Drivetrain How-To for Lower engine mount bushing?
Old Jan 7, 2009 | 03:09 PM
  #101
polepino's Avatar
polepino
Originally Posted by //MZero
take it over to a mechanic shop or machine shop or anywhere they have a press. It will take them literally 30 seconds to have it pressed out for you and they REALLY shouldn't charge you for it. Or...1 minute of labor is what ~ $1-$1.50
Lol thanks for the advice. After I posted I just went back to work at it. I actually did it at home but it took forever, had to take a knife and electric drill to it coupled with a screwdriver but I cut and clawed that sucker out of there. Needless to say, I have the bushings on there and they feel good. I can definitely feel a little bit more connection to the drive train and definitely feel that infamous 'vibration.' It won't bother me however, I kind of like the more 'raw' feel. But I would say, those who are looking for more ride comfort are probably not going to like it even though it is subtle but noticeable.
One other thing, I did unbolt the little fan that's down there as I was replacing everything. Is it supposed to be running at all times or does it go on and off? I started my car up and checked to see if anything was out of the ordinary and I noticed the fan wasn't running right away. Is this normal or should I make sure that wire plug was nice and tight?
Old Jan 7, 2009 | 04:08 PM
  #102
Dr Obnxs's Avatar
Dr Obnxs
The little fan...
doesn't run all the time. It's to cool the motor for the power steering pump. As long as you got the electrical connectors seated when you put it back you should be fine.
Matt
Old Jan 7, 2009 | 04:15 PM
  #103
polepino's Avatar
polepino
Matt
Thanks Matt!
Old Jan 22, 2009 | 08:10 AM
  #104
mister wiggles's Avatar
mister wiggles
if i order from mossmini, how many of each bushing will i need?
upper engine (1 large, 1 small)
lower engine (1 large, 1 small)
Steering rack mount (1) - is the install for this as straight foward as the engine mounts?
gearbox mount (1)
Is this accurate?
Old Jan 22, 2009 | 09:13 AM
  #105
TonyB's Avatar
TonyB
While you are at it, you might want to order a pair of control arm poly bushings also...
It might be prudent to address the stock ball joints (inner & outer, about 40 to 50 bucks each) as well. Tie rods, strut bearings also, maybe.
If you plan to upgrade or remove the front sway bar, that would be opportune time. Just trying to provide a comprehensive list to make the most of your time. I didn't read the entire thread, so I apologize if this was said earlier...
DixonL2
Apr 13, 2021 08:05 AM
silence2-38554
Nov 12, 2015 09:39 AM
minipopkart
Aug 13, 2015 05:22 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
