F55/F56 Who has added a Catch Can to the B48 JCW?
Old May 8, 2025 | 11:09 AM
nuck's Avatar
nuck
It doesn't seem to be a popular mod for this motor or at least people aren't talking about it? Anyone? If you did, which one did you go for?
Old May 9, 2025 | 11:19 AM
dannieh42's Avatar
dannieh42
I have asked about catch cans a couple of times and no thinks they are needed. I disagree and think they would probably be a benefit, but I haven't figured out a good spot to mount one. Where do you plan on mounting it?
Old May 10, 2025 | 06:52 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
These newer engines have variable cam timing and valve lift control. As a result, they do not pull vacuum in the intake manifold, and a catch can won’t do anything, even if you manage to find a place to install one. PCV is all internal to the cam cover.
Old May 10, 2025 | 07:56 AM
dannieh42's Avatar
dannieh42
Originally Posted by njaremka
These newer engines have variable cam timing and valve lift control. As a result, they do not pull vacuum in the intake manifold.
That doesn't make sense to me, because it was my understanding that every naturally aspirated car must have vacuum in the intake manifold. It's required to pull the air into the engine, and at higher RPMs it takes even more. And even though our cars are urbo charged, they run with vacuum in the intake while cruising and not "on boost".
I'm not saying this to argue. If I'm wrong about this I want to learn so I understand it better.
Old May 10, 2025 | 08:44 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Yeah, with fixed intake valve lift, manifold will see vacuum. With variable intake lift, the intake valves will act more like a traditional throttle valve. As such, the manifold won’t see vacuum greater than ~1” negative. If you connect a traditional vacuum gauge to the manifold, you’ll effectively see zero vacuum.
Old May 10, 2025 | 09:46 AM
nuck's Avatar
nuck
It isn't obvious where to mount. I was going to see what the vendor recommended. To Nik's point, my turbo experience is mostly with 90s vintage Japanese turbos so maybe the newer factory tech is different..
Old May 10, 2025 | 12:07 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The newer engines are much different. Seriously, there isn’t much benefit to adding a catch can, so save your monies.
Old May 20, 2025 | 08:17 PM
Rowland2004's Avatar
Rowland2004
Figured i would link my post on this topic for the F56 https://www.northamericanmotoring.co...ml#post4695693
dannieh42
Sep 22, 2025 07:58 AM
Kentiki
Nov 9, 2024 11:37 AM
Here2Go
Feb 23, 2024 03:55 AM
DomesticMuscle
Factory JCW Talk (2009+)
27
Jan 20, 2014 03:37 PM
Phx JCW
Dec 8, 2011 07:32 AM
