.
As well, don't bother doing the small end...I noticed no gain adding it after having the large end already in place. Save yourself the cash.
- Matt
Old Mar 26, 2008 | 06:57 PM
sprp85's Avatar
sprp85
Nice!
Thank you alot!!
Old Mar 26, 2008 | 06:59 PM
PGT's Avatar
PGT
ok, so jack up on stands, lift/support the motor, unbolt the dogbone, tear out old and insert new, reinstall? that's it? I'll knock it out Fri if so.
Old Mar 26, 2008 | 07:03 PM
verveAbsolut
I didn't even bother supporting the motor....the first time I got under there I did, but considering both the upper mounts stay in place (and that's what's taking the vertical load in the first place), no need to support with a jack.
Oh, and you'll have to unbolt the PS fan for adequate clearance and removal of the dog-bone chunk. The inserts pop right into the large end. Like I mentioned above, I had the additional spent time of sanding/grinding down the flat portion of the bushing insert to make a level deck so it would all fit back into the underside dog-bone holder (if that makes little sense, you'll see).
20 minutes or so, no sanding needed, luck permitting.
- Matt
Old Mar 26, 2008 | 07:05 PM
PGT's Avatar
PGT
yeah...makes sense about the insert. was that included with the new ones or the stock one inserted? I don't believe I saw one with my IE kit
Old Mar 26, 2008 | 07:08 PM
verveAbsolut
The metal insert was only for the small end. The poly insert was for both, and the poly insert on the large end had to be flattened lower.
I apologize if this explanation is coming off terribly.
- Matt
Old Mar 26, 2008 | 07:11 PM
PGT's Avatar
PGT
no, that makes total sense as to why I don't have one
Old Mar 26, 2008 | 08:01 PM
jhiggs26's Avatar
jhiggs26
I also used the powerflex bushings. For the big end I just compressed the inserts into the standard rubber bushing with my vise and used a bit of the grease provided to slip it back into the bracket(no sanding required).
Jeremy
Old Mar 26, 2008 | 10:09 PM
motogeno's Avatar
motogeno
Jeremy
Any oil based grease can deteriorate rubber over time - not sure if this is the case for polyurethane, but might be something to keep in mind.
Old Mar 27, 2008 | 04:44 AM
PGT's Avatar
PGT
it's synthetic grease and Powerflex includes it - surely, they didn't include the wrong type
Old Mar 27, 2008 | 05:47 AM
freeskier's Avatar
freeskier
so Powerflex bushings are the most popular for these?
Old Mar 27, 2008 | 08:14 AM
motogeno's Avatar
motogeno
Gotcha
Old Apr 1, 2008 | 08:35 AM
curv872's Avatar
curv872
Just installed these last night...took all of 15 minutes!
Vibration at idle is more noticeable, but at speed they feel great/perfect.
Question for those with these installed, will the bushings soften/settle with time?
Old Apr 1, 2008 | 08:44 AM
Dr Obnxs's Avatar
Dr Obnxs
Some thoughts on these gizmos
I've been thinking about these things (and engine bushings in general). Idealy, you want to increase the stiffness on the upper and the lower. If not, the engine won't rotate about the torque center. It does that stock if the Mini engineers did thier jobs right. This is all theory though....
Matt
Old Apr 3, 2008 | 08:10 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
BTW, I installed the IE units this morning: it's everything advertised! Vibration is clearly greater at idle, but once moving not noticeable. Handling is vastly improved though, I feel about 20 more HP and fuel economy has gone through the roof...
Old Apr 4, 2008 | 04:52 AM
PGT's Avatar
PGT
Old Apr 4, 2008 | 04:33 PM
ScottinBend's Avatar
ScottinBend
I want data ! ! ! !
Old Apr 4, 2008 | 08:45 PM
DrPhilGandini
Originally Posted by ScottinBend
I want data ! ! ! !
You want data? There will be no data because you don't trust me... I said it added 20HP, made the car feel "more connected" and improved gas mileage! Believe me. Really. Yes, it vibrates more and my engine feels like it's about to fall out of the car...but that's a small price to pay for the improvement in all aspects of Mini performance I am experiencing.
What more can I say?
Old Apr 4, 2008 | 09:09 PM
ScottinBend
